How to post your Avatar
Started by peterp, August 05, 2012, 10:23:34 AM
Previous topic - Next topic
peterp
You can now upload your own Avatar through your profile.
Click on your Profile tab
On the left menu click on Forum Profile
Then click on Upload an Avatar
Browse to your computer to upload an Avatar.
TIP:  Try to keep the image size below 200 by 200 because the forum will resize it to that but if you upload larger images it will slow down your posts appearing.
Example:  a 1024 pixel image will still load at that size but will only be displayed at 200 pixels
peterp
Daz 67GTA
Went to change my Avatar and I now get the following:
Using my own from my PC as per above:
"The attachments upload directory is not writable. Your attachment or avatar cannot be saved"
and then the old way via Photobucket:
Image has moved or is not available..
I'm doing this all via Google Chrome...someone got any Ideas...an yes, I will try IE now.
Daz
'67 GTA Coupe
Mick Webb 351C
C10 w/2700 Hi-stall
Strange 9" w/Eaton Truetrac
66 Hertz
I had the same trouble so i asked PETER P to do it for me...............He's the Man!
Daz 67GTA
Cheers 66Hertz..
Thought I was going crazy....
Daz
'67 GTA Coupe
Mick Webb 351C
C10 w/2700 Hi-stall
peterp
All fixed now.
You can upload your own avatar.
Regards  Peterp
Daz 67GTA
Thanks Pete....working fine...as you can see! :cheers:
Daz
'67 GTA Coupe
Mick Webb 351C
C10 w/2700 Hi-stall
