Speedometer Issue.
Author Topic: Speedometer Issue.  (Read 6155 times)
Offline Blacksally1
  • Name: Bill
  • Car: FM GT Fastback
Speedometer Issue.
« on: January 31, 2019, 02:15:01 pm »
The speedo in my car is not accurate and is out, by a lot.
I have checked on my Garmin GPS and a couple of phone apps and at the indicated speed of 100kph I am actually doing only 93kph. I have to set my Cruise control at 118kph to do 110kph on the highway.
I have 20 inch wheels fitted but the actual total diameter is stock. My friends new 2018 Mustang is the same. Apparently it is common.
This really is a PITA, you have no idea what your actual speed is, causes stress every time I drive past the police or a speed trap.
My Toyota Landcruiser is dead accurate, My Nissan Patrol ute is dead accurate, My SV6 Commodore is pretty close, the daughters Subaru Outback is spot on.
Has anybody had Ford Australia  fix this issue? I see that in the States a re-flash of the ECU is available to fix this problem.
2017 FM GT, Tickford Build: Tune, 20' wheels,H&R Suspension, 3' exhaust, diffuser, CAI and Tickford air box with TBS.
Re: Speedometer Issue.
« Reply #1 on: January 31, 2019, 02:41:44 pm »
My wife's 2010 subaru impreza is the same, 117km/h on the speedo is actually 110km/h.
Offline mcarnage59
« Reply #2 on: January 31, 2019, 03:25:11 pm »
https://www.youtube.com/watch?v=XpA57X4Em8Y
Check this out, he is not for everyone but often has some good info.
Always dreamed I'd have one!
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #3 on: January 31, 2019, 04:13:26 pm »
F%@cking Santa Claus is giving out car advice.
Offline JasonK
  • Name: Jason
  • Car: 2015 GT Convertible
« Reply #4 on: February 01, 2019, 01:47:19 pm »
Mine is out by 3km/h at an indicated speed of 40 km/h.
As I understand it that is normal. I would guess that then correlates to 7.5 km/h at 100km/h.
I only really notice anything wrong when going through those roadwork signs that say '82, slow down' and I look at my speedo and cant work out how 82 came up. Never knew if it was my car or the sign giving wonky data.
Offline Tempest
« Reply #5 on: February 01, 2019, 02:48:51 pm »
It's perfectly normal.
Australian Design Rule 18 sets out the accuracy standards for vehicle speedos. Until July 2006 this rule specified an accuracy of +/- 10 percent of the vehicle’s true speed when the vehicle was travelling above 40km/h. That is, at a true vehicle speed of 100km/h the speedo could indicate between 90km/h and 110km/h. An odometer accuracy of +/- 4 percent was also a requirement.
From July 1 2006 a new standard began its phase in and by 1 July 2007 all new vehicles had to comply. The new standard requires that:
The speedo must not indicate a speed less than the vehicle’s true speed or a speed greater than the vehicle’s true speed by an amount more than 10 percent plus 4 km/h.
Odometer accuracy is no longer defined.
What this means:
For a vehicle travelling at a true speed of 100km/h, the speedo must read between 100km/h and 114km/h.  The effect of this is that you will find that at an indicated 100km/h you are driving up to 14km/h below the speed limit, as slow as 86km/hr with 100km/hr indicated on the vehicle’s speedo.
The speedo must always read 'safe', meaning the vehicle must not travel faster than the speed indicated by the speedo. So you don't need to worry about speed traps as you'll always be slower than what the needle says.
So long as you're actual speed is between 86 and 100 when your speedo indicates 100 its legal.
« Last Edit: February 01, 2019, 10:30:49 pm by Tempest »
Offline JasonK
  • Name: Jason
« Reply #6 on: February 04, 2019, 09:29:06 am »
10% +/- 4 km/h, to me at least seems a huge window.
Is it not possible to have the reading simply be accurate?
(hoping there is an engineer or someone on here who know for sure)
Offline Sharkierulz
« Reply #7 on: February 04, 2019, 10:24:28 am »
The speedo is way out (it complies with the law). At indicated 120km/h you are doing 111km/h. I have tested this via a GPS.
You will also note that the cruise control speed is less than the analog speedo, at 115km/h set on cruise you are doing 120km/h on the analog speedo.
What is interesting is that if you activate the engineering mode digital speedo, you will find it is spot on. 111km/h on digital = 115km/h on cruise = 120km/h on the analog speedo.
I tend to drive with the digital speedo on all the time for this very reason. Know your margin and drive accordingly, do not attempt to "fix" it.
« Reply #8 on: February 04, 2019, 11:03:37 am »
I wonder if they do it on purpose to keep most people from speeding   :bolt:
Offline Tempest
« Reply #9 on: February 04, 2019, 02:08:33 pm »
I agree
I also agree that its too big a 'window'. If you were on the limit of what the standard says, with 100 indicated but actually only doing 87 in a 100 zone, you'd be a hazard to those actually travelling at 100.
Offline Xrayman
  • Fatigued - sick of overtime
« Reply #10 on: February 04, 2019, 04:48:25 pm »
but actually only doing 87 in a 100 zone , you'd be a hazard to those actually travelling at 100.
but no-one here drives a Camry, do they?  :bolt:
Aaron
what is essential is invisible to the eye
Offline scollist
  • 65FB, 2017 GT
  • Name: Shane
« Reply #11 on: February 04, 2019, 05:58:50 pm »
I found my 2017 was only about 3kmh out. But bought one of these as I wanted a big digital readout rather than analogue gauge (and couldn't be bothered setting up Engineering mode every time I started the car).
It plugs into the OBDII port and allows you to set an offset percentage to display. E.g 106% will display a value 6% higher than the computer is transmitting (be careful to check this with a GPS).  I'm not sure it if will go to 110% though - which is what is needed if 100kmh on gauge is only 91kmh actual, so check with the seller first.
https://www.ebay.com.au/itm/P12-Car-HUD-Head-Up-Display-OBD2-OBDII-Fuel-Consumption-Speed-Warning-System-RPM-/263719199129?hash=item3d66e3a199&_uhb=1
Offline Sharkierulz
« Reply #12 on: February 05, 2019, 09:56:59 am »
I like this idea. Have always thought about doing a HUD. Can you please post a picture or 2 of what it looks like in the 2017?
Offline scollist
  • 65FB, 2017 GT
  • Name: Shane
« Reply #13 on: February 06, 2019, 01:14:20 pm »
Here are pics of the devices I have in my 2017 FB and my 1965 FB.
The 2017 has the device I linked above. I did check and it can have a speed adjustment ratio up to at least 120%. You can also set a fixed offset if say it is 2kmh off across the whole range.
The 1965 has a GPS HUD (amazingly no OBDII port in a 65!). Works very well, but is slower to respond to speed change, and can be compromised by bad weather limiting satellite access (more the better), or if you are driving through a tunnel.  I like the HUD, but it looks ugly from the outside - especially on a 65.
You can get OBDII HUDs as well. Just search eBay.
https://imgur.com/a/nq0G6Uc
« Last Edit: February 06, 2019, 01:16:18 pm by scollist »
Offline JasonK
  • Name: Jason
« Reply #14 on: February 06, 2019, 02:32:14 pm »
 :grin: :grin: :grin: :grin: :grin:
Offline BRUMBE
  • 2017 GT convertible
  • Name: Tim
« Reply #15 on: February 07, 2019, 09:24:35 pm »
My 2017 GT reads about 3 kph slower than actual. I have gone past many police in the highway doing about 107 on 100 zone and 118 in a 110 zone and never been pulled up / fined.
