Front Disc Brake Pads
Author Topic: Front Disc Brake Pads  (Read 6309 times)
Offline Small Block
« on: September 29, 2020, 09:19:54 pm »
Does anyone know the part numbers for the front disc brake pads for a 65 Mustang disc brake conversion?
Thanks,
« Last Edit: September 30, 2020, 10:04:06 am by Tarheel »
Re: Front Disc Brake Pads
« Reply #1 on: September 30, 2020, 07:48:43 am »
You might have to take them out and take them into a store like Bursons so they can do a match up . If they can not match them up with any you might have to get them rebonded or order a new set from the USA .
Offline nickd
  • MOCA Vic Member 924
  • Name: Nick
  • Car: 1965 Coupe
« Reply #2 on: September 30, 2020, 03:14:14 pm »
Sometimes the pad will have a part number on the back. Otherwise, put up a photo of the caliper and someone may be able to tell you what it is off.
« Reply #3 on: September 30, 2020, 03:31:39 pm »
What conversion have you got?
Is it just the KH style calipers or something more modern that was adapted to fit?
Offline Small Block
« Reply #4 on: September 30, 2020, 03:40:34 pm »
It' the Kelsey Hayes style, so I'm hoping these are just a regular brake pad that can be ordered from somewhere like Repco?
« Last Edit: October 10, 2020, 09:45:15 am by Small Block »
« Reply #5 on: September 30, 2020, 04:51:02 pm »
Any of the local mustang suppliers will be able to help you then, I'm guessing most would carry a consumable like them in stock
Offline Small Block
« Reply #6 on: September 30, 2020, 05:34:29 pm »
I was just hoping to order a set through Supercheap or Repco, or Bursons... I don't know what to order though at the moment. I do see disc pads for a 65 Mustang listed at various stores, but will these fit what I have?
« Last Edit: October 02, 2020, 07:53:07 am by Tarheel »
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #7 on: September 30, 2020, 10:40:05 pm »
dont order any ordinary brake pads, been there done that.
a few of us have found EBC 'green stuff' or better yet 'red stuff' pads are brilliant with KH calipers.
they're way more expensive than then garden variety SD's but totally worth it, ill check the cat# as i put some new red ones in 2 weeks ago.
(ill blame ShaunP for putting me onto them years back) :cheers:
« Last Edit: September 30, 2020, 10:55:00 pm by griff »
you get that .....
Offline Small Block
« Reply #8 on: October 01, 2020, 07:16:44 am »
Thanks, part numbers would be great.
I did see some good brands listed with Supercheap. Are these not recommended?
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #9 on: October 01, 2020, 10:19:46 am »
the likes of supercheap will probably have to order their brands in (ie bendix), any correct pad will work, i just have a preference for EBC red or green because theyre way better than anything else ive fitted and others whove used them will say the same.
if your setup is per that picture you posted then they look like std KH calipers.
EBC red stuff DP31157 will fit these or green stuff are a bit cheaper but excellent as well.
it depends what your budget is though mate!
« Last Edit: October 01, 2020, 10:31:47 am by griff »
you get that .....
Offline Small Block
« Reply #10 on: October 01, 2020, 11:34:52 am »
Thanks very much! Where do you purchase these from? What sort of prices are we talking?
Are the ones listed around the place all based off the Kelsey Hayes set up? If I ordered Bendix for a 65 Mustang, will those fit?
« Last Edit: October 02, 2020, 07:56:01 am by Tarheel »
Offline 289 vert
« Reply #11 on: October 03, 2020, 08:22:52 am »
Yes, they should. But, the Bendix DB1807 that Supercheap lists, is incorrect. I don't think Bendix Australia carrys the 65-67 D11 KH pads
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #12 on: October 03, 2020, 11:56:17 am »
correct. bendix didn’t have them listed at all, i’ve looked through their dealers catalogue that has full scale outline drawings of pads.
the only luck you may have is finding them listed as ‘67 mustang or XR falcon V8 with KH, i lost interest in finding average brake pads to be honest.
taheer if cost is an issue then just get the scott drake replacements from a mustang dealer like Sydney Mustangs or Harry’s.
