67 Fastback S Code - Mechanical Work Recommendations near Sydney
Author Topic: 67 Fastback S Code - Mechanical Work Recommendations near Sydney  (Read 3059 times)
Offline GSD
  • 67 FB S Code
  • Name: Maurice
Hi there,
Hoping the some of you might be able to help me, you guys have a wealth of knowledge.
I am in need of recommendations around Sydney of who can carry out the following:
- Overhaul of 390 FE engine, is there a minimum scope of work that you can recommend. Not after huge performance, just a cruiser
- 4 speed top loader gearbox overhaul
- 9" diff, doesn't have to be concourse but period correct, where can i get one
Thanks in advance.
« Last Edit: April 23, 2021, 11:12:46 am by GSD »
Offline birdman
  • Name: John
Which area in Sydney?
I'm not a Sydneysider but the smart money is usually on taking it to Big Al.
https://www.bigalsmustangs.com.au/
Offline GSD
  • 67 FB S Code
  • Name: Maurice
Re: 67 Fastback S Code - Mechanical Work Recommendations near Sydney
« Reply #3 on: April 23, 2021, 07:42:49 pm »
Anywhere in Sydney, willing to travel wherever it may be.
Give Al a call, if he can't do it then he'll certainly know who can.
i would do a couple of the oiling system mods like run a cj oil filter adapter, enlage the oil feed hole, and put a restrictor (70 holley main jet) in the oil feed hole to the rockers.
blue printed oil pump with high perf oil pump drive
more info here
https://www.diyford.com/ford-fe-engine-oiling-system-complete-guide/
« Last Edit: May 11, 2021, 05:36:28 am by barnett468 »
Offline 438 mach
  • Name: Allan
  • Car: 69 mach 1
Westend Performance at Campbeltown
did all machining and balancing and some head work for my 438 that i assembled
will be taking another 351 to them soon
69 mach 1 438 dart CHI heads CHI dual plane Intake Holley terminator EFI TKO 600 4:11 rear twin 3" exhaust.
goes like a rocket
Offline fredm666
  • Name: federico
  • Car: 64.5 D-code - 55 Cusso
Hi there,
Thanks in advance.
Like someone else said, I would recommend Big Al as well.
fred
