1967 Ford Mustang build.
Author Topic: 1967 Ford Mustang build.  (Read 5283 times)
Offline aussiecbr
« on: March 15, 2017, 05:59:23 pm »
 :flag:G'day guys.
My car is heading to the body shop in late April for a complete modcon resto.
I've chosen the Heidts IFS and IRS.
http://www.heidts.com/part/64-70-mustang-pro-g-front-track-suspension-wide-track/
http://www.heidts.com/part/64-70-mustang-irs-independent-rear-suspension-racing-kit/
I've bought a T56 magnum with a 2.97 first ratio.
Next up I need an engine. I'm split between the following two coyote based engines.
https://performanceparts.ford.com/part/M-6007-A50XS    $22000AUD delivered
http://www.roushperformance.com/engines/50l-coyote-rsc.html   $32000 delivered
I'm leaning towards the XS based on cost to fun ratio. The XS puts out 500HP vs 600HP from Roush. I'm sure with some decent tuning and some small mods I can get 550HP if I wanted for a fraction of the price.
I want some opinions on which one would be more reliable and is the extra $10,000 worth it.
Cheers guys.
York.
Offline Husky350
Re: 1967 Ford Mustang build.
« Reply #1 on: March 15, 2017, 09:47:38 pm »
it's your money so I'm going to tell you to get the roush motor.
However, if it was my money and I wanted more than the 400hp a stock coyote will put out, I would grab a supercharged coyote out of a local FPV. They make well over 500hp stock and with exhaust, tune, injectors and a bit more boost they are making 550hp at the rear wheels of an fpv, so you do the maths.
They pop up on ebay and gumtree for around 15-17g.
But seeing as this will be a 150k+ plus build, money isn't an issue so get the roush brand new.
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« Reply #2 on: June 22, 2018, 02:40:05 pm »
The important message I received from this forum helped me with many basic knowledge.
Bot alert!
Brian
Offline peterp
  • Administrator
« Reply #3 on: June 22, 2018, 03:28:48 pm »
Thanks for the alert.  :thumb:
They are now gone to bother other places in the cloud.
Peter
