Author Topic: Do you have to degree a new cam ?  (Read 488490 times)
Offline lukep6470
« Reply #450 on: March 02, 2016, 12:49:01 pm »
The MSD is a different shape around the non critical bits, that why it snuck past.
« Reply #451 on: March 02, 2016, 02:02:13 pm »
xlnt.
Offline Fitzy1980
« Reply #452 on: March 15, 2016, 10:23:10 am »
Knock on the door this morning, it was like xmas  :pepper: :pepper:
2016-03-15_10-06-30 by peter FITZPATRICK, on Flickr
« Reply #453 on: March 15, 2016, 04:12:53 pm »
that is too dark . please post a better photo.
« Reply #454 on: March 16, 2016, 11:44:56 am »
GET THE LONG BOLT TO INSTALL THE CAM WITH
CHECK THE CAM END PLAY THE WAY I DESCRIBED
Offline Fitzy1980
« Reply #455 on: March 17, 2016, 11:51:52 am »
All parts have arrived......   :evilone:
I want another 20 pages on this thread by the end of the weekend....  :lol:
« Reply #456 on: March 17, 2016, 12:08:23 pm »
xlnt, now...the end of the cam with the threaded hole goes in last .  :lmao:
« Reply #457 on: March 17, 2016, 12:09:57 pm »
...and the gear goes on the end of the cam.  :hi:
« Reply #458 on: March 17, 2016, 12:10:49 pm »
Well is it in yet?  :bolt:
Offline Fitzy1980
« Reply #459 on: March 17, 2016, 12:11:32 pm »
Now, now...  :toetapping:
MEASURE THE VERY END OF THE DISTRIBUTOR SHAFT THAT GOES IN THE HOLE IN THE BLOCK
MEASURE IT 25 MM UP FROM THE BOTTOM.
And ????
The new gear slides on a little tighter than the old one but i could still do it by hand though
Offline Fitzy1980
« Reply #460 on: March 17, 2016, 12:15:06 pm »
Well is it in yet?
Funny, i was asked the same thing by my wife the other day after one to many drinks ?  :wtf:
 :lmao: :lmao: :lmao: :lmao:
« Reply #461 on: March 17, 2016, 12:16:17 pm »
And ????
Hey, at least it will be easy to install.  :lmao:
« Reply #462 on: March 17, 2016, 12:18:08 pm »
guess you'll be lookin fur a machine shop.
there is another way to fix it but but it is kinda tricky.
just stuff your cam in for now, we'll deal with distributor after the cam is in.
do NOT install the cam gear.
DID YOU DRILL THE HOLES IN THE GALLEY PLUGS YET?
« Last Edit: March 17, 2016, 12:21:21 pm by barnett468 »
Offline Fitzy1980
« Reply #463 on: March 17, 2016, 12:20:33 pm »
FFS !! :cry:
Righto,
Whats the other way ?
« Reply #464 on: March 17, 2016, 12:52:06 pm »
FFS !! :cry:
Righto,
You need a small, very sharp punch . a 2 x 4 and a hammer . and a lot of skill or luck.
your shaft has 3 steps, if you have a punch, lay the distributor on its side on a rag then shim the shaft up until it is parallel to the work bench, then whack the middle step ABOVE where the top of the gear would g as a test the post a photo of it.
Offline Fitzy1980
« Reply #465 on: March 17, 2016, 12:59:41 pm »
ok,
Is the punch facing straight down or at an angle to lift the metal as i assume this is what we are hoping to do
Offline Fitzy1980
« Reply #466 on: March 17, 2016, 01:11:53 pm »
Cam is in, no stingy lube job either  :lol:
Found it easier to get back in than out.
« Reply #467 on: March 17, 2016, 01:20:17 pm »
xlnt, and i told you it would be easier to get back in than out . you are on the downhill run now . i told ya you could do it :thumb:
do NOT punch it at an angle.
hit it with light force at first . it only needs to raise it a tiny bit because you will be punching it maybe 20 times if this works . if your shaft is hard it might not work.
...ok, this is starting to sound a little gay.
« Last Edit: March 17, 2016, 01:25:50 pm by barnett468 »
Offline Fitzy1980
« Reply #468 on: March 17, 2016, 01:36:27 pm »
Yes, very gay..
" Not that there is anything wrong with that"
Punch works well.
Where am i punching it in relation to the gear and roll pin hole ?
« Reply #469 on: March 17, 2016, 01:36:42 pm »
punch it one time where i told you then post a photo . it you punch it too hard, the gear will not go on and you will have to file a little.
the distributor s the most difficult part and i have been avoiding it like the plague.
« Last Edit: March 17, 2016, 01:39:19 pm by barnett468 »
Offline Fitzy1980
« Reply #470 on: March 17, 2016, 01:44:16 pm »
I can't get a decent photo where you can see it clear enough.
But the gear does catch on it pretty well so with 20 or so it will definitely be a tight fit.
« Reply #471 on: March 17, 2016, 01:54:19 pm »
ok, put a punch mark between the pin holes, then clamp the end of the shaft that is closest to the distributor in a vice but put a rag around the shaft.
put some assembly lube on the part that the gear will be then install the gear to around the same distance the other one was
next you will install the distributor WITHOUT the clamp but push it down until it is seated.
next try to put your thinnest feeler gauge between the gear and the block . then push down lightly on the top of the shaft then try to remove the feeler gauge.
you want the gear so it is around .005" from the block but because your block pad is now grooved, this will be hard to measure.
after this, you can install the front cam gear and barely tighten the bolt, then put white grease on the dist gear and install it then rotate the cam one full turn then post a photo of the dist gear.
NEVER EVER BEAT ON THE SHAFT UNLESS IT IS IN A VICE OTHERWISE YOU WILL INSTANTLY RUIN THE DISTRIBUTOR BEARINGS
« Last Edit: March 17, 2016, 01:57:12 pm by barnett468 »
Offline Fitzy1980
« Reply #472 on: March 17, 2016, 02:20:00 pm »
Installed the gear to spot on with the roll pin hole. Clearance is around .005 but as you said the pad isn't exactly flat as there is a small lip on the outside so the feel gauge goes in on a very slight angle which obviously makes it a bit touch and go.
I'll have to go and get some white grease. Did have some but i cant find it
« Reply #473 on: March 17, 2016, 02:30:58 pm »
do you have any liguid white out or white or yellow spray paint?
Offline Fitzy1980
« Reply #474 on: March 17, 2016, 02:59:07 pm »
Yeah, do you just want the paint on the raised gear area or the whole thing ?  :lol:
