Author Topic: Do you have to degree a new cam ?  (Read 488483 times)
Offline Fitzy1980
« Reply #600 on: March 21, 2016, 08:47:45 am »
Xlint.
Found a bloke with a small machine shop that will happily drill the distributor and gear for me for free over the next couple of days.
« Reply #601 on: March 21, 2016, 09:25:02 am »
Xlint.
That's all fine and dandy AFTER you punch the shaft then install the gear then check it as i suggested.
Also, it must be drilled with the gear on it and it must be drilled with a 1/8" bit . I guarantee you with 110% certainty that if he uses a metric bit, you will in fact be buying another new $350.00 distributor and $100.00 gear.
If you remove the gear, i will ruining the punching.
Again, you can not cut corners on this.
« Last Edit: March 21, 2016, 09:37:55 am by barnett468 »
Offline Fitzy1980
« Reply #602 on: March 21, 2016, 01:50:06 pm »
I explained it all to him and he knew what i was talking about. He said he'll pin it for me also.
I'll set the gear today, check the mesh and clearances again and take it to him.
« Reply #603 on: March 21, 2016, 01:54:59 pm »
so he has a hardened roll pin?
this should be interesting!
we'll be waiting for photos in a while.
« Last Edit: March 21, 2016, 01:56:37 pm by barnett468 »
Offline Fitzy1980
« Reply #604 on: March 21, 2016, 02:08:04 pm »
Apparently.
I explained it all to him and he said no worries, has done it before.
Has a smaller mill he'll drill it with, more accurate apparently.
I remember you asked about the difference between the stock steel gear and the crane. Can easily see the difference between them, the Crane is so much smoother. I can feel the sharp edges on the stock one whereas on the Crane, nothing. Just visually it looks so much better.
« Last Edit: March 21, 2016, 02:22:16 pm by Fitzy1980 »
« Reply #605 on: March 21, 2016, 03:08:02 pm »
xlnt...see, i told ya so . that crane gear is killer.
« Reply #606 on: March 22, 2016, 01:47:54 pm »
Ok, got your message . Now we all want to see this fancy ass gear with the pin actually installed.  :toetapping:
Still could have drilled it yourself for only $10.00 aud ya chicken.  :therethere:
« Last Edit: March 22, 2016, 01:55:34 pm by barnett468 »
Offline Fitzy1980
« Reply #607 on: March 22, 2016, 02:18:30 pm »
Glenn, you ok ?
 :lmao: :lmao: :lmao:
Offline Fitzy1980
« Reply #608 on: March 22, 2016, 02:20:38 pm »
I could have, but that's 2 schooners at the pub this afternoon  :cheers:
« Reply #609 on: March 22, 2016, 03:05:16 pm »
Glenn, you ok ?
I think he's still trying to get his computer screen clean.
Offline Fitzy1980
« Reply #610 on: March 22, 2016, 03:45:29 pm »
With fire.. :lmao:
« Reply #611 on: March 22, 2016, 03:58:51 pm »
With fire.. :lmao:
Probably so if the disinfectant doesn't work.
« Reply #612 on: March 22, 2016, 04:10:31 pm »
What are you clowns on about ?
Offline Fitzy1980
« Reply #613 on: March 22, 2016, 04:23:48 pm »
Your little google search the other day...  :lmao:
Don't forget to clear the browser history mate, might raise a few questions at home...  :grin:
« Reply #614 on: March 22, 2016, 04:26:48 pm »
Oh, my, I hope we haven't brought back that horrible memory for him .  :lmao:
« Reply #615 on: March 22, 2016, 04:29:07 pm »
Can you get a virus downloading that type of stuff or just a mild yeast infection?
Offline Fitzy1980
« Reply #616 on: March 22, 2016, 06:37:45 pm »
Any advice on getting the lower timing gear on without a sledge hammer  :lmao:
It's super tight before its even engaged the keyway. And i dont want to damage the chain.
« Reply #617 on: March 22, 2016, 06:52:48 pm »
Nothing from me about this anymore . :thumb:
« Reply #618 on: March 22, 2016, 07:17:06 pm »
ummm, well, yeah, when you take your distributor to your machinist friend, just take the gear with you so he can hone it our around .0005" because the nose on your crank is too large because it is Chinese .  :lmao:
...and no, im not kidding .  :lmao:
« Last Edit: March 22, 2016, 07:18:59 pm by barnett468 »
« Reply #619 on: March 22, 2016, 07:21:19 pm »
what do you expect for only $18,000.00
 :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao:
 :lmao:
« Reply #620 on: March 22, 2016, 07:24:23 pm »
Hey GLENN, how's your $8,000.00 engine running? . I hear you've only had it going for around 5 years or so!
« Reply #621 on: March 22, 2016, 07:30:39 pm »
Hey, if you have one of these you can simply trim down the crank some.
SURVEY
Has this information been useful to you?
a. Yes
b. Absolutely
c. No doubt about it!
« Reply #622 on: March 22, 2016, 07:35:22 pm »
About 6 years and what $8,000 ,not that much mate . :lmao:
Offline Fitzy1980
« Reply #623 on: March 22, 2016, 07:37:56 pm »
Chinese ?
It's something like a $2,500 crank...  :thud:
« Reply #624 on: March 22, 2016, 07:45:39 pm »
Chinese ?
what crank is it exactly?
