1967 mustang original resto progress pics
Author Topic: 1967 mustang original resto progress pics  (Read 40224 times)
Offline shelby_mustro
  • Name: Ryan
« on: September 07, 2014, 07:46:54 pm »
Hey guys thought I'd post up some of my past weeks progress of my 67 mustang.
My partner and I found her in la while on the 50th mustang anniversary tour in April.
The car has been in the family it's whole life and has all the original paper work still when it left the factory so we have decided to put it back to original as more like a concourse car.
Has some deluxe options like center console power breaks power steering pop of gas cap and levured bonnet.
« Last Edit: September 07, 2014, 10:31:31 pm by shelby_mustro »
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
  • Name: Ryan
Re: 1967 mustang original resto.
« Reply #1 on: September 07, 2014, 07:53:18 pm »
Ended up just cutting of the rh quater and replaced with a new one from past bad repairs.
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #2 on: September 07, 2014, 07:57:15 pm »
Both floor pans where completely stuffed the past owners just put tin Nd pop riverted over the top.
Both floors all finished and re coated.
« Last Edit: September 07, 2014, 08:04:45 pm by shelby_mustro »
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #3 on: September 07, 2014, 08:13:40 pm »
Lh win do piller was full of bog & a bad attempt of welding.
Ended up cutting it all out made a new piece and drip rail.
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #4 on: September 07, 2014, 08:22:45 pm »
The inner & outter sections had bog and rust. Had to remake that part of the drip rail and reweld it
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #5 on: September 07, 2014, 08:26:36 pm »
« Last Edit: September 07, 2014, 08:32:54 pm by shelby_mustro »
t5 5 speed manual
Other cars
Offline smackdownz
  • Mr Pony
  • Name: Jai
Re: 1967 mustang original resto progress pics
« Reply #6 on: September 09, 2014, 06:29:29 pm »
pretty jealous of your welding/plating skills mate, looks like alot of work ahead but should be mint when its done  :thumb:
what did you use to recoat the floor?
Jai.
« Reply #7 on: September 09, 2014, 06:54:45 pm »
Good job, keep the pics coming
Offline sea67n
  • Name: Sean
« Reply #8 on: September 09, 2014, 09:40:21 pm »
looking good, been going through the same with my 67, Im sure it will be very sweet in no time
  • Name: Ryan
« Reply #9 on: September 10, 2014, 05:31:34 pm »
Thanks I'm surprised myself I couldn't afford to pay someone to fix the rust so thought I'd have a go myself turns out I had a bit of a nack for it  :grin:. to be honest there was a lot more hidden rust in this car then I thought when I bought it in the states. but more or less I was sold on the fact it was a one owner car and has all it's original paperwork with it & the price  :evilone:
Got all my bits back from the powercoater today came out mint and the cost to do it was cheaper then buying new parts.
« Last Edit: September 10, 2014, 05:36:41 pm by shelby_mustro »
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #10 on: September 10, 2014, 05:35:14 pm »
Jai.
There is a paint shop on Brisbane road that sells that rubber coating you spray on and you can paint over it. I put that on first and then put the 2pk red oxide over the top. trying my best to keep it as close to original as possible. I'm only at runway bay not far from you should pop round for a beer one day mate check it out.
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #11 on: September 25, 2014, 08:43:11 pm »
Thought I'd so my progress for today front cowl and lower section have been pulled out and will be replace when the new bits arrive.
New lh door skin the old one was badly dinted.
t5 5 speed manual
Other cars
Offline 65muzzy
« Reply #12 on: September 25, 2014, 10:15:58 pm »
What did you do to the leaf springs to get them like that.
  • Name: Ryan
« Reply #13 on: September 26, 2014, 09:59:43 am »
I had them pulled apart completely and sent them to the powercoaters. It all came up mint. worked out cheaping doing this then getting new parts.
t5 5 speed manual
Other cars
Offline 67fasty.sm
  • Name: shane
« Reply #14 on: September 26, 2014, 08:00:16 pm »
doing a great job shelby !  :thumb: one question how come you didnt use a 67 repo qtr panel , thats alot of work what you did
cheers shane
« Reply #15 on: September 26, 2014, 10:17:12 pm »
Excellent job
  • Name: Ryan
« Reply #16 on: September 26, 2014, 11:00:11 pm »
Thanks guys!
