Front alignment
Author Topic: Front alignment  (Read 5511 times)
Offline PONI04
  • Name: Pete
Front alignment
« on: January 18, 2018, 01:13:16 pm »
Can  someone tell me the toe in/toe out specs for a 2004 GT, thanks
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
Re: Front alignment
« Reply #1 on: January 18, 2018, 06:04:58 pm »
Dr Google said this:
This is straight from fords workshop manual
Alignment Specifications — GT and Base ItemLHRHTotal/SplitFrontCaster3.2° ± 0.75°3.2° ± 0.75°0° ± 0.75°Camber-0.50° ± 0.75°-0.50° ± 0.75°0° ± 0.75°Toe (positive value is toe-in, negative value is toe-out)——0.25° ± 0.25°
General Specifications ItemSpecification
Front Ride HeightFront4 mm ± 7.6 mm (0.2 in. ± 0.3 in.)
Rear Ride HeightRear — GT and Base128 mm (5 in.)Rear — Cobra18 mm ± 7.6 mm (1.4 in. ± 0.3 in.)
Vehicle Lean (Side-to-Side Differences)
Front — maximum13 mm (0.5 in.)Rear — maximum13 mm
DogtrackingMaximum13 mm (0.5 in.)Clear vision (negative value is counterclockwise)-2° ± 3°Ball Joint DeflectionLower ball joint0-0.3 mm (0-0.012 in)
From All Ford Mustangs Forum.
Good luck.
Offline PONI04
  • Name: Pete
Re: Front alignment
« Reply #2 on: January 20, 2018, 04:10:17 pm »
Thanks Brett
