302 Windsor help
Author Topic: 302 Windsor help  (Read 25398 times)
Offline shelby_mustro
  • Name: Ryan
Re: 302 Windsor help
« Reply #25 on: January 13, 2013, 08:49:15 pm »
hi
it was the gasket on the side I didnt change no4 piston area. Ill take both off put a nice set of heads and cam on to get me by. yes well there is only one way u can put that gasket on.
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
« Reply #26 on: January 14, 2013, 01:30:44 pm »
hi
You'd be surprised how many windsor gaskets end up on back to front. All good.
  • Name: Ryan
« Reply #27 on: January 26, 2013, 11:42:12 am »
it's hard to miss the gasket has front on it. with the felpro gaskets does the colour gray and blue part face the top? the underneath is black so I'm guess this sits on the block side. how many ft pounds dose the heads needs to be wrenched up at?
t5 5 speed manual
Other cars
« Reply #28 on: January 26, 2013, 12:54:53 pm »
70 lbs in 3 stages 25,50 then 70 lbs .2 centre bolts 1st working your way out both sides .blue black grey gaskets really ,got me.
  • Name: Ryan
« Reply #29 on: January 26, 2013, 07:36:16 pm »
Glenn ill be around tomorrow your more then welcome to pop in if you have time tomorrow.
t5 5 speed manual
Other cars
« Reply #30 on: January 26, 2013, 08:11:20 pm »
ok ,but will see what the weather is like .not good they say .
  • Name: Ryan
« Reply #31 on: February 03, 2013, 10:40:38 am »
Well got the car running yereseterday and another problem
 Has come out.  My breaking system has locked up. just got harder and harder. had to push the motor which over heated it trying to get home on it. Has a break booster double master cylinder and xy disc on front and xf on the rear.
t5 5 speed manual
Other cars
Offline EXHAUSTED
  • Nearly retired
« Reply #32 on: February 03, 2013, 11:01:03 am »
Loosen the nuts holding the cyl to the booster & see if the brakes free up. Might not have enough free play between them, faulty master cyl, brake hose collapsing. You need to determine if it is one brake or all the brakes that are holding on !! Have you checked your pedal clearance (shaft to booster) under the dash.
« Reply #33 on: February 03, 2013, 06:46:49 pm »
It will be the brake booster ,there is a plastic piece inside were the arm comes out that fits onto the brake pedal,it brakes ,then your brakes will be so touchy, then they slowly lock on ,aftermarket boosters only .You can back off the master cyl nuts a little to get home ,but you need a new booster .They can split the booster and fix but just buy a new one .
  • Name: Ryan
« Reply #34 on: February 03, 2013, 08:30:08 pm »
It's defentaltly the break booster. I loosened up the two bolts to the master cyl and it did free up.
t5 5 speed manual
Other cars
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #35 on: February 03, 2013, 08:53:42 pm »
Glenn is correct it has possibly shattered the reaction disc in the booster.
If the reaction disc has failed the brakes will tend to have no modulation control, they will be very grabby almost all on or off.
You should be able to pull out the circlip and seal and pull the pushrod out of the booster,
the reaction disc sits on the bottom of the pushrod. (between pushrod and booster internals)
Very common fault on Falcons.
Peter.
  • Name: Ryan
« Reply #36 on: February 03, 2013, 10:36:52 pm »
Well it's a. 3 week wait to get one from cal customs they are $180 not to bad.
t5 5 speed manual
Other cars
« Reply #37 on: February 04, 2013, 09:56:01 am »
theres a CIRCLIP  there which keeps ur plunger in,,,,i had one break on me
be worthwhile to take out booster,,see wats happening in thar
Not if it's a falcon master and I think it is, the booster holds the piston in.
« Reply #38 on: February 04, 2013, 02:01:40 pm »
No it is an after market one from cal custom .
Offline Ford Compact 1963
« Reply #39 on: October 27, 2013, 08:07:05 pm »
Good work glen
