brake warning switch
Author Topic: brake warning switch  (Read 3369 times)
Offline skev
« on: April 20, 2012, 08:24:37 am »
All I can is the early 67 ones had one pin and earthed through the distribution block when required, the newer ones added the.second pin/earth wire. Can you connect the live wire only to the switch,  then earth the other pin on the switch and check results?
67 Convertible
Offline 66coupe
  • Name: Felix
« Reply #1 on: April 20, 2012, 09:53:04 am »
Hi Skev,
For the light to work it appears the 2 pins need to be shorted out.
I have moved this article to tech torque
1965 TBIRD
1968 BUICK RIVIERA
1979 CM VALIANT
2002 HSV CLUBSPORT
2013 MAZDA 6
1969 Hillman Hunter
