Author Topic: Do you have to degree a new cam ?  (Read 488078 times)
« Reply #1200 on: April 15, 2016, 01:46:30 pm »
« Reply #1201 on: April 15, 2016, 01:48:46 pm »
Page 49   :thud:  :cool:
« Reply #1202 on: April 15, 2016, 01:49:35 pm »
So it got water into the sump/ pan  :thud:   So fresh oil and filter needed .
Hey, try simply bailing it out with one of these . I think 500 gallons per hour should be enough.  :thumb:
« Reply #1203 on: April 15, 2016, 01:51:20 pm »
oops...I forgot to include the wiring diagram.  :smile01:
« Last Edit: April 15, 2016, 01:59:56 pm by barnett468 »
« Reply #1204 on: April 15, 2016, 01:59:04 pm »
If you are on a budget you could try the hand model . A big strong guy like you that can easily turn over a used v8 engine with no plugs in it by hand shouldn't have  problem pumping it.  :bolt:
« Last Edit: April 15, 2016, 02:01:03 pm by barnett468 »
Offline Fitzy1980
« Reply #1205 on: April 15, 2016, 02:17:39 pm »
Yep, happy days..  :thud:  :thumbdown:
Offline Fitzy1980
« Reply #1206 on: April 15, 2016, 02:19:25 pm »
Pump it straight onto the driveway...  :bolt:
« Reply #1207 on: April 15, 2016, 02:23:02 pm »
ummm...you already did that...TWICE . Or aren't you counting the 10 liters of gas you used to try to wash the oil ff with? :lmao:
« Last Edit: April 15, 2016, 02:25:11 pm by barnett468 »
Offline Fitzy1980
« Reply #1208 on: April 15, 2016, 02:52:03 pm »
Trying to give Deepwater Horizon a run for it's money...  :lmao:
Offline Fitzy1980
« Reply #1209 on: April 15, 2016, 02:57:44 pm »
Alright,
Looks like i fk'd up with the intake install..
There's a pool of milky grey oil at the back of the intake valley and where the rtv sits on the china wall.
 :thud:
« Reply #1210 on: April 15, 2016, 03:01:13 pm »
Alright,
 :thud:
that does not mean anything.
dont take the gasket or any silicone off.
take photos where i told you plus take some of the 4 corners of the intake and the end where the silicone was used for an end seal . you can put it on a box or hang th ends off a work bench one at a time to get these.
clean then photograph the distributor gear also.
« Last Edit: April 15, 2016, 03:15:13 pm by barnett468 »
Offline Fitzy1980
« Reply #1211 on: April 15, 2016, 03:12:53 pm »
dont take the gasket off.
take photos.
No point,
Parts of the gasket came off with the intake for some fkn reason..
There cactus, ill have to order new ones on Mon.
« Reply #1212 on: April 15, 2016, 03:16:31 pm »
No point,
take the photos anyway . you dont know what i am looking for.
you also didn't give me the part number of the gaskets . the same gaskets may do the same thing.
dont take any silicone off either.
take photos where i told you plus take some of the 4 corners of the intake and the end where the silicone was used for an end seal . you can put it on a box or hang the ends off a work bench one at a time to get these.
« Last Edit: April 15, 2016, 03:21:06 pm by barnett468 »
Offline Fitzy1980
« Reply #1213 on: April 15, 2016, 03:20:11 pm »
Welll, ummmm.
Because it ripped a heap of the gasket up.
I've already cleaned a lot of it off...  :thud:  :bolt:
I know, i know....
« Reply #1214 on: April 15, 2016, 03:27:47 pm »
better not get ANY of that gasket in the intake ports or the engine.
Offline Fitzy1980
« Reply #1215 on: April 15, 2016, 03:31:26 pm »
Blocked all the ports and have rags etc covering everything else..
I used a small vac last time to suck the sh!t up as i was scraping it off
« Reply #1216 on: April 15, 2016, 03:44:20 pm »
yes but you cant get it all . put newspaper in the valley also and tuck the edges under the head.
if the last gaskets were .060" thick, i wold use ones that are .090" etc.
you also need to torque them exactly, exactly how i said.
« Last Edit: April 15, 2016, 03:47:59 pm by barnett468 »
Offline Fitzy1980
« Reply #1217 on: April 15, 2016, 04:37:38 pm »
Gaskets were the right ones, Fel Pro 1262. Also had R3 on them.
« Last Edit: April 15, 2016, 04:44:18 pm by Fitzy1980 »
Offline Fitzy1980
« Reply #1218 on: April 15, 2016, 05:30:25 pm »
Even though it sounded like a tractor at least i got to hear it run for the first time in nearly 4 months.
And it didn't blow up !!!  :pepper: :lmao:
https://youtu.be/6vlqmU7uGHU
« Reply #1219 on: April 15, 2016, 05:35:53 pm »
ummm read my previous thread . video two is how it will idle with that cam . your timing was near perfect.
Offline Fitzy1980
« Reply #1220 on: April 15, 2016, 05:54:53 pm »
https://youtu.be/InQEJKeuckU
Ok, it's definitely a bit choppier than the old cam if that's the case.
« Reply #1221 on: April 15, 2016, 06:10:34 pm »
ummm, that is the case then .  it has a little more duration at .050" lift and steeper ramps and more lift than the other cam, so in effect, it has more overlap . i think you will be quite happy once you mash the gas pedal. :thumb:
after all, it is a "race car" is it not?  :lmao:
« Last Edit: April 15, 2016, 06:13:57 pm by barnett468 »
« Reply #1222 on: April 15, 2016, 06:15:33 pm »
IS THAT WHAT YOU THOUGHT WAS BACKFIRING?
I STILL NEED THE CRANK DAMPER AND TIMING COVER PHOTOS.
« Last Edit: April 15, 2016, 06:18:48 pm by barnett468 »
Online GEOFF289
« Reply #1223 on: April 15, 2016, 08:33:59 pm »
Hope it breaks down Geoff  :toetapping: :lmao:
It didn't. 50 something miles through the Dandenong Ranges with the windows down and the exhaust echoing off the hills. Great day out.
Checked the oil and water before I started it and they appeared to be quite separate. You should try that.
« Reply #1224 on: April 16, 2016, 05:52:41 am »
That comment is just inhumane.  :lmao:
