Author Topic: Do you have to degree a new cam ?  (Read 488153 times)
Offline Fitzy1980
« Reply #1025 on: April 06, 2016, 05:36:36 pm »
wha the fk are you using to turn it, a 6" long wrench?
doesn't sound like you ever were at a gym.
Why yes i am
Figured ive made everything else hard for myself so why stop now.. :lmao:
I coach Olympic Weightlifting and Crossfit part time ya jack ass...
Offline Fitzy1980
« Reply #1026 on: April 06, 2016, 05:37:20 pm »
xln't....i'll get the wieners!
A Schnausage perhaps ?
« Reply #1027 on: April 06, 2016, 05:40:52 pm »
Why yes i am
To who quadrapalegics?
Do they have a forum I can go to to tell them you can't even turn an engine over with no rockers and no spark plugs in it .  :lmao:
« Reply #1028 on: April 06, 2016, 05:43:21 pm »
I coach Olympic Weightlifting...
Must be for the "Special" Olympics .  :lmao:
« Reply #1029 on: April 06, 2016, 05:45:51 pm »
...and Crossfit part time ya jack ass...
A cross between what Richard Simmons and Caitlin Jenner? :lmao:
« Last Edit: April 06, 2016, 05:49:29 pm by barnett468 »
Offline Fitzy1980
« Reply #1030 on: April 06, 2016, 05:48:36 pm »
You'd fit right in..
« Reply #1031 on: April 06, 2016, 05:52:30 pm »
Yeah but at least I can turn an engine over with no plugs and no rockers .  :lmao:
« Reply #1032 on: April 06, 2016, 05:53:49 pm »
Are ya gonna need someone to help ya turn the key over too?  :lmao:
Offline Fitzy1980
« Reply #1033 on: April 06, 2016, 05:54:29 pm »
Got the Mrs for that..
« Reply #1034 on: April 06, 2016, 06:11:05 pm »
Well then it looks like ya should of had her turn the wrench for ya too.  :thumb:
 :lmao:
« Last Edit: April 06, 2016, 06:24:02 pm by barnett468 »
« Reply #1035 on: April 06, 2016, 06:13:24 pm »
Hey it's a new forum record, 11,322 thoroughly satisfied voyurers.
Offline Fitzy1980
« Reply #1036 on: April 06, 2016, 06:28:02 pm »
Just in case anyone came here to actually learn something.
Apparently, no you do not "have" to degree a new cam..  :thumb:
« Reply #1037 on: April 06, 2016, 06:31:59 pm »
By the way, the more rockers you put on, the harder it will be to turn over, so you might want to get a helper for that step   :lmao:
« Reply #1038 on: April 06, 2016, 06:32:32 pm »
 :lmao:
« Reply #1039 on: April 06, 2016, 07:14:05 pm »
you must use a long bar to turn the engine over with or something  bad may happen.
Offline Fitzy1980
« Reply #1040 on: April 06, 2016, 07:51:16 pm »
Say what now ?
« Reply #1041 on: April 07, 2016, 12:00:30 am »
Say what now ?
i mentioned to use a long bar in my earliest posts.
« Reply #1042 on: April 07, 2016, 09:08:15 am »
ok bitch, try to follow these simple instructions.
1. connect your fuel pump line . but i guess you figured that out on your own yesterday .  :lmao:
2. put number 1 on tdc fire position.
3. install distributor so the rotor points at the post you want to use for number 1 cylinder.
4. connect the coil and distributor wires.
5. install a SPARK plug in number 1 cyl and connect that plug wire.
6. connect a timing lite . if it is adjustable, make sure the know says ZERO.
7. have someone turn the engine over as you set the timing to exactly 12 degrees before top dead center . in your case this will be 12 degrees to the right of the black felt pen mark on your damper as you face the engine.
if no one can help you, then use a short screwdriver to connect the big post on the FRONT of the solenoid to the tiny post right next to it.
8. tighten distributor.
9. install remaining plugs and wires and check the wire routing THREE times.
10. your engine WILL instantly fire up when you turn the key.
« Last Edit: April 07, 2016, 09:10:10 am by barnett468 »
Offline Fitzy1980
« Reply #1043 on: April 07, 2016, 10:25:32 am »
 :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao: :lmao:
Offline Fitzy1980
« Reply #1044 on: April 07, 2016, 02:24:38 pm »
Well would you fking believe it...
Rockers done
Engine rotates smoother than Glenn's nether regions..  :bolt:
« Last Edit: April 07, 2016, 02:26:21 pm by Fitzy1980 »
« Reply #1045 on: April 07, 2016, 02:28:28 pm »
Well would you fking believe it...Rockers done
You're right,  we don't .  :lmao:
Engine rotates as smoother than Glenn's nether regions..  :bolt:
ummm, ok, if you say so, but please don't post photos or any further details. :lmao:
« Last Edit: April 07, 2016, 02:30:06 pm by barnett468 »
« Reply #1046 on: April 07, 2016, 02:31:30 pm »
make sure the rocker adjusting nuts are pretty tight.
Offline Fitzy1980
« Reply #1047 on: April 07, 2016, 02:35:30 pm »
Have faith brother  :bow:
No chance of firing it up today, battery was overnight 3 days ago so that's here "tomorrow" and i have to make brackets etc for the rad which will take a couple of hours.
Also i'm going to have to "pro" mod the side of the distributor slightly because the water temp sensor hits it..
And some other stuff...
« Last Edit: April 07, 2016, 02:45:53 pm by Fitzy1980 »
« Reply #1048 on: April 07, 2016, 03:51:41 pm »
what battery did you use the other day?
dont be like your "professional" engine builder and go grinding on your brand new shiny $400.00 distributor . post a photo of the prob.
« Last Edit: April 07, 2016, 03:53:14 pm by barnett468 »
Offline Fitzy1980
« Reply #1049 on: April 07, 2016, 04:11:51 pm »
I used the old one but it wont fit now with the radiator in
