CAR POLISH
Author Topic: CAR POLISH  (Read 387837 times)
Offline 69candy
Re: CAR POLISH
« Reply #125 on: November 04, 2012, 09:01:59 pm »
OK. Will order the six of them.
Reserved so far
Rocket 1
Dale 1
Scedd1 ( Steve )  1
That leaves 3 more - first in best dressed.
Here is the Link for those interested -
http://www.aliexpress.com/item/New-710W-Dual-Action-Machine-Car-Polisher-Buffer-Sander/465867090.html
By ordering the 6 - cost will be $116.53. Pick up from Pooraka SA or will post interstate or country for you as long as you pay for the postage.
Jeremy, Glad to hear from you. Sounds like you are enjoying SEMA :cheers: :cheers: :cheers: :cheers: Mum said to say hi to Monique
The polishing machine you are talking about is the Flex XC 3401 VRG. But be careful. The Americans use a different power system. So the Flex we need is called the Export model which is 230 volt. If they have it at SEMA can you grab me one and i will fix you up when you return. Will put the Link from mwizz ( Mark ) up shortly.
Edit - here is the Link from Mark -
http://www.toolking.com/flex-xc3401vrgcee-variable-speed-dual-action-orbital-polisher-230-volt#
Your blue Mach1 is finished. Here are the photos i took earlier -
Rocket ( aka Dad ).
G/day mate. Can you put me down for 1 as well if possible??. I will work out how to get it down to me in the South East. or pick up when I'm in town next.
Let me know.
cheers
« Last Edit: November 06, 2017, 05:30:53 pm by peterp »
Offline rocket
  • MOCSA Member No. 894
    • Image Classic Cars
Re: CAR POLISH
« Reply #126 on: November 04, 2012, 09:17:44 pm »
Hi 69candy, Will put you down for one. So now we have
Rocket
Hertz66
scedd1
69candy
That takes care of 4 machines. Just 2 more left to be placed. Here is the link again
Rocket.
Check out our new Website
Offline rocket
Re: CAR POLISH
« Reply #127 on: November 04, 2012, 09:28:23 pm »
The princess has a year old SS Commodore in the new Chlorophyll colour (blue in the sun, green in the shade).
It lives in the garage and has 5,000kms on the clock.
We will keep it for about 5 years/ 25,000kms.
Would this sealant be suitable for the factory paint, which seems to be a top quality job to me?
My main aim is to avoid washing and polishing, as i am a lazy bastard, even though i am getting the fancy polisher.
Steve
Steve, Yes... The Sealant will protect your paint - for a while. But remember, Sealants do wear out after a few months and require topping up. I would give the Jetseal 109 a top up of 2 coats every 6 months. Application of a Sealant will make it much easier to wash the car, but a weekly wash is still required. I wonder if a 3 monthly Wax would be better for you - less work. There is a fantastic Wax called DP MaxWax available from Waxit.com.au for about $40 Easy on, easy off. Not much work for a great finish.
Rocket.
Offline rocket
Re: CAR POLISH
« Reply #128 on: November 04, 2012, 09:56:19 pm »
Thanks Rocket will definitely take it on board but just to confirm what is the main differences when polishing old paint and a car which has just been painted.
Normally I am a Meguirs person who goes with the hand polishing of vehicle were I can go around the car up to 5 times including the washing & drying
Herman
You must be very fit Herman!
I came across this gem while checking out good polishes to use by hand  " Personally, i have trouble moving my hand at over 1,000 RPM - so i use a polishing machine ". :grin:
Differences in polishing old or new paint?
If the old paint is oxidised , generally it would require a more aggressive first step compound. Something like Menzerna PF 1000 or Meguiars ScratchX, or Meguiuars Megs105 . After that first step i would still use my 3 favourites Menzerna PF 2500, SF4000 and SF4500 .
Of course you need to be a bit careful. You do not know how thin the old paint is, so it is wise to do a test using the rule of thumb, start with a light polish and see how it goes, then work up to the aggressive polish/ pad combinations till you find the right combo that will do the job in the quickest time.
You will find that Acrylic Lacqeur paints without clear coat will leave a lot of paint on your polish applicator, but with 2 pak paints you will not see any paint on your applicator.
Regarding best polishes to use by hand - Gretschem suggests TCut, Farecla G6, Juice Swirl remover. Others i have seen recommended via a google search which have a slight abrasive and easy to work by hand are Megs no. 80 followed by Megs no.81.   Megs 105 followed by Megs 206.    Zaino ZPC.    Duragloss DG501 is another.
Here is an excellent Thread by Mike Phillips at Autogeek Titled " Man V Machine "
http://www.autogeekonline.net/forum/hot-topics-frequently-asked-questions/20257-man-versus-machine.html
Rocket.
« Last Edit: November 04, 2012, 11:24:08 pm by rocket »
Offline 69candy
Re: CAR POLISH
« Reply #129 on: November 04, 2012, 10:07:48 pm »
Rocket
Hertz66
scedd1
69candy
Rocket.
Cheers Mate. Any idea when you will have them??
Offline rocket
Re: CAR POLISH
« Reply #130 on: November 04, 2012, 11:23:24 pm »
Ordered them on Saturday and was informed 10 working days
Will advise when they arrive and will do a test straight away to see how good they are. Watch for pics and maybe a YouTube Video.
Rocket.
