Author Topic: Do you have to degree a new cam ?  (Read 489076 times)
« Reply #825 on: March 27, 2016, 06:29:10 pm »
I agree, so lets get back to gay rugby players and lemon party's .  :thumb:
 .  :lmao:
« Reply #826 on: March 27, 2016, 06:33:00 pm »
I know Geoff, and i'm sure there are a lot people viewing this thread thinking "This fuk'n guy"  :lmao: :lmao:
As painful and i'm sure annoying as it's been for everyone, i'm glad i gave it a go myself. I don't like being told i can't do something and that's one thing i always tell my kids. Never let anyone tell you that you can't do or achieve something.
Besides, i still have to get everything else together and more importantly see if it even STARTS !  :thud: :lmao: :lmao:
Mate, no disrespect intended. Unfortunately my sense of humour is never far from the surface. While I have surprised myself with what I have managed to do I have so far drawn the line at getting inside an engine. I am VERY impressed with your having a go at this. I reckon the finish line is in sight.
Offline Fitzy1980
« Reply #827 on: March 27, 2016, 06:33:04 pm »
NO WARRANTEES OR GUARANTEES EXPRESSED OR IMPLIED
 :lmao:
 :lmao:
Kind of used to that now....
« Reply #828 on: March 27, 2016, 06:37:57 pm »
Fitzy we should call you fixie  .  You are doing a fantastic job and giving it a go  :thumb: maybe you and Barnett should get married  :lmao:
Offline Fitzy1980
« Reply #829 on: March 27, 2016, 06:42:36 pm »
None taken buddy.
Kind of scary that this has me buggered but yet i used to work on multi million dollar mining plant.
I had my bosses bluffed there..
 :lmao: :lmao:
Offline Fitzy1980
« Reply #830 on: March 27, 2016, 06:43:32 pm »
He needs to at least take me for dinner first..
  :lmao:
« Reply #831 on: March 27, 2016, 06:56:34 pm »
Sorry but I don't think Cait would want to share me.
I love the way she "fills out" a swim suit . Looks like they didn't do a complete change over!  :lmao:
« Last Edit: March 28, 2016, 07:49:43 am by barnett468 »
Offline Fitzy1980
« Reply #832 on: March 27, 2016, 07:01:22 pm »
Always gotta make things weird ...  :lol:
« Reply #833 on: March 27, 2016, 07:03:19 pm »
  :lmao:
Sorry but the waiting list is pretty long, but maybe I could squeeze you in for a quick "snack".
« Last Edit: March 27, 2016, 07:05:41 pm by barnett468 »
« Reply #834 on: March 28, 2016, 07:45:01 am »
INTAKE INSTALLATION
I use grade 8 bolts, grade 8 flat washers and grade 8 lock washers.
If you want it fancy looking, buy ARP bolts or chrome, black or stainless allen/socket head bolts and AN style flat washers.
Clean the bejesus out of all surfaces with paper towels and cleaner making sure to clean the front of the block and the inside of the valley . This will allow the Permatex to stick to these areas when it gets smushed out by the pressure from the intake..
Clean the bejesus out of it all with paper towels again.
Quickly put contact cement around the intake ports on one head and the side of the gasket that goes to the head.
Put a thin layer of permatex around the water port on the same head and a small blob at the junction where the head meets the block.
Install the gasket carefully . once the glue sticks, the gasket aint gonna move . Press down firmly on the intake area of the gasket, not at the water port.
Quickly put contact cement around the intake ports on the other head and the side of the gasket that goes to the head.
Install the 4 studs in each corner of the heads.
Put a thin layer of Permatex around the water and intake ports on the intake gaskets.
Put a 6 mm bead of Permatex on the front and rear of the block where the end seals would do . Extend it onto the intake gasket by around 3 mm.
Put around a 2 mm thick bead on the intake where the cork seals would go.
Carefully Install the intake . The 4 studs will guide it into place . Sliding it front and back for alignment by very much is not good.
Use the correct torque pattern
Tighten the bolts to 12 lbs.
