67 390 cuin fan clutch replacement
Author Topic: 67 390 cuin fan clutch replacement  (Read 3138 times)
Offline gavin57
  • Name: Gavin
  • Car: 1967 GTA 390 Coupe
« on: July 16, 2020, 06:56:54 pm »
I need to replace the fan clutch on my 67 390 big block. The only one listed on most of the parts sites is the Scott Drake 68-69 replacement but it does not fit. My current fan clutch is wider and flatter.
Does anyone know where to source a replacement, preferably in Oz?
Thanks.
Offline chopmgw
Re: 67 390 cuin fan clutch replacement
« Reply #1 on: July 16, 2020, 08:11:42 pm »
https://www.ebay.com.au/itm/Engine-Cooling-Fan-Clutch-Hayden-2710/363024284579?hash=item5485eefba3:g:fTYAAOSweKNeVSx~&frcectupt=true
Looks like the same model I used on my 68 302.
I bought from this seller a couple of years ago. He`s OK.
HTH
I can smell oranges !
Michael
Offline 289 vert
« Last Edit: July 19, 2020, 11:38:38 am by 289 vert »
Offline gavin57
  • Name: Gavin
« Reply #3 on: July 19, 2020, 02:37:45 pm »
Thanks Guys, not sure what the difference is between the Hayden 2710 & the 2711 but both seem to be listed as correct fitting. Thnks.
Offline 289 vert
« Reply #4 on: July 20, 2020, 09:39:35 am »
Distance From Clutch To Mounting Flange, 1.75" for the 2710
1.4" for the 2711
