Electric fuel pump
Author Topic: Electric fuel pump  (Read 4036 times)
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
Electric fuel pump
« on: May 10, 2021, 05:05:00 pm »
Hi guys just wondering if anyone can recommend a quite external electric fuel pump I can fit to my 66 coupe It gets abit annoying hearing my pump whining or whirring away.
Thanks,
Re: Electric fuel pump
« Reply #1 on: May 10, 2021, 05:55:44 pm »
Why are you running an electric pump anyway ? . A stock pump will do the job .
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #2 on: May 11, 2021, 06:59:11 am »
I like my electric fuel pump.
No cranking to get fuel to carb.
Also have cutoff switch for anti theft.
Got a Facet external on my car.
Just requires cutoff switch in case of accident.
Offline Micks66coupe
  • Name: Mick
  • Car: 66 coupe
« Reply #3 on: May 11, 2021, 10:13:15 am »
Where have you got the pump mounted? My 66 has an old electric pump (not connected) mounted next to the fuel tank, I found it when I had the car up on a hoist when I was checking it before I brought it.
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #4 on: May 11, 2021, 01:10:52 pm »
The pump was there when i bought it, its mounted next to the tank.
I will have a thorough look and make sure its not vibrating against the tank or the body but it just seems a noisy unit.
« Reply #5 on: May 12, 2021, 06:39:52 pm »
Hi all, I found this on the web!
May help if you're interested!
I can guarantee they'll be quieter than a Bosch 044!
https://soundproofnation.com/quietest-electric-fuel-pump/
Cheers Phil
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #6 on: May 13, 2021, 04:45:01 pm »
thank Phil I'll have a read tonight  :thumb:
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #7 on: May 15, 2021, 05:20:18 pm »
here's pic of mine its a Holley I have no idea of model or specs ?
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #8 on: May 15, 2021, 05:21:32 pm »
pic,
Offline Tempest
« Reply #9 on: May 16, 2021, 10:04:33 am »
I've got a mallory 110 electric pump that I find quiet enough.
I mounted it using a set of FJ Holden radiator bolts that have a rubber center section to isolate vibration.
Works pretty well.
I used an electric pump as I was having vapour lock issues in Darwin's heat and the electric pump allowed me to run a return style system to keep the fuel cooler, solved all my issues.
« Reply #10 on: May 16, 2021, 10:40:24 am »
I'm recessing a BA Falcon pump assembly in a new 22g tank for mine.
Keeps the pump cooler, quieter and hidden away.
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #11 on: May 17, 2021, 03:54:27 pm »
A few people have recommeded the Mallory.
Offline Edz
    • Checkout my car builds
  • Car: 66 Convertible V8 AODE
« Reply #12 on: September 20, 2021, 11:14:06 am »
Don't buy an Aeroflow 97 gph red unless you want a really noisy pump. I have mine mounted on a big rubber insulator but it's still loud.
« Last Edit: December 07, 2021, 05:28:39 pm by Edz »
Offline ag71
  • Name: ag
  • Car: 1966 hardtop
« Reply #13 on: September 21, 2021, 12:55:39 pm »
I decided to stick with what I have for the moment.
Offline Edz
« Reply #14 on: December 07, 2021, 06:00:30 pm »
Most carburettors only like 5 - 7 psi. You would only use a Bosch 044 if you were running efi because they put out 73 psi and 300 lph.
If you used one with a carburettor you would have to run a bypass type fuel reg.
https://www.nolimitmotorsport.com/prod/BSH-580254044
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0580254044.
Minimum Current: 12 Volts.
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Also, be careful of the thousands of Chinese copies out there being sold as genuine on eBay and automotive websites. They look very close to a genuine pump but if they are selling for $50 to $150, they are a copy.
How to spot a fake below:
https://www.facebook.com/BoschMotorsportAustralia/photos/buyer-beware-fake-044-pumpsits-come-to-our-attention-that-fake-bosch-044-fuel-pu/1272574349508824/
https://www.driven2automotive.com/blog/how-to-spot-fake-bosch-044-fuel-pumps/
https://www.rx7club.com/rotary-car-performance-77/bosch-044-real-knockoffs-read-959132/
