Does anyone know the torque setting for the camber pin nuts?
Author Topic: Does anyone know the torque setting for the camber pin nuts?  (Read 8447 times)
Offline Mustangpaul
  • Look before you leap
Hello after half a dozen wheel alignments and discovering the camber pin nuts were stripped I would like to tell the mechanic what to torque them to . Does anyone know the torque setting for the camber pin nuts please?
Offline mert
Re: Does anyone know the torque setting for the camber pin nuts?
« Reply #1 on: September 07, 2015, 07:08:09 pm »
68 shop manual - lower arm to underbody 75-100 lb-ft
Offline Mustangpaul
« Reply #2 on: September 08, 2015, 08:48:36 am »
Thanks got that, the real problem was that the aftermarket camber pins ahd a short thread ans therefor would never tighten enough, they just ran out of thread, that problem is fixed well, now,
Paul
« Reply #3 on: September 21, 2015, 08:10:54 pm »
I only use K-mac brand heavy duty bolts, XY falcon ones. Washers are twice as thick and nuts are double length.
Offline Mustangpaul
« Reply #4 on: September 22, 2015, 09:16:19 am »
Normally I would say that advice makes cents, but your advice is so good it makes dollars :thumb:
