Axle offset on a 66 8 inch
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Axle offset on a 66 8 inch (Read 2496 times)
HAMBURGLAR
Worked
I NEED MORE MONEY
Car: 66 A code fastback 6R09A
HAMBURGLAR
on:
June 01, 2016, 05:59:54 pm »
Good evening ladies and gentlemen. Does anyone know the axle offset for a 66 8in. Its said its either 2.5 or 2.66 but I can only get near 2.4 or less without taking the drum brake backing plate off. Would I be correct if I measured from front of axle housing flange to the front of the axle flange. Seems I wouldn't get close to 2.66.
Logged
289 vert
Worked
289 vert
Re: Axle offset on a 66 8 inch
Reply #1 on:
June 09, 2016, 05:46:16 pm »
2 1/2" brake gap
Logged
HAMBURGLAR
Worked
I NEED MORE MONEY
HAMBURGLAR
Reply #2 on:
June 09, 2016, 06:13:10 pm »
Thanks 289vert , I finally took everything off and measured it properly. Fitted the brakes , all good. Cheers.
Logged
Print
Pages: [
1
Go Up
« previous
next »
