Distributor Gear ?
Author Topic: Distributor Gear ?  (Read 10026 times)
Offline J.hatzivalsamis
  • Name: jimmy hatziv
Distributor Gear ?
« on: September 12, 2018, 03:33:58 pm »
So I'm using this cam Howards Camshaft 221275-10; Hydraulic Roller 1200-5600 for Ford 221-302/351W SBF on my 302 renegade head roller engine and would like to know what material for gear on distributor before I install, Looking to use my Pertronix II billet dissy which is on my 289. Cheers Jim
Re: Distributor Gear ?
« Reply #1 on: September 12, 2018, 03:44:12 pm »
i only use the crane gear when it fits the dist shaft.
« Reply #2 on: September 13, 2018, 04:12:29 pm »
Barney Thank You for the brand but I was more concerned about the type of metal compatible with this cam. Cheers
« Reply #3 on: September 13, 2018, 04:36:18 pm »
well the crane gear is melonozed . a melonized gear is compatible with all cam materials. this way there is no need to guess what the cam is made out of but that "should" be billet steel. composite and bronze gears are also compatible with billet steel.
« Last Edit: September 13, 2018, 04:38:05 pm by barnett468 »
Offline Fitzy1980
« Reply #4 on: September 14, 2018, 08:47:46 am »
 :agree:
Offline sms777
« Reply #5 on: September 14, 2018, 09:02:20 am »
No hydraulic roller cam is made out of billet steel. Only solid rollers. You can use any good quality steel gear or the new composite one's which I don't trust. Your cam spec card should have it written on it the type of gear recommended. Do not use bronze gear with hydraulic cams.
« Reply #6 on: September 14, 2018, 09:08:59 am »
Mine is  :hi:
« Reply #7 on: September 14, 2018, 09:14:22 am »
No off the shelf HR cam are on steel billet, though custom ones generally are, comp will grind them on a -9 steel billet if you ask. The composite gears are ok but they do break, they are originally made to run in dry sump race engine where there is no oil pump load. Generally off the shelf HR's are made from selectively austempered ductile iron, which is quite hard unike normal cast iron flat tappet cams.
drill a hole in the gallery plug behind the gear and use a melonised steel gear and it will be fine.
« Reply #8 on: September 14, 2018, 10:38:03 am »
As you can see by dwaynes post, some definitely are, but typically they are not.
« Last Edit: September 14, 2018, 10:44:30 am by barnett468 »
« Reply #9 on: September 14, 2018, 10:40:25 am »
...and unfortunately, not all the mfg's that make composite gears state that which hey should.
« Reply #10 on: September 14, 2018, 10:43:14 am »
:agree:
And I bet there is absolutely zero wear on that crane gear i had you get...although the engine probably only has around 12 kilometers on it.  :lmao:
« Reply #11 on: September 14, 2018, 10:51:07 am »
Thanks for the good info now is there a supplier for this melonised gear and are all the distributor shafts the same diameter? Cheers Jim
« Reply #12 on: September 14, 2018, 10:52:40 am »
Here's a billet steel off the shelf ford racing hydraulic roller cam.
https://www.jegs.com/i/Ford-Performance/397/M-6250-C580T/10002/-1
« Reply #13 on: September 14, 2018, 10:53:23 am »
...are all the distributor shafts the same diameter?
 :lmao:
« Reply #14 on: September 14, 2018, 11:48:01 am »
FYI - ALL off the shelf trick flow hydraulic roller cams are made from billet steel cores. It is one of their "claims to fame."
https://www.trickflow.com/search/product-line/trick-flow-track-max-hydraulic-roller-camshafts-for-ford-5-0l/make/ford/engine-size/5-0l-302
« Last Edit: September 14, 2018, 11:50:46 am by barnett468 »
Offline sms777
« Reply #15 on: September 14, 2018, 12:10:25 pm »
:lmao:
Clevelands come in two different dizzy shaft sizes. Maybe that's what hatzi is referring to.
As for billet steel hydraulic roller....it's an overkill and total waste of money. Hydraulic rollers generally only run half the valve spring pressure compared to mechanical so no need to be billet.
« Reply #16 on: September 14, 2018, 12:30:28 pm »
I cant remember exactly but I think its only about $70 option from Comp cams
« Reply #17 on: September 14, 2018, 12:31:25 pm »
MSD
Crane
Comp cams
« Reply #18 on: September 14, 2018, 01:10:21 pm »
ok, lets try it this way;
Is there currently a gear on the distributor?
If so, is it new, lightly used, or heavily used?
« Reply #19 on: September 14, 2018, 01:13:38 pm »
I went thru this finding a gear that would fit fitzy's chinese distributor, and if I recall correctly, the shaft on it was not exactly the same size as a factory ford which is why i posted the little laughing guy in reply to jimmy's question.
« Last Edit: September 14, 2018, 01:18:31 pm by barnett468 »
« Reply #20 on: September 14, 2018, 02:09:16 pm »
It's a lightly used Pertronix II distributor and cannot find what type of gear is on it, whether it is suitable on need to change it. Cheers.
« Reply #21 on: September 14, 2018, 02:15:18 pm »
Okay found out it's steel on the one I have am I good to go or purchase a melonised metal one.??????
Offline sms777
« Reply #22 on: September 14, 2018, 02:35:17 pm »
It is fine to use the way it is.
« Reply #23 on: September 14, 2018, 04:48:05 pm »
Did you drill a hole in the lifter oil galley plug like shaun suggested?
What oil are you using?
Offline Fitzy1980
« Reply #24 on: September 15, 2018, 02:50:07 pm »
To get the distributor to fit just grind the end of the shaft down, works a treat..  :lol:
