'69 (mainly) parts for sale
Author Topic: '69 (mainly) parts for sale  (Read 2202 times)
« on: July 13, 2020, 10:32:16 pm »
Not mine - phone Chris on - oh For 1 seven, Ate oh 9, five for two or email on violetta.steart at bigpond.com
New non-fold down rear parcel shelf
Used glove box
428 CJ water pump, original, suit re-build CA8E 8505H 8A31 date
Shaker scoop bracket, original, used x 3
NOS shaker scoop rubber seal C9ZZ-9B624-C x 2 new
Front headlight splash shields, pair, used
Starter motor BB 390-428 used
Power steer pump x 2 used
6 rims ROH 6 x 14 Ford date 15.12.77, 14.12.73, 15.12.77, 14.10.76, 16.12.74, 2.7.75 12 slots
Licence plate mount, used
Pitman arm, used
Side air vent plastic cover, used
Regulator, used
69 390 S code exhaust manifold, used
69 428 exhaust manifold with spacer, mint
Air plenum, used, very good
Pair of dash plastic end covers, good
Quarter vent window locks with attaching brackets, pair
Quarter window sail light, great condition
2 x yellow top coil
Horns, pair, good condition
Hood scoop emblems, NOS 351, 427, used 428
1969 glue-in complete glass window assembly
New Scott Drake 67, 68 kick panels, black
New front screen air duct, repo
Front autolite shock absorber, pair, mint & back one damaged
Original battery hold-down clamp, good, used
Original rear tail light extension, pair, cast alloy / 1 x early fibre glass
Horns x 4
Distributor top 428 CJ
NOS fusible link wire
428 CJ power master mini starter motor, new
Ford power steer #3006 belt x 7 new
Front interior pillar covers window front, new x 2 white
NOS ford front drum brake lines, pair
NOS ignition leads motorcraft, auto light, Marti auto
NOS side reflector bezel x 2 with hardware
New 1970 heater tube 428 CJ repo
New wiper motor mount 69-70 repo
Used jack handle
NOS gold Mach 1 stripe kit x 2
New radiator water necks thermostat housings x 2 repo
New quarter window vertical trim x 1, rubbers x 3
Used pop-open petrol caps, 1 nice, 1 driver, Ford
New pop-open petrol caps x 2, repo
Used interior door lights x 2 pair, Ford
Used hood scoop indicators, pair, Ford
Used roof sail ornaments, de-chromed, Ford
Used 69 F/B petrol neck filler, Ford
New mini torque starter motor (mean green) brand
NOS 1965 dash wood C522-10838-B
New re-chromed mustang boot letters 2 sets at least
New tail shaft safety loop
Front seat guides, both sides
Window boomerangs, 1 set mint re-chromed, other set used
Used external door handles
Used 2 x top radiator bracket
Solenoids x 2, 1 used , 1 new
Used rear tail light housing and lenses, pair
Used bonnet latch release x 2
Used air vent assembly, pair
Used 69 radio bezel
Used pair internal door handles
Used head light buckets, rings, plastic surrounds
Used radiator centre support bracket
Used pair shock tower braces
Used pair hinges hood possible 67,68 x 2 pair
Used wiper motor arm, motor
As new 8” gear set 3.5 ratio mint
Good used front guards, pair, Ford
Inner wheel wells, pair, new
Boot latch assembly, new, sheet metal
Used carbs spacer C9ZE-9A589 good condition
Rare 428 staggered shock plates mint
Blow-proof 428 bell housing, mint condition
Used front 69 bumper bar, bare metal, needs re-chrome
Used Ford 9” centre C7AW9 69 date 9E19
New 69 front spoiler, aftermarket, new, correct grain
Used RHD converted 1969 cowl panel, sheet metal
Used 9” housing snubs, 1 Mustang, other not sure
Used 9” centre Ford 3.25 gears, good for parts
Used heavy duty traction bars, not home-made, these would suit Gasser or came with 69 Mustang
Used rear exhaust panel, good, Ford
New sump, big-winged, baffled 428
Used 302 Boss into XR, XT, XW, Y Falcon, well-made
Melins pick up suit big sump 428
Fold-down seat parts x 3 used
Holley 4 barrel adaptors spread & square bore
NOS wide grill moulds x 3, 1 used
NOS thin lower grill moulds x 4
Used light teak door panel insert, good
NOS eye brow moulds
Used eye brow moulds
NOS very rare Dixo hood mounted tacho
Front guards, good, used, Ford
Inner rear wheel, sheet metal, new repo
428 used starter motors x 2
Alternator
Valley pan
Used upper control arms
68/69 302 Windsor block STD
351 Windsor block STD, fuel-injected style, suit 427 stroker
NOS DIXO hood-mounted tacho, rare, in original box with wiring & instructions
69 NOS rear tail light panel
69 NOS petrol cap, rare
Traction Master traction bars NOS
69/70 mint air cleaner bases with mint chrome lids
Many, many more parts available – please enquire
Offline Tanner18
Re: '69 (mainly) parts for sale
« Reply #1 on: January 27, 2021, 10:16:02 pm »
Hi mate,
You still got those 69 parts for sale?
« Reply #2 on: January 28, 2021, 02:47:53 pm »
"Not mine - phone Chris on - oh For 1 seven, Ate oh 9, five for two or email on violetta.steart at bigpond.com"