Offline 6R07K
Re: CAR POLISH
« Reply #131 on: November 05, 2012, 01:41:30 am »
Great thread, got my bottle of jetseal109 last week and keen to give it a go rather then the 3 coats of wax like normal.
I recommend Dodo Juice born slippy, its a concentrate you mix up to use as lube when claying. With the other off the shelf products I have used found myself needing to reapply before finished working the area. But with born slippy you can work away and it doesn't dissipate.
Purple is the go for polishing up those chrome bumpers on our mustangs.
Tend to get most my stuff from http://www.carcareproducts.com.au/ as they have a big range, prices are fair and being on the opposite side of the country their delivery is quick.
Ben
Lifes short, play hard.
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
  • Name: Dale
Re: CAR POLISH
« Reply #132 on: November 05, 2012, 10:35:49 am »
Rocket.
Rocket get our money first...if its crap none of us will want it........  :grin: :grin: :grin:
Paint by IMAGE CLASSIC CARS
Re: CAR POLISH
« Reply #133 on: November 05, 2012, 11:07:13 am »
Gee when i asked what polish to use on my stang i thought someone would  just  say turtle wax . Been very interesting thanks ,GLENN 70 .
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
Re: CAR POLISH
« Reply #134 on: November 05, 2012, 11:31:14 am »
Back in 1970 you washed your car and applied Turtle Wax, that was it for most of us.
Now there's a whole world of products and applications.
s
Re: CAR POLISH
« Reply #135 on: November 05, 2012, 12:00:08 pm »
Maybe for you and the others but 1970 i was cleaning my pushbike .  :grin: :grin:
Offline 66 Hertz
  • Web Editor
  • Name: Dale
Re: CAR POLISH
« Reply #136 on: November 05, 2012, 12:06:13 pm »
  Me too, my dragster with the three speed shifter & sissy bar at the rear...  :thumb:
« Last Edit: November 05, 2012, 12:09:10 pm by 66 Hertz »
Offline rocket
Re: CAR POLISH
« Reply #137 on: November 05, 2012, 01:02:41 pm »
Dale, A bit of creative editing and all is well. :grin: :grin:
Seriously though, I have a hunch that these type of machines all come out of the same factory. Creative colour changes and badge engineering.
In any case i will offer a concrete warranty - once they are off our concrete - all yours for better or worse. :grin:
Rocket.
Re: CAR POLISH
« Reply #138 on: November 05, 2012, 01:20:24 pm »
My dragster had twin mirrors and a head light .HA HA .AND I USE TO TURTLE WAX IT .
Offline Herman
Re: CAR POLISH
« Reply #139 on: November 05, 2012, 10:03:46 pm »
Nah not fit just didn't know any better until now  :thumb:
Offline rocket
Re: CAR POLISH
« Reply #140 on: November 07, 2012, 07:35:33 pm »
Does that mean you are becoming a convert to machine polishing? :hi:
Received notification that the 6 polishing machines were shipped today. Hopefully they will be here mid next week. Question now is - which car to try one out on. Maybe Moniques Convertible or Jeremys Fastback.
Then again, might be best to try it out on a Holden first :grin: :sick:
Rocket.
Offline Herman
Re: CAR POLISH
« Reply #141 on: November 07, 2012, 07:37:52 pm »
I could be as it will save me a lot time and effort  :evilone:
Offline evan
Re: CAR POLISH
« Reply #142 on: November 07, 2012, 08:14:57 pm »
Herman's pretty good with his hands. Just look at his avatar  :grin:
Evan.
Offline Fast69back
Re: CAR POLISH
« Reply #143 on: November 07, 2012, 08:29:57 pm »
Hi Rocket, If you have any of those polishers left, can you put my name on one please.
Cheers Vic.
Offline rocket
Re: CAR POLISH
« Reply #144 on: November 07, 2012, 08:42:41 pm »
Evan.
Ahhhh... I see.   Herman - just what are you polishing in that photo? :bolt:
Offline rocket
Re: CAR POLISH
« Reply #145 on: November 07, 2012, 08:46:30 pm »
Cheers Vic.
Hi Fast69back, Your name is added. Which State are you located?
That means 5 are now placed. Who wants to be the lucky last? Only one more available.
List is -
Rocket
66Hertz
scedd1
69candy
Fast69back
Rocket.
Offline Fast69back
Re: CAR POLISH
« Reply #146 on: November 07, 2012, 08:54:52 pm »
Hi Rocket, Thanks for that. I'm in Queensland. Just let me know cost+post and handling and I will direct deposit your bank account.
Vic.
Offline rocket
Re: CAR POLISH
« Reply #147 on: November 07, 2012, 09:06:37 pm »
 Hi Vic, No worries. Will do.
Thanks.
Remember guys, last unit goes to first person requesting it on this Thread.
Rocket.
Offline MachAttack
Re: CAR POLISH
« Reply #148 on: November 07, 2012, 09:55:18 pm »
Rocket.
Put me down for one Rocket, I'll try it out on this one for you  :grin::
I can direct deposit or paypal.
Thanks.
Offline shelbyright
Re: CAR POLISH
« Reply #149 on: November 07, 2012, 10:08:51 pm »
So what car polish do you use on your stang . Whats the best polish you have used .
this is a fantastic thread, im a little concerned about having a go myself on the supersnake. so does anyone know a good detailer?.maybe you rocket?
There are only 2 times in life, today or too late!
