68 Mustang ( Indicators not working ) Emergency flashers are working ??
Author Topic: 68 Mustang ( Indicators not working ) Emergency flashers are working ??  (Read 2002 times)
Offline 69 SCJ
Hello
Yes the indicators are not working and yes the Emergency flashers ARE working.
Does this mean the turn signal flasher is crook.
If so why does the emergency ones working.
Is there 2 flasher units??
If so where the hell are they.
Yes im sure you will have the answer.
Thanks an advance as always
Cheers Steve  :sick:
Offline unilec5544
  • Name: Neil.
I do believe there are two cans, it may be up near the steering column or fitted to the back of the dash instrument panel.
Hi Steve, there are two flashers, mine are directly over the steering column behind the gauges.
You may be lucky enough to place your hand around the steering column and pull it out. (If it's loose and not attached to anything) mine are zip tied to the frame.
Have the emergency flasher working so you feel the pulse and don't pull out the wrong one.
Other than that you'll have to pull out the gauge cluster.
Good luck with it!
