Space saver
Author Topic: Space saver  (Read 6167 times)
Offline Olympia1959
  • Name: Theodore chr
Space saver
« on: January 15, 2016, 06:01:58 pm »
This subject has most probably been discussed previously.
Have a 67 fastback that needs to have a spare. With the small
area in the boot, I was considering whether someone can
Advise if space savers are avaliable for these models & obviously
Where can I get one  or what options are avaliable.
Can someone please advise
Regards Theo
Offline aussie trev
  • you must have toys
  • Name: trevor
Re: Space saver
« Reply #1 on: January 15, 2016, 06:12:30 pm »
You can buy a space saver in us but can are not cheap with the dollar going down. What i did for my hotrod was to buy a space saver from wreckers  out of a jap car and have a wheel repair shop machine out the centre and weld in a ford centre.cost me about $150 with new powder coating. this my help. trev
Re: Space saver
« Reply #2 on: January 15, 2016, 07:12:55 pm »
I'm about to start searching for a 4 stud rim so our wheel workshop can make a space saver rim up for me to try. I figure if they can build up trailer, truck, mining and earthmoving rims it's an easy crossover.
Offline moe
  • Name: "Moe"
Re: Space saver
« Reply #3 on: January 15, 2016, 09:02:50 pm »
Mazda 5 stud is same stud pattern as ford.  Have used a ford wheel on a couple mazda's (mx5, RX7 and mazda3); just need to check load ratings
Re: Space saver
« Reply #4 on: January 15, 2016, 09:42:25 pm »
Also buy a can of the inflatable stuff that you can use to pump your tyre up if you get a flat. Mine is called "Pump My Ride" and I got it at Supercheap.
Offline skev
Re: Space saver
« Reply #5 on: January 16, 2016, 08:39:09 am »
What about a modern falcon space saver?
67 Convertible
Offline 67FBGT
  • Car: 1967
Re: Space saver
« Reply #6 on: January 16, 2016, 08:53:46 am »
Wouldn't any modern wheel, Falcon or Jap, have the wrong offset, or wouldn't that matter?
Re: Space saver
« Reply #7 on: January 16, 2016, 09:14:55 am »
Two problems 1 st yes the offset make sure it fits before you buy,  2nd ,  try and get the same hight as what's on the car now and if you car has a LSD diff its a must .
Offline moe
  • Name: "Moe"
Re: Space saver
« Reply #8 on: January 16, 2016, 09:39:48 am »
Wouldn't think offset comes into play with a true space saver....  way too skinny for offset to be an issue.
Re: Space saver
« Reply #9 on: January 16, 2016, 09:57:38 am »
Maybe not a problem .  Even a early 5 inch mustang rim with a small tyre might do the job . A space saver rim might be around 3 1/2 wide at a guess .
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
Re: Space saver
« Reply #10 on: January 16, 2016, 10:44:03 am »
Space savers have a speed limit; they're only to be used to get you home or safe location to replace the tyre; only intended for very limited use so they don't have to be so precise but yeah, they do have to fit and not interfere with panels/components.
s
« Last Edit: January 16, 2016, 10:46:07 am by StephenSLR »
Offline stormin
Re: Space saver
« Reply #11 on: January 16, 2016, 10:36:21 pm »
I have the Mazda space saver in my 68 FB. From memory cost about $30 on Ebay and picked up from a wrecker.
Stormin
