What compressor will fit a 94/95 Mustang?
Author Topic: What compressor will fit a 94/95 Mustang?  (Read 7070 times)
Offline 95_GT
  • Name: Tony
« on: July 22, 2015, 04:49:36 pm »
Hi. Does anyone know what compressors from different makes will fit a 94/95 Mustang? The original is not working and trying to find a replacement is proving a bit difficult. Thanks in advance.
Offline 95_GT
  • Name: Tony
Re: What compressor will fit a 94/95 Mustang?
« Reply #1 on: July 23, 2015, 11:14:48 am »
Geez you guys are a big help. Thanks!
Offline Ausfox
« Reply #2 on: July 23, 2015, 01:26:42 pm »
You would think that you would get an answer with all the experts on here!
AU Falcon is the exact same compressor with the only difference being the the fixed mounting bolt sleeves on the U.S. ones are longer than the Aussie compressor.
Simple fix by making two 10mm aluminium plates, with two holes in each, to fit between the bottom of the AU compressor bolt sleeves and the Mustang compressor mount.
Use your original bolts and not the shorter AU ones.
Belt length doesn't change.
94-95 Mustang compressor.
AU Compressor.
« Last Edit: July 23, 2015, 04:41:51 pm by Ausfox »
17 SEPT 1964 FASTBACK
1966 Turbo 6Cyl Coupe
1979 INDY PACE CAR
http://s251.photobucket.com/albums/gg310/427gge/Mustang%20Pacecar/
Offline 95_GT
  • Name: Tony
« Reply #3 on: July 23, 2015, 03:22:19 pm »
You sir, are a bloody legend!
Thank you so much!!!  :thumb: :thumb: :thumb:
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
  • Name: Dale
« Reply #4 on: July 23, 2015, 04:07:00 pm »
just ask and wait Tony................ :thumb:
ps. there are a few 94-95's now in Adelaide...what colour is yours
Paint by IMAGE CLASSIC CARS
Offline 95_GT
  • Name: Tony
« Reply #5 on: July 23, 2015, 04:28:34 pm »
She's a black beauty. Custom plates GT PONY.
She has undergone some major exterior changes lately so I'll be putting up some more pics soon.
« Last Edit: July 23, 2015, 04:36:37 pm by 95_GT »
Offline 95_GT
  • Name: Tony
« Reply #6 on: July 23, 2015, 04:37:26 pm »
$4500 custom leather interior care of Carofano Trimmers in Adelaide.
« Last Edit: July 23, 2015, 04:39:20 pm by 95_GT »
Offline 66 Hertz
  • Web Editor
  • Name: Dale
« Reply #7 on: July 23, 2015, 05:10:43 pm »
nice, hope to see it out and about  :cheers:
Offline 95_GT
  • Name: Tony
« Reply #8 on: July 23, 2015, 11:02:57 pm »
Ausfox, can the difference in length be made up by adding thick washers on top of the sleeves, one on top of the other and the bolts fitted through the washers so everything is nice and tight?
Offline Ausfox
« Reply #9 on: July 25, 2015, 09:42:34 am »
As the spacers need to go between the AU Compressor mounts and the Mustang Compressor mounting bracket,
I just found it much easier to drill four holes in some aluminium 10mm  x 25 mm flat, than try and juggle the compressor, the mounting bolts and multiple washers.
95 engine in my 1965 Coupe. AU compressor with spacer plates.
« Last Edit: July 25, 2015, 09:44:38 am by Ausfox »
1979 INDY PACE CAR
Offline 95_GT
  • Name: Tony
« Reply #10 on: July 26, 2015, 05:23:24 pm »
Thanks mate.  :thumb:
