67 mustang rear gards are rubbing
Author Topic: 67 mustang rear gards are rubbing  (Read 13242 times)
Offline shelby_mustro
  • Name: Ryan
« on: August 13, 2015, 08:34:46 am »
Hey all does anyone know where I can go to get my rear gards rolled?? Everytime I have two or more people in the car or it hits a bump in the road that inside lip is hitting the otter edge of the tyre out. I'm on the Gold Coast
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
Re: 67 mustang rear gards are rubbing
« Reply #1 on: August 13, 2015, 09:02:35 am »
Where's my wheels  :grin:   Your a pain in the Butt ,precision guard rolling ,Kevin 0400622116 if he is still doing it . You owe my big time for all the info and help I give you .
Offline boofhead
« Reply #2 on: August 13, 2015, 09:21:20 am »
A hammer works.
A baseball bat works.
  • Name: Ryan
« Reply #3 on: August 13, 2015, 10:18:41 am »
Glenn didn't you read your messages  :therethere:
Ha I thought about that but don't want to risk damaging the paint
t5 5 speed manual
Other cars
Offline lukep6470
« Reply #4 on: August 13, 2015, 02:00:28 pm »
I have a guard roller that I used on the front of my 67 no problems.  It's the one that bolts to the hub and has a skateboard wheel on it.  I also have a heat gun to soften the paint.
I'm in Brisbane if you want to give it a go.  All care no responsibility.
Offline mojocoops
« Reply #5 on: August 13, 2015, 03:35:59 pm »
Hi Luke,
I may need to borrow it also, just bought some new wheels and the rears rub a bit.
I'm in Brisbane also.
Stephen.
Offline Pinto Pete
  • Name: Nigel
« Reply #6 on: August 13, 2015, 06:52:06 pm »
A hammer works.
50 mm exhaust tube works well too..
  • Name: Ryan
« Reply #7 on: August 13, 2015, 07:19:17 pm »
Just rang that number gleen gave me the guy is away on hoildays for a week or two but said he can do it for $120 for the back end. think I'd rather leave it to him to do.
t5 5 speed manual
Other cars
« Reply #8 on: August 13, 2015, 08:26:01 pm »
Kevin seems to a good job so worth the wait .
  • Name: Ryan
« Reply #9 on: August 13, 2015, 08:36:37 pm »
Yep I think so also not worth damageing the paint. Will cost a lot more then $120 if I do.
Hey Glenn did u say you wanted 14s? Checked them out this arvo.
t5 5 speed manual
Other cars
« Reply #10 on: August 13, 2015, 08:38:18 pm »
Yep just std 14 inch nothing special .
Offline lukep6470
« Reply #11 on: August 13, 2015, 10:01:04 pm »
I'm just wondering what size you guys are fitting to the rear of your 67s?
I've got 17x9 on the back with 245s and there is still heaps of room.  I could go to 265s without rolling the guards.
Offline mojocoops
« Reply #12 on: August 13, 2015, 10:16:07 pm »
I'm running 17x8 with 225/50/17s, need to roll the guards just a bit.
« Reply #13 on: August 14, 2015, 07:01:26 am »
When I owned a 68 I had 15x8 with 255x60 on the back and it was lowered 2 inches all round and had plenty of room because I had the right offset on my rims . The offset is where you can go wrong .
  • Name: Ryan
« Reply #14 on: August 14, 2015, 05:56:32 pm »
I have coys 17x7 front and rear 17x8 even put a low profile tyre on almost hits all four corners
t5 5 speed manual
Other cars
Offline lukep6470
« Reply #15 on: August 17, 2015, 03:26:15 pm »
So I have 17x8 with 225s on the front that needed rolling just at the top.  The rear are 17x9 with 245s and have maybe 15cm to go to the guard without rolling.  Both are 4.5" backspace I think.
The front is lowered so if it was stock height there would be no problem.
Offline mojocoops
« Reply #16 on: August 17, 2015, 03:29:51 pm »
What profile are your tyres?  Surprised you have so much room in the rear.
Offline lukep6470
« Reply #17 on: August 23, 2015, 10:05:17 am »
The rear are 245x45 17 and the front are 225x45 17.  The speedo over reads by 2mph at 60.