Retighten to 12 lbs
Tighten to 18 lbs.
Retighten to 18 lbs.
Tighten to 24 lbs.
Tighten to 24 again.
Let dry for 12 hours before use.
Run for 30 minutes.
Tighten bolts to 24 lbs.
« Last Edit: March 28, 2016, 07:48:32 am by barnett468 »
Offline Fitzy1980
« Reply #835 on: March 28, 2016, 10:59:47 am »
The heads have 2 studs in the center, which guide the intake on held down by nuts under the carbs.
By the look of it they should guide the intake on to its correct alignment
Do i still need the 4 studs ?
Offline teacherspet
  • Name: Pete
« Reply #836 on: March 28, 2016, 11:04:57 am »
INTAKE INSTALLATION
Should you be saying "bejesus" during Easter? SINNER!!!! :grin:
Offline teacherspet
  • Name: Pete
« Reply #837 on: March 28, 2016, 11:21:36 am »
.....& on the next exciting instalment of "Do you have to degree a new cam", will Barnett be struck by lightning & have his Easter eggs confiscated for saying the word "bejesus" twice in the one sentence, will Fitzy & Barnett finally tie the knot after a deep & meaningful conversation about camshafts & gay rugby players over a candle lit romantic dinner, & will Caitlyn Jenner be the surprise bridesmaid for the wedding? Stay tuned for this & lots more!  :lmao:
« Last Edit: March 28, 2016, 11:35:54 am by teacherspet »
« Reply #838 on: March 28, 2016, 12:11:54 pm »
t doesn't apply to me cuz I'm a Scientologist .  :lmao:
« Reply #839 on: March 28, 2016, 12:14:13 pm »
...and will Cait ever have the last operation that will finally bring him...her...it to its dream of being a "complete" Woman where it can finally begin sticking one of these in the CORRECT location?
« Last Edit: March 28, 2016, 12:20:12 pm by barnett468 »
Offline Fitzy1980
« Reply #840 on: March 28, 2016, 12:23:44 pm »
Well.... this thread just hit rock bottom  :thud:
 :lmao:
« Reply #841 on: March 28, 2016, 12:26:46 pm »
The heads have 2 studs in the center, which guide the intake on held down by nuts under the carbs. By the look of it they should guide the intake on to its correct alignment
Only if you're lonely .   :bolt:
« Last Edit: March 28, 2016, 12:32:30 pm by barnett468 »
« Reply #842 on: March 28, 2016, 12:30:02 pm »
 :lmao:
Not even close yet .  :lmao:
« Reply #843 on: March 28, 2016, 12:32:06 pm »
Hey, 8,206 disturbed people have now viewed YOUR thread.  :thumb:
Offline Fitzy1980
« Reply #844 on: March 28, 2016, 05:20:26 pm »
These are the numbers engraved on the Schnausage cam.
52951
274 r -10
Below is what i received on email from Schneider.
274-R
274 duration
230 @ .050"
..620" lift with 1.7 rocker
.020" lash int. & exh. hot
110 lobe center
« Reply #845 on: March 28, 2016, 05:39:39 pm »
ok, i will see what they say tomorrow
Offline Fitzy1980
« Reply #846 on: March 28, 2016, 05:57:45 pm »
Awesome, thanks mate.
Didn't get the intake on today, ill do that tomorrow.
Thought i'd give you the day off.  :lmao: :lmao:
« Reply #847 on: March 28, 2016, 06:04:13 pm »
 :lmao:
HEY, DID IT HAVE A MILD OR KIND OF NASTY IDLE BEFORE WHEN YOU FIRST GOT IT?
WHAT IS YOUR ROCKER RATIO?
« Last Edit: March 28, 2016, 06:22:49 pm by barnett468 »
Offline teacherspet
  • Name: Pete
« Reply #848 on: March 28, 2016, 06:35:02 pm »
So, do you have to degree one of these once inserted?
« Reply #849 on: March 28, 2016, 06:52:42 pm »
i will have to read the instruction manual and get back to you on that.