Ha yes I did do it the hard way that's for sure using a skin but saved about $300 doing it this way.
For the lh side I plan to use a full quarter this time will be much quicker.
While the cowl  was out I cleaned up the fire wall and repainted it also sent the whole dash out to be blasted.
It's tempting I have gone this far I could almost convert it to rhd been the dash and cowl has been taken out but not sure if it would be worth more doing it.
t5 5 speed manual
Other cars
Offline 69ISH
  • Name: Rodney
« Reply #17 on: September 27, 2014, 07:20:07 am »
Ryan,
It is only a run of the mill type coupe so unfortunately you will over capitalize on it even with you doing most of the work on it. If it was a fastback or a convertible you may just have been able to break even, there is just as much money and work involved in restoring either of the 3 body styles but the other 2 demand a higher resale price  So as every one keeps on telling people build it how you want it not how others want it and get out and enjoy it.
If you are trying to make money on it, good luck, have a look at the market and see what a coupe is really selling for not what the asking price is. Even concourse correct coupes do not draw big dollars and you're coupe which is just being restored with after market replacement panels and incorrect finishes is far from concourse but looks like it will be a very nice car none the less.
I guess what I am trying to say is build it for you and what you can afford resale value should not matter.
« Last Edit: September 27, 2014, 07:31:28 am by 69ISH »
1972 Gran Torino Sport (Sold)
1968 Mustang Coupe (Sold)
« Reply #18 on: September 27, 2014, 08:51:32 am »
 :agree: Ryan build it the way you want . It will never be a Concourse car no hope .  For a concourse car it has to be as it came out of the factory ,so forget 2 pack paint ,powder coating etc etc . If you plan on keeping it do it the way you will be happy ,if selling do it nice but not over the top and try and get some of your money back .
  • Name: Ryan
« Reply #19 on: September 27, 2014, 11:31:44 am »
Arh my budget has been very good so far. I have watched every cent so far. What I liked about this car was it was an one owner option car with all it's paperwork so I thought that added some value to it.
I have a concorse finnishes Book so have been following that pretty closely to what stripes and what colour bolt goes where.
All the original bits have been sent out to get refinished re chromed etc. It will be close I'm trying to cover every corner of the car. This is how I want to do it I want an original car.
t5 5 speed manual
Other cars
Offline 67FBGT
  • Car: 1967
« Reply #20 on: September 27, 2014, 11:41:57 am »
I think what he means he's doing the works on it, everything; so it will be super tidy, will present well & probably judge very well.
Yes any deviation from how Ford built them originally loses points in true 'concours' competition classes which are very strict; they are top level & have their place but are too strict for many of us. I can't be bothered with it any more, too tough for my budget & too anal!
It's coming up well, lots of nasty surprises but Ryan will overcome those, just as we have all experienced such things ourselves no doubt.
I have a friend in NZ also with a one-owner red '67 coupe, all paperwork, full history, the works, & it's got less options than Ryans, still it's special & he just loves it because of all that even though FBs & CVs get more attention.
Go Ryan!
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #21 on: September 27, 2014, 11:52:21 am »
I agree. Not everyone has a FB or Vert, and even the humble basic car needs representation or no-one will remember that Mustangs were supposed to be a budget car initially.
  • Name: Ryan
« Reply #22 on: September 27, 2014, 05:17:14 pm »
Sent the dash out to be sand blasted today. May as we'll get the underside as nice as the top end. Front cowl will hopefully be in next week. not too long now untill I send it out to the panel beater.
No I agree concorse is too hard but I'm going to try and get it close as possible. found a good seller that sells you all the original coils, battrey leads pretty we'll everything for all the autolite gear you need. Pretty we'll want a car that looks original but clean enough to eat of it.
« Last Edit: September 27, 2014, 05:19:10 pm by shelby_mustro »
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #23 on: October 07, 2014, 07:24:39 pm »
Painted my concole today came up mint in the original 67 dark red
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #24 on: October 07, 2014, 07:30:04 pm »
Desided to do a new lh full quater panel the old one was ok but not the best.
t5 5 speed manual
Other cars
