289W Matching BTR 4 Speed Confirmation Please
Author Topic: 289W Matching BTR 4 Speed Confirmation Please  (Read 7479 times)
Re: 289W Matching BTR 4 Speed Confirmation Please
« Reply #25 on: July 13, 2018, 01:34:43 pm »
If as you say above the flexplate is from an AU its going to be a 50 ounce one. 289's used a 28 ounce one and there is therefore a 28 ounce balancer on the other end of your engine.
I'll be corrected if I'm wrong but I'm not sure you can just change the balancer to a 50 ounce one as the whole rotating assembly has been set up to have 28 ounces swinging off both ends, not 50. I think you could get your flexplate rebalanced to 28 ounces.
Why does it  need an AU flex plate? why would not use a 28 oz Windsor plate and if you need 164 tooth you just use a Cleveland plate. Thats what I did on an AOD. You can re balance a 50oz plate to 28 however if needs be. like you say you cant fit a 50oz plate to 28oz rotating Assembly its a different crank.  Flex plates are cheap though like $100
« Last Edit: July 13, 2018, 01:36:24 pm by shaunp »
