390 inlet manifold
Author Topic: 390 inlet manifold  (Read 2004 times)
Offline simo
  • Name: greg simpson
  • Car: 1969 Mach 1 S Code
390 inlet manifold
« on: June 13, 2021, 12:41:12 pm »
Hi Guys,
My '69 Mach1 is an S code with a 390 FE / C6 auto. The heads that are on it are from a Cobrajet motor but it's running a standard inlet manifold with a Holley 600 cfm carb. My question is would I benefit by swapping over to a Cobrajet inlet manifold or just leave it standard.
Many thanks
Simo
Re: 390 inlet manifold
« Reply #1 on: July 09, 2021, 12:23:58 pm »
Hi Guys,
Many thanks
Simo
Yes,
« Reply #2 on: July 09, 2021, 04:41:31 pm »
If this was in print/still available then it would be great reading and tell you what you need to know and WHY.
http://fepower.net/GFEIC.html
Suffice to say, like Barnett says - you'll get a power increase
Have a read of this - the section by Jay (he wrote the book above) tells you all you need to know
https://www.fordfe.com/new-to-fe-engines-questions-gt390-heads-vs-428-cj-t60504.html
an option for the intake is the PI intake - worth reading about them on CJ heads here:
https://www.fordfe.com/428cj-port-size-compared-to-390-heads-t3553.html
Bottom line - anything will be better than the 390 intake, and headers will perk it up even more. A CJ intake is effectively a MR intake so make sure the cam will support the revs that the top end will support.
« Last Edit: July 10, 2021, 06:53:00 pm by jiffy »
Offline simo
« Reply #3 on: July 27, 2021, 12:02:48 pm »
Many thanks guys and those links were very informative.
