Author Topic: Do you have to degree a new cam ?  (Read 488621 times)
« Reply #625 on: March 22, 2016, 07:46:47 pm »
maybe you should have bought a $4000.00 one them .  :lmao:
« Reply #626 on: March 22, 2016, 07:47:12 pm »
Came on Barnett help him out here .
« Reply #627 on: March 22, 2016, 07:51:15 pm »
I did, i pm'd him and told him to simply put his gear in the oven at 985 f for around 10 minutes and it should slip right on .  :lmao:
« Reply #628 on: March 22, 2016, 07:52:44 pm »
I also asked him to measure the old gear and the new one but he said he can't but I will let him tell you why .  :lmao:
« Reply #629 on: March 22, 2016, 07:54:01 pm »
I bet that $3000.00 to have someone else do this is lookin pretty good to him right about now.   :lmao:
« Reply #630 on: March 22, 2016, 07:55:56 pm »
Do you guys have an emergency number to dial in case someone has a stroke?  :lmao:
Offline Fitzy1980
« Reply #631 on: March 22, 2016, 08:24:46 pm »
I told you, ill swing by the local crematorium in the morning to borrow one of there ovens for 10-15.
« Reply #632 on: March 22, 2016, 08:27:38 pm »
You might have to share the oven.  :lmao:
Offline Fitzy1980
« Reply #633 on: March 22, 2016, 08:29:47 pm »
what crank is it exactly?
Callies Magnum from memory
« Reply #634 on: March 22, 2016, 08:41:26 pm »
ok, so your american crank is crap, or your aussie gear is . they might have honed the other gear out to get it on.
« Reply #635 on: March 22, 2016, 09:35:35 pm »
Callies are good cranks, make no mistake, Is it a Compstar perhaps?
« Reply #636 on: March 23, 2016, 04:51:36 am »
Shaun, his old roll master crank gear came off fairly easy . his new one won't go on . he cant measure the gears because he broke his calipers.
Offline Fitzy1980
« Reply #637 on: March 23, 2016, 08:09:51 am »
I remember seeing Magnum on some paperwork way back. Was probably over kill.
« Reply #638 on: March 23, 2016, 08:16:16 am »
yeah, it has bigger journals which is why your gear doesn't fit .  :lmao:
did your calipers fix themselves yet .  :lmao: :lmao: :lmao:
Offline Fitzy1980
« Reply #639 on: March 23, 2016, 08:16:59 am »
The other crank gear was tight, i used a puller to squeeze it off.
This one goes on till about the crank key then gets tight, it moves a couple of mm if i tap it but i don't want to cause damage to the gear or chain.
« Reply #640 on: March 23, 2016, 08:35:55 am »
ok, you said sledge hammer.
remove the gear.
inspect the crank AND key CLOSELY for even a tiny flaw and fix it with a fine file if you see one.
Take some 280 grit wet/dry sandpaper and water or wd40 and sand the inside of the gear heavily . this will smooth any little machining burs or ridges etc.
put the gear in the oven at 300 f for 15 minutes.
put assembly oil on the crank.
install the gear with ease.
« Last Edit: March 23, 2016, 08:38:43 am by barnett468 »
Offline Fitzy1980
« Reply #641 on: March 23, 2016, 08:39:34 am »
remove the gear.
inspect the crank AND key CLOSELY for even a tiny flaw and fix it if you see one.
Well, i figured it would be tight but taping it 10 times to move it a mm or so seemed a bit extreme.
« Reply #642 on: March 23, 2016, 08:50:14 am »
yes, it is . do what i said and it will go right on.
« Reply #643 on: March 23, 2016, 04:03:18 pm »
Offline Fitzy1980
« Reply #644 on: March 23, 2016, 06:24:11 pm »
Yes, i need to cut them..
 :lmao:
And i need to wet sand the gear a heap more, it fits a little easier but is still very tight. With no movement at the bottom it's impossible to get enough play to fit the top gear on the cam.
« Last Edit: March 23, 2016, 06:29:15 pm by Fitzy1980 »
« Reply #645 on: March 23, 2016, 07:07:20 pm »
you didn't put it in the oven did you?
more sanding won't hurt
Offline Fitzy1980
« Reply #646 on: March 23, 2016, 07:27:35 pm »
Yes, yes i did...
« Reply #647 on: March 24, 2016, 04:11:30 am »
Yes, yes i did...
no you didn't .  :lmao:
clean your pan before you install the gear.
« Reply #648 on: March 24, 2016, 07:09:19 am »
Ok, another day, another drama . PLEEEASE tell us you didn't touch anything yet.
I think you need a guardian .  :lmao:
Offline Fitzy1980
« Reply #649 on: March 24, 2016, 09:33:31 am »
What now ?
