67 Coupe - Vapourizer
Author Topic: 67 Coupe - Vapourizer  (Read 22088 times)
Offline aus_67stang
    • Build page on Facebook
  • Name: Steve
Re: 67 Coupe - Vapourizer
« Reply #50 on: May 07, 2018, 08:04:58 pm »
another item off the fabrication list....
Since I have started the amazing job of rewiring the old girl it was time to sort out one part of Mission Control sorted ...
due to some of the changes and fabrication work I am removing the floor mounted wiper / washer pedal and also the high beam button and relocating them to the dash.
From an idea to paper:
and from paper to reality:
« Last Edit: May 07, 2018, 08:06:33 pm by aus_67stang »
Offline Husky350
« Reply #51 on: June 05, 2018, 09:20:14 pm »
That looks awesome. Very professional.  It's easy to add things, but to make them look like they were meant to be there is something else.  Are they Billet Automotive buttons?
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
« Reply #52 on: June 05, 2018, 09:52:24 pm »
Very impressive!
s
Offline aus_67stang
  • Name: Steve
« Reply #53 on: June 05, 2018, 10:04:30 pm »
Thanks Husky, they are Blue Wire Automotive buttons and start kit.. they probably use the same supplier as Billet Automotive  :smile01:
Offline aus_67stang
  • Name: Steve
« Reply #54 on: June 05, 2018, 10:07:25 pm »
Offline aus_67stang
  • Name: Steve
« Reply #55 on: November 25, 2018, 11:53:17 am »
It's been a while since I last posted, work getting in the way of progress but a few things have happened in recent months.
Since the wiring has is mostly sorted it was time to start the sound deadening, every place I and fit my arm has had Car Builders heat & sound deadener installed.
Next stop was the brake and Fuel lines:
Installed the Hoppers Stoppers 8 & 1/2" Booster kit with a Aeroflow bias valve to make sure the balance can be set right.
Fuel lines run down the tunnel to the rear of the car, Aeroflow fuel regulator with the hardline terminating directly on the regulator.
Fitting of the window assemblies are well underway to get it to a sealed state.
« Last Edit: November 25, 2018, 11:57:37 am by aus_67stang »
Offline aus_67stang
  • Name: Steve
« Reply #56 on: December 25, 2018, 11:04:09 pm »
Someones been a good boy this year :)
« Last Edit: December 25, 2018, 11:06:10 pm by aus_67stang »
Offline Husky350
« Reply #57 on: December 26, 2018, 01:47:16 pm »
Nice mate. Dellow bellhousing?
Offline aus_67stang
  • Name: Steve
« Reply #58 on: December 26, 2018, 05:39:37 pm »
Nah, this one is from Castlemaine Rod Shop
Offline aus_67stang
  • Name: Steve
« Reply #59 on: January 12, 2019, 12:29:02 pm »
And after a long separation they are back together  :pepper: :pepper:
« Last Edit: January 12, 2019, 12:32:02 pm by aus_67stang »
