Ok guys have rung a few places.
Looking at between 5500 and 6500 for rebuild!
That better include the mini stroker kit and head mods.
What are your opinions on run in procedures as two places said they just give the built motor back and we can install and one place said it must be dyno run in?
I have never gotten a flat cam using my patented procedure below.
INTAKE MANIFOLD AND VALVE COVER BOLTS
Check them for tightness, they may have loosened.
OIL
Joe gibbs break in oil
PRIME
Spin oil pump with 1/2” drill for 30 seconds.
Turn crank 180 degrees and spin pump for 10 seconds
Turn crank 180, spin for 10.
Turn 180, spin for 10.
VALVE SPRINGS
If you have a non roller cam and your spring pressure is more than around 280, I would consider removing the inner valve springs for break in if you have duals . . You can also have cams pre-broken in by Cam Research or other shop.
VALVE LASH
comp lifters are crap and they may make a ticking sound . . Adjust the comp lifters to 1/2 turn preload.
TIMING
Turn engine until intake valve is fully closed then turn almost 1/2 turn until you see timing marks on damper and line them up with tdc.
Remove distributor cap and make sure the rotor is pointing to number 1 cylinder spark plug wire.
Remove all plug wires except for number 1 cylinder.
Plug the distributor vacuum advance until after break in then plug it into ported vacuum providing there is no vacuum at the port at idle.
Connect timing lite and turn engine over by jumping the two forward posts together in the starter solenoid with a short screw driver etc ir have someone operate the key and set it to 10 btdc.
Reconnect plug wires.
THERMOSTAT
Remove it
RADIATOR FLUID
Use water only and and fill it to 1 inch below bottom of filler neck.
HOSES
Tighten them, then tighten them again.
FAN
Put a big one in front of the rad.
STARTING
Have someone start if while you operate the throttle on the carb.
Instantly rev it up to around 2000 rpm and set idle screw.
After a few minutes the rpm will increase, reduce it to 2000 rpm and maintain this rpm for 30 minutes.
AFTER BREAK IN
Let engine cool for 30 minutes.
Re-check intake manifold and valve cover bolts and fan belt tension and hoses.
Re-install 180 - 185 thermostat.
Refill with water and let idle for 7 minutes.
Turn off and open lever on rad cap to release pressure.
Fill it to 1 inch below the bottom of the filler neck.
Test drove for 30 minutes . . Accelerate from 40 to 65 kph then immediately back down to 40 kph around every 3 minutes . . This will help break the things in more quickly.
Drain water and install anti freeze.
Let idle for 7 minutes.
OIL AND FILTER CHANGE
After 200 miles.
............................Then...
![bow :bow:](https://forum.mustang.org.au/Smileys/smilies/bow.gif)
![](https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcSVYREGxzg6Fe0suhODFRcEOikLVimMChqdk3ZO_rr153W6aHQs)
