5 speed conversion 1970 mustang SOLD
Author Topic: 5 speed conversion 1970 mustang SOLD  (Read 1985 times)
Offline scott
« on: November 08, 2020, 08:39:17 pm »
for sale is a complete rebuilt 5spd with conversion to fit  1970 mustang to 351cleveland, it will fit any early Cleveland or Windsor, also comes with a 90% complete cable conversion for a 1970 mustang as well only missing the back plate for fire wall they are available from mdl for 100 bucks, parts are as follows.t5 5spd  rebuilt with new master kit and new gears with only about 600 ks on it ,clutch pres plate and flywheel ,arp clutch bolts, cross member for 70 mustang, clutch fork, yolk 28 spline ,brake pedal, Hurst shifter, Hurst rubber boot, bell housing and starter spacer, I have a sandwich plate but it has a crack in it that was there when i installed it so you may need a new one of those ,clutch cable and pedal mounting hardware, the bell housing is also drilled to take a hydraulic cylinder if thats what you have already  $2800      :burnout:
« Last Edit: November 30, 2020, 04:59:09 pm by scott »
