OUTSIDE TEMPERATURE GAUGE MALFUNCTION
Author Topic: OUTSIDE TEMPERATURE GAUGE MALFUNCTION  (Read 3026 times)
Offline POPS 67
« on: February 07, 2018, 01:58:58 pm »
The outside temperature gauge read out on my 2016 v 8 often malfunctions. It sometimes sticks and doesn't change or other times it's widely inaccurate. I presume this is a faulty sensor? Anyone had this issue? :sick:
I dont suffer from insanity, I enjoy every minute of it.
Offline sms777
Re: OUTSIDE TEMPERATURE GAUGE MALFUNCTION
« Reply #1 on: February 07, 2018, 05:08:56 pm »
I don't know the location of the sensor in the new Mustangs but my BMW used to play up and I found that it was mounted under the front bumper. After a while road grime and dirt will build up on it causing it to misread. After giving it a clean works fine.
Suggest you do the same......
Offline POPS 67
« Reply #2 on: February 07, 2018, 06:02:14 pm »
Thanks I will have a crack tomorrow and see if I can spot it, not much room under though.
Offline Salthorse
  • MOCA (Vic) member - 2709
  • Name: Dave
« Reply #3 on: February 07, 2018, 07:47:17 pm »
It's located on the RHS of the car just inside the lower grille and under the number plate. You can just see it jutting into where the flow of air will pass the sensor.
Dave
1969 Black Jade Mach 1 with a 351C, 3v closed chamber heads, Comp Cams and lifters, FMX trans with 2500 stall converter, LSD, Edelbrock Performer 600 CFM, Sanderson ceramic shorty extractors and Flowmaster American Thunder exhaust.
2016 Deep Impact Blue GT manual with Roush exhaust.
I love it, I need it
I seed it
Eight cylinders all mine
Alright hold tight
I'm a highway star
Deep Purple, “Highway Star” (1971)
