Looking for a carter X fuel pump and distributor for a 1970 Boss 302
Author Topic: Looking for a carter X fuel pump and distributor for a 1970 Boss 302  (Read 7601 times)
Hi all, my Boss 302 has a build date of 5 November 1969. I am seeking a dizzy and fuel pump for it in case someone on the forum has these. Appreciate any assistance.
Mark
Offline Shermatt
 :ouch: geezus T-rex...dont hurt the man  :grin:
now get back to googlin 427, 412, 408 super chargers and chase that front cut  :smash:
Matt
that Carter X fuel pump from Okeeracer is wrong - it's a Carbureter housing, not a Carter.
I make reproduction Carter X fuel pumps for Boss 302's, 428CJ's, 429CJ's, 65/66 K-Codes so I can make one date coded for your car if you like?
428CJ or Boss 302 Carter X fuel pump, $350 plus shipping
Here's an example of a 428CJ one I did recently:
Here's the 4441S (obviously a B2 is 4910S...
Date code
Here's a few pics of my '66 K-Code or Shelby GT350 pumps. '65 have the screw-on can on the bottom, just waiting for some to come in, I'll post pics of them when they're available...
'66 4201S
Black ‘63.5 Galaxie 4SPD fastback (422chp/
493 clbft.)
Thanks Pegasus. I am a bit wary of the Boss 302 dizzys and fuel pumps listed on ebay because of the comments I have seen on the Boss forum about copies being passed off as real. I appreciate the links however. If I see one that I am interested in that is not exorbitant in price I will get some advice from the forum experts.
« Last Edit: April 29, 2013, 12:27:00 pm by mwizz »
Hi Jiffy, I saw your original message on the Boss forum and have kept you in mind. You do great work. I want to try and get a NOS one but if unsuccessful will be in contact.
Offline mert
and
... and as you note you are looking for date correct... these are pretty much mutually exclusive....  :smile01:
Have not seen a NOS X in a long time and if you found one for under $500-600 you would be lucky... most are remans... similar for dizzy's, an NOS one will be a grand easy...
You are right mert. Only this week I missed out on matching date code dizzy and carter fuel pump from a Boss forum member. Both for $1,700. He posted them online and they were gone in 15 minutes. Would have been perfect for me but I missed out.
Offline mert
 :thumb:  gotta be fast on those rare and hard to find parts.... and have deeeeepppp pockets!
Guess I was just a little bit low on my estimate!  :thud:
Offline Shermatt
jiffy
Mark and myself have discussed your pumps as an option if we cant hunt one down
Just got back from a week in the air. Called Sherm at Sunstate this morning....Should have it fired up this week
Matt
Offline blackthunder1970
  • Name: barry
hi mark
suggest to  you to buy a jiffy fuel pump you can not tell the difference
i have 2 on my cars and have an original sitting on the shelf which i paid 650 us dollars four years ago
you wont be disappionted jeff has alot of of his repo fuel pumps on high dollar cars
i know of 5 vic shelbys with them as well as bosses and cobrajet cars
cheers
barry
1970 brandy wine  427 cammer mach ch 1
1970 blue 428 cj mach 1
1970 blue 428 scj w code mach 1
1970 r code convertible 1 of 12
1970 gt 500 convertible replica
1969 shelby gt500 real one
used to own
2 66 fastbacks
69 boss 302 original paint yellow
69 boss 302 project
69 mach 1 428cj blue
69 mach1 428 scj red auto
69 mach1 428 scj black 4 speed
69 mach 1 351 4v auto
70 mach 428 cj matching number j white stripe
70 mach 1 428 cj grabber orange
70 mach1 428 cj auto white
70 mach1 428 cj auto white fully optioned
70 mach1 428 cj auto yellow original paint should have keep it
70 boss 302
Thanks Barry, I've got a couple of enquiries currently going in the states so will depend on that.
Offline mert
For a distributor you could try Tim O'Connnor.  He got me a correct '68 390, about as hard to find as a B302 one.  One year only and shared with 428's.
Also does top notch restorations if you find one needing some work.  Buy in the US, ship it to him, gets to you basically near new.
http://428cobrajetcars.com/
Thanks mert, I check his website from time to time as he generally has them listed in there. He charges about $1,800 for a B2 dizzy plus shipping
PM sent Jiffy
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
What's the difference between the Boss fuel pump and standard 302W pump from 1969?
I realise the housings are different.
The lever length also looks different, is the eccentric in a Boss engine different?
Difference in flowrate?
s
Re: Looking for a carter X fuel pump and distributor for a 1970 Boss 302
« Reply #17 on: February 17, 2015, 08:53:17 pm »
Flow-rate is probably higher, but you'd have to be seriously going some to use all the fuel from a standard pump. The pic above showing a complete are is for a 428CJ, a B2 pump looks the same but has an arm like the ones in the K-Code pumps pictured afterwards.
493 clbft.)
