Inability to log on
Author Topic: Inability to log on  (Read 9626 times)
Offline Ausfox
Inability to log on
« on: May 18, 2017, 10:44:21 am »
Normally view from desk top, hence access now.
Using same log in details I have also been using an Ipad for the last year as well.
Have had no problem up till now. Deleted browsing history regularly, as it slows a Crapple product to snails pace and then have just logged on again.
This time, won"t let me log on.
Pop up says "An error has Occurred, your session timed out while posting. please go back and try again".
Sick of trying.
Any suggestions?.
17 SEPT 1964 FASTBACK
1966 Turbo 6Cyl Coupe
1979 INDY PACE CAR
http://s251.photobucket.com/albums/gg310/427gge/Mustang%20Pacecar/
Re: Inability to log on
« Reply #1 on: May 18, 2017, 10:47:37 am »
Yes I have had the same problem for around 3 days ,the same thing . I just go down a little further where it says log in again and that works . I just tried it again and when that happens you will see log in again on the page just press that again to log in .
« Last Edit: May 18, 2017, 10:57:09 am by GLENN 70 »
« Reply #2 on: May 18, 2017, 11:29:02 am »
Is there a 'remember me' box you can tick when logging back in?
Offline peterp
  • Administrator
« Reply #3 on: May 18, 2017, 11:33:37 am »
What browser are you using when you login.
I have always had a problem with Firefox and I think it has something to do with the way it handles java.
Peterp
Offline birdman
  • Name: John
« Reply #4 on: May 19, 2017, 06:32:21 pm »
Likewise on my end. Also noticed on my laptop it states (Not Secure) in the address bar, same with the AMCCA forum. Using windows 10 security up to date and iPad all up to date. Hmmmm  :thud:
Offline birdman
  • Name: John
« Reply #5 on: May 19, 2017, 06:33:10 pm »
Peterp
Peter I'm using Google Chrome never had an issue until a few days ago
Offline birdman
  • Name: John
« Reply #6 on: May 19, 2017, 06:36:33 pm »
Yes that's all working fine just won't log on until the Login pop up shows. Then no problem
Offline birdman
  • Name: John
« Reply #7 on: May 25, 2017, 07:41:30 am »
New log in format. Working fine and the little padlock in the address bar is visible  :thumb:
Offline peterp
  • Administrator
« Reply #8 on: May 25, 2017, 07:43:54 am »
This issue has now been addressed and corrected, we also have a new login button.
We have also applied an SSL Certificate.
The forums correct URL is https://www.mustang.org.au/forum/ although it will still work with http://www.mustang.org.au/forum/ but will not show the green padlock.
Peterp
« Reply #9 on: May 25, 2017, 08:26:37 am »
Thank you Peter P ,it works  :thumb:
Offline birdman
  • Name: John
« Reply #10 on: May 25, 2017, 08:27:15 am »
Peterp
That's great Peter. Also need to address this issue on the AMCCA forum. I've passed this thread onto Vanessa
Offline peterp
  • Administrator
« Reply #11 on: May 25, 2017, 08:34:34 am »
Yes it appears that the last big update patch from SMF took its toll with a lot of SMF forums.
Regards   Peter
