Author Topic: Do you have to degree a new cam ?  (Read 488280 times)
« Reply #725 on: March 26, 2016, 01:37:09 pm »
True..  :lol:
Going off the pointer its around the 270 mark, whats happened there ?
Rotate it around to 0 ?
It's only a few degrees off the original TDC mark from the original build ?
what?
you cant be at 270 and tdc at the same time.
rotate to the tdc mark in the direction that is closest to it.
« Reply #726 on: March 26, 2016, 01:38:46 pm »
after that look at the left front lifters, they should both as low as they can be in the bores.
Offline Fitzy1980
« Reply #727 on: March 26, 2016, 01:45:35 pm »
Sorry, i meant the pointer is only a few degrees off where the builder had TDC marked.
I thought we set it at 0, so i assumed the damper would go back on it would be at 0
Fuk'd if i know. But yes the first 2 lifters are at there lowest from what i can tell
« Reply #728 on: March 26, 2016, 01:50:17 pm »
the number 1 piston is at tdc when the crank key is straight up.
you may have the wrong damper.
what side is your pointer on?
what brand is your damper?
can you post a photo?
you may need to take the bolt back out ad put the key straight up then take a photo of the timing marks.
if we dont get this right it will be very bad.
Offline Fitzy1980
« Reply #729 on: March 26, 2016, 01:54:49 pm »
2016-03-26_01-51-40 by , on Flickr
2016-03-26_01-52-05 by , on Flickr
Black mark is the original mark for TDC by the builder
Offline Fitzy1980
« Reply #730 on: March 26, 2016, 01:57:33 pm »
See pic
Romac
Key was straight up when i put it on, may have moved a little when tightening it but not much
« Reply #731 on: March 26, 2016, 01:59:16 pm »
son of a f'n btch
« Reply #732 on: March 26, 2016, 02:02:38 pm »
which color are your marks?
Offline Fitzy1980
« Reply #733 on: March 26, 2016, 02:03:52 pm »
son of a f'n btch
That's what i do not want to hear.
If i have to pull this apart, it's not happening. Fukn thing can sit there and rust away..
Offline Fitzy1980
« Reply #734 on: March 26, 2016, 02:04:48 pm »
Mine are the white marks, measured the damper spaced out 4 times starting at 0
The 32 degree mark is there mark
« Reply #735 on: March 26, 2016, 02:05:34 pm »
ok, i got it . back in a minute
Offline Fitzy1980
« Reply #736 on: March 26, 2016, 02:12:14 pm »
2016-03-26_02-09-55 by , on Flickr
No 1
« Reply #737 on: March 26, 2016, 02:16:51 pm »
the black mark is top dead center on the 260 degree line . rotate the crank counter clockwise 5 degrees so it lines up with pointer.
1-3-7-2-6-5-4-8
adjust the valves on 1.
rotate clockwise to 170 adjust 3
rotate clockwise to 80  adjust 7
rotate to 350 adjust 2
rotate to 260 do 6
rotate 170 do 5
rotate 80 do 4
rotate 350 do 8
rotate 260 . this is tdc . recheck the valves on 1.
« Reply #738 on: March 26, 2016, 02:17:50 pm »
please don't show us your snausage bits.
« Reply #739 on: March 26, 2016, 02:18:57 pm »
remove your white marks, they are now useless.
put new ones on at the numbers i mentioned.
« Last Edit: March 26, 2016, 02:28:04 pm by barnett468 »
« Reply #740 on: March 26, 2016, 02:26:51 pm »
We can install the intake after this . wheee!  :pepper:
Offline Fitzy1980
« Reply #741 on: March 26, 2016, 02:27:23 pm »
 :ouch: :ouch:
Who the fuk would do this for a living....  :lmao: :lmao:
« Reply #742 on: March 26, 2016, 02:28:52 pm »
:ouch: :ouch:
obviously not your engine builder .  :lmao:
Offline Fitzy1980
« Reply #743 on: March 26, 2016, 02:31:53 pm »
 :lmao:
Ok, so im on the same page.
Rods in, rockers on.
torque the rockers down at the shaft, 25 ft lbs ??
Wind internal screw down till it stops,  then out 1 turn.
« Last Edit: March 26, 2016, 02:35:36 pm by Fitzy1980 »
« Reply #744 on: March 26, 2016, 02:34:42 pm »
install each pair of rockers when you get to the correct cylinder then set the proper clearance now as per the cam card
Offline Fitzy1980
« Reply #745 on: March 26, 2016, 02:36:16 pm »
install each pair of rockers when you get to the correct cylinder.
0.22 hot, should it be tighter cold ?
« Reply #746 on: March 26, 2016, 02:39:31 pm »
back in a f'n minute  :thud:
it should have given a cold spec . i will look.
what is your cam number?
« Reply #747 on: March 26, 2016, 02:42:12 pm »
do you have a blow dryer to heat them up with?  :lmao:
Offline Fitzy1980
« Reply #748 on: March 26, 2016, 02:46:37 pm »
220183-10
just has running clearance (hot)
« Reply #749 on: March 26, 2016, 02:54:05 pm »
post a photo that makes no sense.
hey, that's a nice cam, who suggested that one?
set them .002" TIGHTER than they suggest.
put the feeler gauge between the rocker and valve
tighten screw until it requires a slight force to remove the gauge
hold the screw as you tighten the nut.
recheck the clearance.
the adjustment needs to be very close but not 110% perfect .001" off is ok.
« Last Edit: March 26, 2016, 03:24:40 pm by barnett468 »
