WA legal registration requirements. 66 Coupe
Author Topic: WA legal registration requirements. 66 Coupe  (Read 10804 times)
Offline FM289
« on: May 12, 2015, 01:33:31 pm »
Hey, looking for some advise on many modifications getting done to my 66 Coupe, which may save some time,money and heartache.
Has anyone done any of the following and could point me in the right direction to for-fill WA legal registration requirements.
List of modification
Front coil-over conversion
Rear coil-over conversion
Electric power steering
Wilwood disc brakes front and back
I would assume I will need to have an engineer pass some or all of these modification and was hoping someone could share their do's and don't.
Offline dyates
  • mustang tragic
  • NSW member of MOCA.Located Casino
Re: WA legal registration requirements. 66 Coupe
« Reply #1 on: May 12, 2015, 03:49:52 pm »
Not sure about WA but I am highly dubious as to whether NSW would pass the rear end conversion given the lower shock/spring mounting position.
Black and Gold 66 Hertz Tribute
1966 Coupevertible triple black - Sold
Offline trav68
« Reply #2 on: May 12, 2015, 03:54:35 pm »
Hi,
Should not really be a big issue apart from the electric power steering (just don't know much about them and compliance requirements as not an area of interest personally). Ideally calipers should have outer piston dust boots which yours may not have (?) but precedence exists for engineered Wilwood kits so it should not be an issue.
My 1968 Fastback is legal and fully complianced with upgraded disc brakes, slight suspension modifications, BA seats and 3 pt belts. I did the engineering report myself as I am a qualified Mechanical Engineer, Chartered with the Institute of Engineers Australia, National Professional Engineers Register and have considerable experience in industrial/mining engineering, testing and commissioning. So with these credentials the  DPI gave me permission to do my own engineering cert.
Ideally you should approach one of the registered engineers with the DPI before commencing the following journey as they will ultimately have to sign off on your work/project:
Step 1: Fill out application to modify ( should have really done this before procuring parts)
Step 2: DPI will respond with an "in principle approval letter" so you can proceed if they deem your modifications to have met the code requirements
Step 3: Complete mods
Step 4: Engineer will inspect vehicle, undertake testing ( i.e abridged ADR brake test), etc ( rectification works may be requested so engage early so requirements are defined)
Step 5: Engineer will supply a report, inspection check sheets, brake test data and signed declaration
Step 6: Purchase vehicle mod plate voucher from DPI Licensing Centre
Step 7: Vehicle inspection over pits and issue of Mod Permit ( assuming no rectifications works required)
Step 8: Attend DPI Licensing Centre for update of details in DPI system
Note the final 3 steps maybe be simplified if you attend a DPI inspection centre versus one of the private operators who are certified to conduct inspections.
I was entertaining the idea of undertaking this work but on hold at the moment due to confidence in revenue to justify my insurance premiums. Estimated cost for the above engineers scope is about $600. Before you engage an engineer I would quiz them on public liability and professional indemnity insurance as some of the operators are "cowboys" in my opinion. The report I produced for my vehicle was above and beyond the norm including GPS data logged brake tests but my if you are going to do a job you may as well do it properly!
I don't really come on this forum frequently find me on Mustangtech if I am slow to respond to a query or bassan at iinet.net.au .
Regards,
Travis
Offline FM289
« Reply #3 on: May 12, 2015, 04:43:25 pm »
Hey Travis, thanks for the great feedback. Let me know if your insurance premium issue changes, i'd be happy for you to help me thought the process. Cheers Rod
Offline trav68
« Reply #4 on: May 12, 2015, 05:18:42 pm »
What is your registration timeframe since it appears to be a longer term project? I have a few people who have expressed interest in using my services if it gathered momentum I would commit.
The National Code of Practice for Light Vehicle Modificaitons NCOP5 - LG and NCOP11 - LS cover suspension, steering and brake upgrades. Any modifications you undertake will have to be compliant to these specifications.
Regards,
Trav
Offline FM289
« Reply #5 on: May 12, 2015, 06:06:31 pm »
Trav, the car is waiting for new doors to arrive from the US mid June, then booked for paint thereafter. Electric power steer will have to wait, all other components are in or ready to go. motor and gearbox will go in before painting hopefully in a week or two (its maybe not the right way to put in before painting) Steering will be manual steer for now. Full wiring need to be done after paint. So will be a while before drivable for braking tests. I've been collecting parts for 7 years and have all major components. So, touch wood I think barring any major hiccups 2-3 months, it will be drivable. Being an enthusiast and not an expert in any mechanical field, I have a few issues that I will need assistance with. Rod
Offline highside
  • Car: XR Fairmont
« Reply #6 on: May 24, 2020, 04:57:13 pm »
Hi there
how did you go in the end with your mustang ?
I have done  a Willwood conversion front and back on an XR Fairmont, also in WA,  and would be interested to hear how your approval process went.
Offline trav68
« Reply #7 on: May 25, 2020, 12:43:42 pm »
Hi mate,
Shouldn't be much of a bother for just a brake upgrade. Refer to above step by step on the process.
From memory only sticking point with some of the aftermarket brake kits is for road cars/licensing piston dust boots are preferred - and not all of them have that. For a pre-engineered kit from a company like Wilwood you should be pretty safe generally.
Try Dan Pitic if you need an engineer. I don't have all insurances so wouldn't do work for other people .
Regards,
Trav
