Speedo Cables / Drives
Author Topic: Speedo Cables / Drives  (Read 8945 times)
Offline Geoff Rose
  • Car: Mustang 67 Coupe
« on: May 14, 2019, 02:57:45 pm »
Hello fellow mustangers.
I hv a 67 RHD coup. My speedo reads faster than I am going.
I think when it was converted to RHD an Australian Ford speedo cable was used because I don't think the LHD speedo cable would reach across from the LHS of the transmission to the RHD instrument cluster.
Does anyone know if the gear at the end of the cable for Australian Fords and Mustangs is the same gearing?
I am trying to work out if it is an incorrect drive gear on the cable or the actual speedo.
Offline birdman
  • Name: John
Re: Speedo Cables / Drives
« Reply #1 on: May 14, 2019, 03:21:52 pm »
Colour of speedo gear (number of teeth) should correspond with your diff ratio.
Offline mcarnage59
« Reply #2 on: May 14, 2019, 04:20:39 pm »
Wheel and tyre combo exactly the same as original?
Always dreamed I'd have one!
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #3 on: May 14, 2019, 05:01:10 pm »
My 66 coupe is  rhd and I replaced the speedo cable recently with an off the shelf standard part.
Suppose it depends where the hole to enter the cabin is.
Offline Geoff Rose
« Reply #4 on: May 14, 2019, 05:05:48 pm »
Rim size is same but tyres bigger height wise, they are a bit balloon.
Speedo diff ranges from 10 - 15 MPH.
Never thought of that will check.
Offline Geoff Rose
« Reply #5 on: May 14, 2019, 05:06:55 pm »
I might get a new one and try.
Thanks reply.
Offline Geoff Rose
« Reply #6 on: May 14, 2019, 05:07:54 pm »
OK thanks will look into it.
TA
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« Reply #7 on: May 14, 2019, 10:56:14 pm »
As birdman and mcarnage59 have said, the only things that will affect your indicated speed vs actual (provided you haven't changed the diff ratio) are the diameter of your wheels/tyres and the drive gear on the transmission end of the speedo cable.
Once we know the diff ratio, wheel/tyre size and what kind of transmission you have we can calculate the number of teeth you should have on the end of your speedo cable. It's then a simple job to yank this out and check against what you have now.
Brian
Offline Geoff Rose
« Reply #8 on: May 15, 2019, 10:00:02 am »
Thanks Brian, Will check it all out.
Offline Clubman7
  • Cruising.
  • Name: Brett
« Reply #9 on: September 18, 2019, 06:01:11 pm »
New cable fitted earlier in the year was a standard Mustang repo cable which although fitted to a rhd converted car did make the distance from the gearbox to the speedo.
Unfortunately bend out of transmission puts too much load on the drive gear and it chewed out gear again.
Ordered new gear and XW-XY Falcon cable to replace standard Mustang one.
Fitted it today with Falcon cable being about 350mm longer.
Gives much better path without having to bend too as tight a radius in places.
Also drive size of square on each end of Falcon cable is the same size as the Mustang cable I replaced. (Read somewhere they were different.)
Will test this weekend.
Offline unilec5544
  • Name: Neil.
« Reply #10 on: September 18, 2019, 07:38:51 pm »
Interested in how the falcon cable works for you.
