69 Mach1 finally started
Author Topic: 69 Mach1 finally started  (Read 30498 times)
Offline MACH_ONE
  • torque to me
  • Name: Andrew
Re: 69 Mach1 finally started
« Reply #25 on: June 23, 2014, 06:08:50 pm »
At the end of the day you buy the car for yourself not to please others...if you want to paint it in pink with purple spots then go for it...If I buy another mustang most of the purists will hate it because it will be wild.
I watched a video last night on a guy who has a copper coloured Eleanor to me it was beautifully done but some of the remarks from idiots were....
why did he paint it that color its not original Eleanor colour!!!...news flash neither is the car
why did he put those wheels on????....news flash because he could and they look great
The engine sounds like crap it should have a 289 in it...news flash what a 429 supercharged is not good enough?
peoples perception of things are just that ! perceptions ! Do what you want its your car.
(btw pink and purple spots yuk) lol
My other car is a Mustang ( ok I lied this one cost me enough)
Offline paulb
  • Car: 1969 fastback
« Reply #26 on: June 28, 2014, 07:42:27 pm »
Here's the dash coversion ,have one thats already converted but cant use vents with it and i wanted one that was same measurements as factory in where the steering colum and glovebox are
« Last Edit: June 28, 2014, 07:47:01 pm by paulb »
Offline paulb
« Reply #27 on: August 13, 2014, 08:25:59 pm »
Been busy tweeking the dash , removed outer cowls,cleaned up the rust and repaired sections
« Last Edit: August 13, 2014, 08:34:51 pm by paulb »
« Reply #28 on: August 13, 2014, 08:31:09 pm »
I've only just caught up with this thread. Great job so far. Keep the pics coming.
Offline paulb
« Reply #29 on: October 04, 2014, 05:55:39 pm »
Been busy over the last few weeks, r/h rail, torque box installed, radiator support and front approns in, and r/h sill panel, sat wheels in place to determin diff width
Offline Macka
  • Vic member 1571
« Reply #30 on: October 04, 2014, 06:07:23 pm »
Plenty of rubber under those guards Paul..    :thumb:
Offline paulb
« Reply #31 on: February 14, 2015, 01:49:28 pm »
Haven't posted updates for a while as with christmas and family comitments work has slowed, here's some progress, got my draglink back from john, mounted steering box and idler,floor is tec screwd in rear floor removed,rails strengthed and sandblasted,por15 painted on inside rails,rear torquebox covers replaced,shockabsorber crossmember replaced and rear floor fitted, doors and front end fitted ,chassis checked and rechecked for proper alignment,once i'm fully satisfied its right I'll weld it up,then start on the rear panels.
« Last Edit: February 14, 2015, 01:58:48 pm by paulb »
Offline 69candy
« Reply #32 on: February 14, 2015, 07:11:01 pm »
Good progress. I remember when I was at the same stage doing the same work
Offline paulb
« Reply #33 on: February 15, 2015, 02:43:26 pm »
Will be worth it as I'll know exactly what I've got 😊
Offline paulb
« Reply #34 on: May 09, 2015, 09:14:16 pm »
A few progress photos,left 1/4 on just about to fit r/h one after a few repairs on the door jam,having it down this far has let me blast and treat areas that you wouldn't normally be able to get to
Offline 66 Stang
  • MOCA NSW Member
  • Name: Keith
« Reply #35 on: May 09, 2015, 10:15:22 pm »
Man that looks like a huge rebuild, good on you for taking on a project like that :thumb:
Will be following this thread with interest.
Offline littlejohn
« Reply #36 on: May 26, 2015, 09:02:26 pm »
 :omg: you're full on
Commendable, takes big kahuna's to do that  :thumb:
« Reply #37 on: May 26, 2015, 10:22:24 pm »
Impressive
Offline paulb
« Reply #38 on: May 28, 2015, 03:04:22 pm »
Thanks, it's not that hard just lots of patience, measurements and photos, also helps having a father who's an old school panelbeater, I remember when I was young going to work with him on Saturday mornings so I could help ( or hinder depends on how you look at it :smile01:) unfortunately for me he lives too far away to help. I got four days in the last round off so a little progress, door jam has been blasted andrepaired, everything inside gets the metal finish and poor 15 treatment , replaced front roof brace , fitted up rear 1/4 panel and wheel wells, fitted up tail light panel, doing some gapping with the rear valance, so much easier when the lower part isn't welded together yet.
« Last Edit: May 28, 2015, 04:19:29 pm by paulb »
Offline littlejohn
« Reply #39 on: May 31, 2015, 09:45:11 pm »
Friggin insane!!
Offline paulb
« Reply #40 on: January 01, 2016, 07:32:12 pm »
Thought I would update seeing as it's been a while, boot floors welded in, rear seat support panel finally showed up and fitted, gapped doors ( still more to do) , r/h door is 5 mm shorter than the left, both dynacorn.Drip rails replaced and roof skin fitted, Rear is all fitted up awaiting a final measure then welding. Hopefully after Christmas is over I'll get some solid time on it
« Last Edit: January 01, 2016, 07:36:08 pm by paulb »
« Reply #41 on: January 01, 2016, 09:20:51 pm »
Welcome back Paul and Happy New Year. The panel fitments are looking real good, great progress.
Offline unilec5544
  • Name: Neil.
« Reply #42 on: January 01, 2016, 10:06:43 pm »
Great progress, I am going to have to get dynacorn doors for my 69 once I start and have heard that the fit is not great. How did you fix the 5mm gap?
Offline paulb
« Reply #43 on: January 02, 2016, 07:41:02 am »
Happy new year everyone, The fit of the left door was very good,just needed a bit added at top near the mirror, the right door was short, I used welding rod with the flux removed from memory its 2-3 mm then slowly welded it to the door, you can only weld very short runs, I air cooled as I went, takes a while but well worth it, I then trim with a sanding disc and body file
« Last Edit: January 02, 2016, 07:43:03 am by paulb »
Offline paulb
« Reply #44 on: January 08, 2017, 07:50:02 pm »
Hello everyone, can't believe another year gone! Thought I might update with a few photos, progress has been a bit slow, diff shortened and in place, inner wheel houses widened, rear welded up, inner rocker panel strips folded and fitted, firewall started, plan to have it painted this year( fingers crossed )
l
][/URL]
« Last Edit: January 08, 2017, 09:13:09 pm by paulb »
Offline PET-289
  • Name: Mick
« Reply #45 on: January 08, 2017, 08:03:58 pm »
Great work Paul, looking really good
« Reply #46 on: January 08, 2017, 08:54:12 pm »
Thanks for the update, great work
Offline staddy
  • 1969 GT350H
« Reply #47 on: January 16, 2017, 06:03:56 pm »
Very Impressive , ton of work and a ton of patience , a credit to you , love seeing the progress  :thumb:
1969 GT350H
Offline unilec5544
  • Name: Neil.
« Reply #48 on: January 17, 2017, 10:48:22 am »
Hey Paul, just a question about the dash conversion, my 69 has no vents in the dash, although I have bought vents for it. Can I just cut the vent holes into my existing dash to fit the vents in, or is there an issue with that?
Thanks, Neil.
Offline paulb
« Reply #49 on: January 17, 2017, 09:52:24 pm »
Thanks, Neil.
Hi Neil,  you could probably cut them out, would probably be easier getting one that already had them, if your is left hand drive?  Most that convert to r/h use non air dashes, makes it easier but steering wheel sits off centre, I converted mine so that it sits centre
