'69 parts - latest parts and prices - this all goes into storage early December
Author Topic: '69 parts - latest parts and prices - this all goes into storage early December  (Read 5513 times)
Restored '70 428CJ Shaker $2500
set of new fender bolts and captive nuts $10
Pair of good used 69/70 door mechanisms $20
Pair of new door striker plates $10
Pair of internal door handles and rods $20
Fuel tube $10
Set of correct new radiator and heater clamps 390/428 $10
Rear bumper to tail-light panel rubber dust seal $10
Rubber gaskets for mounting rear spoiler $5
Pair 69/70 Quarter window lower pivots $50 (fastback only)
Big block engine mount rubber insulators $25 each
Big block engine mount set (3/side) $100
Black sunvisors w/mounts. Visors good, mounts corroded. $free
70 front valance used original no rust $20
'69 non-A/C heater resistor pack - $15
65/66 reversing light/rear valance seals, new repro, opened  $5
69 fuel line clips used set - $10
70 RH front indicator - used, sound needs resto $10
69/70 big block upper clutch rod used $10
69 LH front indicator needs new lens but sound $10
67-70 pink toploader 31-spline output shaft speedo gear (for 3.50:1-4.30:1 rear end ratios) new but fitted once - $15
390/428 crank pulley 3 sheave (for P/S cars) C8AE-6312D $100
390/428 Partial SMOG setup - working CJ SMOG pump & non-a/c pulley, manifolds, valves, canister & bracket (leaking diaphragm), no hoses $750
69 non-tach, non-A/C dash harness really good $100
Would prefer pick-up in Rowville SE Suburbs or shipping if buying multiple items, but all this stuff needs to go....
« Last Edit: January 10, 2022, 03:18:33 pm by jiffy »
Offline seany-boy
  • Car: 1970 Mach1
Re: '69 parts
« Reply #1 on: April 12, 2021, 11:21:20 pm »
are the qtr panel extension seals new condition?
Re: '69 parts
« Reply #2 on: April 13, 2021, 12:42:58 pm »
Brand-new in a bag....
Offline IMHI2
  • Car: 69
Re: '69 parts
« Reply #3 on: May 26, 2021, 04:25:32 pm »
If available I'll take:
65-70 door hinge repair kit - 4 pins and 8 bushes $20
69 accelerator pedal and rod/pivot $10
69 1/4 panel ext seals $10
 will need to post to 4036 thanks Gavin
« Last Edit: May 26, 2021, 04:40:29 pm by IMHI2 »
Never Met a Mussy or Lee Enfield I didn't want
Re: '69 parts
« Reply #4 on: June 15, 2021, 11:32:12 am »
IMH12 - I never heard back from you - sent you a PM??
Still interested?
Offline IMHI2
  • Car: 69
Re: '69 parts
« Reply #5 on: June 17, 2021, 10:32:27 pm »
Hi Jeff Yes I am mate pm'd you.
Re: '69 parts - latest updates
« Reply #6 on: September 28, 2021, 08:51:00 pm »
Bumping to the top - would consider a silly price for bundles of parts - I'm moving and this stuff really should go to a good home...
Offline Tanner18
« Reply #7 on: October 03, 2021, 07:41:59 pm »
Hj mate,
Can you send pics of the heater and is the trunk seal used or new?