EBC pads make some people on limited budgets reach for a defibrillator.
you get that .....
Offline 289 vert
« Reply #13 on: October 03, 2020, 01:43:35 pm »
:smile01: So true.
In America, the Bendix pads are $22. EBC, Porterfield R4-S, and Hawk HPS will cost at least 6 times that. The Bendix pads are definitely average.
Offline Gallop
« Reply #14 on: October 06, 2020, 10:02:42 pm »
Hi Griff,
Just wondering from where you buy your EBC brakes pads?
Thanks.
Andrew
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #15 on: October 07, 2020, 10:01:38 pm »
hey andrew. i see you’re in brisbane i bought my first set from a brake specialist in Capalaba while up there some years back, but recently got slotted RDA rotors and EBC red pads from my local PEPS auto parts.
i did all the enquires first with RDA in Brisbane who referred me to PEPS down here in southern sydney.
look up rdabrakes.com.au
footnote: after a month of bedding in the discs and pads i did some serious braking at speed down Bulli Pass south of Sydney, those who are familiar will know how steep and long it is and it’ll test how much brake fade you’ll get by the bottom, i was extremely pleased with how good they performed to say the least. all up they cost $550. well worth it
you get that .....
Offline evan
« Reply #16 on: October 08, 2020, 07:56:46 am »
I also installed RDA slotted/dimpled rotors & EBC Redstuff pads a few months back. I'm now getting less fade & more bite. I was concerned about cold braking but was pleasantly surprised. 3-4 times the price of others but worth every cent. I'm running the Commodore caliper/Falcon rotor setup and have tried at least 5 different pads. The only ones that worked were Remsa & EBC. I've always been happy with Bendix in the wife's car but for some reason, they just wouldn't bite in the Mustang.
Evan.
Offline birdman
  • Name: John
« Reply #17 on: October 08, 2020, 08:02:30 pm »
Evan.
Hey Evan,
What booster/master set up are you running?
Offline evan
« Reply #18 on: October 08, 2020, 08:20:21 pm »
Ha, just mentioned what I'm running on another thread Johnny!  :grin:
I'm running a universal 7" dual diaphragm booster with XB M/C.
Evan.
Offline Small Block
« Reply #19 on: October 09, 2020, 05:53:25 pm »
Sure does!! I just can't justify $250 for a set of brake pads. I think I have found a good alternative though and will give these a try. While looking for a good brake pad, I did have a sales Rep say that he thought EBC were overpriced for what you get. Who knows, so I will see how I go.
Offline birdman
  • Name: John
« Reply #20 on: October 09, 2020, 08:35:01 pm »
Evan.
Thanks Evan, just read it.
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #21 on: October 09, 2020, 11:29:22 pm »
Ha when a sales rep says something is overpriced, its usually their oppostion's superior product they're referring to....
(price is never a problem for me, if its worth it ill pay it :thumb:)
you get that .....
Offline Small Block
« Reply #22 on: October 10, 2020, 09:43:48 am »
Or it could  be that they are over priced for what you get...
Either way, time will tell
Offline evan
« Reply #23 on: October 10, 2020, 10:55:54 am »
I would normally agree but not in this case. After buying so many different brake pads, master cylinders, rotors, pressure tester & God knows what else, the $200 odd I spent on Redstuff pads was money well spent. I'd hate to think how many hours I poured into chasing my braking issues. I've always been a fan of Bendix but in this particular case, they wouldn't pull up the car. Possibly something to do with my conversion but I've heard others on this forum requiring EBC pads with their KH brakes.
Give the cheaper pads a try & if they don't work, go the Reds.
Evan.
« Last Edit: October 10, 2020, 10:58:20 am by evan »
Offline Gallop
« Reply #24 on: October 12, 2020, 07:43:04 pm »
Thanks for the information about RDA brakes - I think a set of EBC brake pads will be coming my way soon.
