AOD to 347
Author Topic: AOD to 347  (Read 3281 times)
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
AOD to 347
« on: August 23, 2018, 09:55:09 am »
One for the tech guys. I have a late model 302 roller engine stroked to 347 which has been set up as a 28oz external balance. My question is do I need to go to a 164 tooth 28oz flexplate or can I stay with the 157 tooth 28oz flexplate to fit the AOD trans im putting in. Too much info out there and i'm getting seriously confused. Cheers.
Re: AOD to 347
« Reply #1 on: August 23, 2018, 10:00:29 am »
You need a 164t 28oz plate.
I'm doing the same thing with my build.
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
Re: AOD to 347
« Reply #2 on: August 23, 2018, 11:06:21 am »
Thanks Dwayne. :thumb:
Offline lukep6470
Re: AOD to 347
« Reply #3 on: August 23, 2018, 04:07:00 pm »
I used a PIONEER PIFRA-205 for mine.  You need to use an FMX compatible one to get the spacing correct.  If not it will push the converter into the pump.
Re: AOD to 347
« Reply #4 on: August 23, 2018, 04:22:29 pm »
Thanks Luke, I wasn't aware I needed and FMX compatible one.
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
Re: AOD to 347
« Reply #5 on: August 23, 2018, 05:40:08 pm »
Thanks Luke. :thumb: I wasn't aware of that.
Re: AOD to 347
« Reply #6 on: August 24, 2018, 06:20:14 pm »
Its just the same a local 351 clevo falcon one.
