Author Topic: Do you have to degree a new cam ?  (Read 490298 times)
« Reply #1675 on: June 04, 2016, 02:07:42 pm »
...deep seeded...
Wow, that sounds like fun.  :thumb:
Offline Fitzy1980
« Reply #1676 on: June 04, 2016, 02:12:05 pm »
Dunno what sort of shifter that is but it looks the whole mechanism is pivoting backwards and forwards rather than the lever moving.
Hurst.
« Reply #1677 on: June 04, 2016, 02:16:18 pm »
the shift box that bolts to the trans is loose just like your rod and main bolts probably are.   :thumb:
where the fk did you find these clowns.  :lmao:
try this but it may not work.
put the shifter i neutral
center the shift handle in the hole
tighten the bolts on the side of the shifter housing.
try it out
« Reply #1678 on: June 04, 2016, 02:16:56 pm »
Offline Fitzy1980
« Reply #1679 on: June 04, 2016, 02:39:16 pm »
try it out
I'll give it a crack
I know everything that's happened flys in the face of it but they are a very well respected outfit..
With the amount of big $ race cars and engines they build and maintain, i can't work out for the life of me why a lot of things have been done so half arsed. Makes no sense at all..
Offline ants
« Reply #1680 on: June 04, 2016, 03:17:34 pm »
Maybe that not being a race car was the training ground for the apprentice...an unsupervised apprentice at that !!!!!!
« Reply #1681 on: June 04, 2016, 04:44:52 pm »
yup, and thats why his engine was only 18000.00 instead of 25,000.00.  :lmao:
Offline sms777
« Reply #1682 on: June 04, 2016, 06:28:44 pm »
I can certainly agree with barnett on that one... :cheers:
Offline Fitzy1980
« Reply #1683 on: June 04, 2016, 06:33:11 pm »
Hardy friggin ha !
 :cry:
 :lmao: :lmao:
« Reply #1684 on: June 04, 2016, 06:53:15 pm »
Hardy friggin ha !
 :cry:
 :lmao: :lmao:
Just trying to bring some levity to your despair.  :lmao:
« Reply #1685 on: June 04, 2016, 06:54:27 pm »
By the way, hows the parking brake, other brakes working.  :lmao:
Offline Fitzy1980
« Reply #1686 on: June 04, 2016, 07:28:48 pm »
Surprisingly that's holding up, for now..  :shrug:  :lol:
Diff is causing me some anxiety, not liking the noises it's making going around corners..  :thud:
« Reply #1687 on: June 04, 2016, 07:35:48 pm »
Well, uh, yeah, of course they work fine in the driveway when your car doesn't run.  :lmao:
What noises?
If it is klunking around corners and is a clutch type and not a locker etc, just add a bottle of friction modifier.
Offline sms777
« Reply #1688 on: June 04, 2016, 07:43:37 pm »
Sorry for butting in but....since you have parking brake, going around corners should be a breeze. I am surprised barnett didn't pick this up. Combination of steering work and parking brake eliminates diff noise.   :thumb:
« Reply #1689 on: June 05, 2016, 12:16:00 am »
lol, oh, yeah, that will definitely cure posi klunk, however, i think this particular technique might be above fitzys pay grade at this juncture in time as he is still having enough trouble simply trying to shift it.  :lmao:
« Last Edit: June 05, 2016, 12:18:13 am by barnett468 »
« Reply #1690 on: June 05, 2016, 12:19:29 am »
...and making it run for more than 10 minutes without something breaking.  :lmao:
« Reply #1691 on: June 05, 2016, 08:10:56 am »
What sort of centre was it ,I can't remember what he told us . I don't think it was a LSD
Offline Fitzy1980
« Reply #1692 on: June 05, 2016, 09:47:46 am »
It's apparently and LSD
From a 1998 Hyundai.....  :shrug:  :lmao:
« Reply #1693 on: June 05, 2016, 10:25:24 am »
Ok if it's a LSD put the friction modifier in and that should stop it .  Some good diff rebuild shops should stock it or maybe google it . If the clutch packs are tight this will allow them to slip when going slow around corners .  Check to see if it's a LSD 1 st .
« Reply #1694 on: June 05, 2016, 10:31:24 am »
That's too bad . The 97 is the good one.  :lmao:
« Reply #1695 on: June 05, 2016, 10:35:15 am »
How's this for a thread title. "Do you have to tighten the shifter bolts?"  :lmao:
« Reply #1696 on: June 05, 2016, 10:46:38 am »
Wow, front wheel drive Mustang!
« Reply #1697 on: June 05, 2016, 02:24:23 pm »
Actually...right now it doesn't drive at all.  :lmao:
Offline Fitzy1980
« Reply #1698 on: June 08, 2016, 09:22:12 am »
Well it somehow lost 3 bolts out of where the shifter bolts to the side of the box...  :lmao:
I thought maybe 1 bolt working its way out but not friggin 3  :thud:
« Last Edit: June 08, 2016, 09:25:01 am by Fitzy1980 »
Offline Shep69
« Reply #1699 on: June 08, 2016, 10:04:20 am »
Hey Fitzy I think it's time to rename this thread .  :grin:
How about How To Fix Fitzys Lemon. We might be able to get to 100 pages. :grin:
Shit I've had a good laugh at this thread.
« Last Edit: June 08, 2016, 10:06:52 am by Shep69 »
