Throttle linkage to cable
Author Topic: Throttle linkage to cable  (Read 1726 times)
Offline edd666
  • Name: Eddie
« on: April 27, 2021, 06:29:53 am »
Hi, Anyone know of a suitable upgrade for a throttle peddle and cable to replace the old rod linkage set up on a 66 mustang V8 before I go searching the wreckers. Thank you
Re: Throttle linkage to cable
« Reply #1 on: April 27, 2021, 12:13:31 pm »
Hey Eddie,
Look up Lokar accelerator pedal and cable set up!
Do you have an automatic with kick down, if so you may need something else, I'm talking manual transmission!
https://images.app.goo.gl/FnNPFtYQAZTLnqdA8
« Last Edit: April 27, 2021, 12:20:35 pm by AussiePhil »
Offline edd666
  • Name: Eddie
« Reply #2 on: April 27, 2021, 03:26:12 pm »
Hi Phil
Thank for the reply, I should have mentioned it was auto with a kickdown
Offline edd666
  • Name: Eddie
« Reply #3 on: April 27, 2021, 03:30:29 pm »
Quote from: AussiePhil it might be handy if I do not connect the kick down?link=topic=35884.msg336610#msg336610 date=1619489611
Hey Eddie,
« Reply #4 on: April 27, 2021, 03:47:50 pm »
Hey Eddie,
I know absolutely nothing about autos!
I think you still need your kick down or the gearbox will be sluggish!
Someone on the forum will have an answer!
You won't have to wait long, someone will advise!
Lokar probably has a cable from your carby linkage back to the transmission?
Cheers Phil
« Reply #5 on: April 27, 2021, 03:56:27 pm »
Lokar are the go to for this.
You can get:
Pedal (BAG-6115)
Throttle cable (various lengths)
Carby linkage (to suit your combo)
C4 kickdown cable (cheaper copy https://www.ebay.com.au/itm/392946449143?epid=23041070651&hash=item5b7d6efaf7:g:34EAAOSwwmlc0L0i)
« Last Edit: April 27, 2021, 04:02:39 pm by Dwayne »
Offline edd666
  • Name: Eddie
« Reply #6 on: April 27, 2021, 11:27:33 pm »
Thank you for your help, I will chase these parts
