Author Topic: Do you have to degree a new cam ?  (Read 488508 times)
« Reply #425 on: February 28, 2016, 06:20:06 pm »
.001 you could just put it in the oven, for 20 min, put the shaft in dry ice will slide straight on
 Barrent things cost more because the minimum wage is higher. Min wage here is about $18, just to flip burgers. Shops can be held responsible but you have to take them to small claims court, not worth the effort. Suck it up and move on. Any decent shop will be charging well over $100 an hour. Not to mention the local importer of parts rape you as well. In real terms it probably works out the same all considered. Particularly if you consider our health care and subsidized pharmaceuticals, government provided old age pension etc.  Also as an employer you have to pay about 9% on top of the wages into a government approved superannuation fund for the employ. When I worked for Telstra they paid 18% I think its all relative, and you dont have to worry about the company going broke and running off with your money.
« Last Edit: February 28, 2016, 06:30:13 pm by shaunp »
« Reply #426 on: February 28, 2016, 06:54:05 pm »
shaun, i based the $1600.00 at 16 hours at $100.00 an hour and we have to pay 35% of the employees wages.
if we pay a guy $10.00 an hour, we have to pay the gov $3.50.00 so we pay $13.50. we pay a guy $1,000.00 we pay an additional $350.00 so we actually pay $1350.00.
« Reply #427 on: February 28, 2016, 07:04:16 pm »
what it looks like is that msd makes an off size of .468 so you have to use their gears . the crane gear size is more common.
the melonized gears can not be heated over maybe 400 degrees or it will damage the coating and an additional .001 of interference may be too much to overcome.
« Last Edit: February 28, 2016, 07:06:03 pm by barnett468 »
« Reply #428 on: February 28, 2016, 07:19:38 pm »
Fitzy, my plan is to have at least .002" - .003" clearance between the gear and the block and then check gear mesh at that point and if the gear needs to go up, just move it up until it's happy.
you can not do this on a stock ford distributor because they do not use ball bearings, however, chevy has been doing this since they first started making the V8 and possibly since before that and you can do the same thing with any bal bearing distributor which your msd and some others are.
Offline Fitzy1980
« Reply #429 on: February 28, 2016, 07:23:32 pm »
Right, so looks like its MSD steel gear then.
What if anything do i do about the butchered shaft ? Will it effect anything ? If it will, ill have to find out if they can replace the shaft.
Failing that, new f'n distributor i'd say.
I'm going to phone the builder tomorrow regardless and try and get some answer as to why anyone there would do that.
It also looks like its been ground on the bottom as well, so i can only assume the shaft has been shortened also.
Is it also normal to cut and grind the vacuum advance canister off as well ?
« Reply #430 on: February 28, 2016, 07:34:26 pm »
I already said i wouldn't do that but do whatever you want.
we need more photos and the photo with the felt pen on it . you only photod one side.
see answer above
we will see.
we will see.
also tell them the gear was too low on the shaft and this caused it to bind and you want them to pay for the parts.
how special . send them photos and a bill for $1000.00 in parts.
You gotta be F###in kidding . and this guy is one of the better race engine builders . my fkn grandma could do a better job and shes blind almost blind.
i would hate to see what a shitty engine builders engine looks like. .  :lmao:
« Last Edit: February 28, 2016, 07:42:00 pm by barnett468 »
Offline Fitzy1980
« Reply #431 on: February 28, 2016, 07:41:51 pm »
Well at least that's a start, sounds good to me.
Should i start a new thread for that or keep with this one ?  :lol:
Might have to break out the  :nopity: otherwise.  :lmao:
Offline Fitzy1980
« Reply #432 on: February 28, 2016, 07:43:26 pm »
see answer above
we will see.
we will see.
It has the lockout fitted but there is all these grind marks near it and on the distributor housing
« Last Edit: February 28, 2016, 07:54:46 pm by Fitzy1980 »
« Reply #433 on: February 28, 2016, 07:54:14 pm »
Oh i didn't tell ya's about the vacuum canister ?  :lmao: :lmao: :lmao:
 :cry:
« Reply #434 on: February 28, 2016, 07:55:33 pm »
They  have ground bottom face because it was hitting the clip that stops the drive shaft, coming out. I assume it has an arp pump drive? You often you often have to move the clip down a bit just to get the shaft in.
Offline Fitzy1980
« Reply #435 on: February 28, 2016, 07:59:17 pm »
I didn't notice this till recently.
I understand things have to modified etc.
Looks like my 5 yr old went to town with a Dremel.
« Reply #436 on: February 28, 2016, 08:01:17 pm »
no ya don't, ya can just grind the bottom of the dizzy down cuz thats obviously what the "professionals" do .  :lmao:
« Reply #437 on: February 28, 2016, 08:05:04 pm »
OMG...pleeeease stop, I think I just peed my pants!
« Reply #438 on: February 28, 2016, 08:07:04 pm »
............. Man, this is way better than watchin GLENN Lawn Bowl!
« Last Edit: February 28, 2016, 08:12:00 pm by barnett468 »
« Reply #439 on: February 28, 2016, 08:28:31 pm »
Hell, even this Chinese one would fit better!
« Last Edit: February 28, 2016, 08:30:43 pm by barnett468 »
« Reply #440 on: February 28, 2016, 08:56:27 pm »
Why didnt they just buy a pro billet without vac advance they come either way.
Offline Fitzy1980
« Reply #441 on: February 28, 2016, 09:18:29 pm »
Why when they can just do a hatchet job on the one they had.
It's "custom" made  :lmao:
Seriously it's lucky i have a sense of humor about all this.
« Last Edit: February 28, 2016, 09:20:36 pm by Fitzy1980 »
« Reply #442 on: February 28, 2016, 09:39:19 pm »
And those are just some of the extra, special touches you get when you pay $18,000.00 for a "custom", "high performance" engine.
 .  :lmao:
« Last Edit: February 28, 2016, 09:41:52 pm by barnett468 »
« Reply #443 on: February 28, 2016, 09:40:44 pm »
oh...by the way...will you be taking your $90,000.00 Landcruiser to pick up parts in...or the rental?
OMG...there goes my spleen!
« Last Edit: February 28, 2016, 09:44:33 pm by barnett468 »
« Reply #444 on: February 29, 2016, 05:12:15 am »
WHAT IS THE EXACT DIAMETER OF YOUR DISTRIBUTOR SHAFT BELOW THE GEAR?
WHAT IS THE DIAMETER OF THE RAISED PAD ON THE BOTTOM OF THE GEAR?
I forgot to mention, that chinese distributor has a, 500" gear shaft and Crane just happens to make a .500" gear...hmmm.
http://www.summitracing.com/parts/crn-36971-1/overview/
« Last Edit: February 29, 2016, 07:13:00 am by barnett468 »
« Reply #445 on: February 29, 2016, 06:07:54 pm »
You can buy this or call Summit and buy it direct . Ask if shipping to oz is free if you buy it thru Ebay and ask about shipping time.
Shaft size is .467 so the Crane gear will fit.
Ebay Pertronix p/n D130810 polished black HEI cap . $225.00 usd . $314.00 aud.
http://www.ebay.com.au/itm/PerTronix-Distributor-D131810-/331724858510?hash=item4d3c57a48e:g:AOUAAOSwHQ9WYeY0
Ebay Pertronix p/n D130811 polished red HEI cap . $225.00 usd . $314.00 aud.
http://www.ebay.com.au/itm/PerTronix-Distributor-D131811-/331724858505?hash=item4d3c57a489:g:TBMAAOSw8-tWYeZo
Summit Pertronix p/n D130810 polished black HEI cap . $254.00 usd . This price should be $225.00 usd
http://www.summitracing.com/parts/pnx-d130810/overview/make/ford
Summit Pertronix p/n D130811 polished red HEI cap . $225.00 usd . $314.00 aud.
http://www.summitracing.com/parts/pnx-d130811/overview/make/ford
Ebay Crane p/n 360970-1 .467 melonized steel gear . $80.00 usd . $111.00 aud
http://www.ebay.com.au/itm/36970-1-Crane-Cams-369701-Crane-Steel-Distributor-Magneto-Drive-Gear-/181789517385?hash=item2a537fe649:g:ncQAAOSwLVZVktfe
Summit Crane p/n 360970-1 .467 melonized steel gear . $72.00 . $101.00
http://www.summitracing.com/parts/crn-36970-1/overview/make/ford
« Reply #446 on: February 29, 2016, 09:40:43 pm »
I got some new pro billets here Ill measure one, and a Mallory comp 42 which is steel gear brand new, But its been ratted for the module and cap, your if you want it.
« Last Edit: February 29, 2016, 09:44:07 pm by shaunp »
« Reply #447 on: March 01, 2016, 10:27:08 am »
CAMSHAFT
Here's the cam in stock on their shelf and it is $30.00 less than Summit and they will ship it direct to you . Shipping cost might be $60.00 unless you want 3 day air.
Make sure this is the same cam number i gave you before.
They have a toll free number but it will not work from oz . call 920-233-1176 in your morning and ask for Eric.
http://www.competitionproducts.com/Howards-Mechanical-Roller-Camshaft-Ford-SB-221-302-351W/productinfo/220183-10/#.VtTO9ub4NLM
I called Howards and they said both of their cam machines broke 6 weeks ago but should have them fixed soon, lol.
CRANE CAM GEAR
Here is a list of Crane dealers in oz . Call and ask if they have the gear in their shop . Ask if it comes with a roll pin.
http://www.cranecams.com.au/index.php/where-to-buy
Crane p/n 36970-1
Snausage actually has one in stock.
« Last Edit: March 01, 2016, 11:16:23 am by barnett468 »
Offline lukep6470
« Reply #448 on: March 01, 2016, 02:31:22 pm »
WRT the dizzy.  Remember he has to clear quad webers with it.  It will have to be a small dia cap distributor.
I'm not sure why the base of your old one was butchered like that.
BTW what block do you have.  My Dart SHP had a grub in the oil passage that hit a stock distributor but a MSD billet cleared fine.
« Reply #449 on: March 01, 2016, 03:51:55 pm »
This means the MSD was improperly designed.
