68 302 windsor timing chain cover
Author Topic: 68 302 windsor timing chain cover  (Read 2803 times)
Offline 2+266
« on: October 15, 2010, 06:40:41 pm »
hi guys chasing a C8AE 6059A timing chain cover NOS or one in great nic,thanks
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #1 on: October 15, 2010, 11:22:09 pm »
Hi, doesn't sound like what you are after, but CPC make a repro of the 68-73 cover, with the correct markings etc. It is not the same as the cover offered by Scott Drake, which is a nice aftermarket unit, but not a reproduction of an original.
I don't have a 67-73 repro in stock, but I do have the Repro 64-67, and it is quite nice. I also carry aftermarket ones, if anyone else is interested.
I will have a repro 68 onwards one on my next order.
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline 2+266
« Reply #2 on: October 16, 2010, 08:27:07 am »
thanks BLKPNY,have seen those CPC ones,very well manufactured,might have to go down that path if i cannot source what i need ,cheers
Offline DUNRITE66
« Reply #3 on: October 17, 2010, 12:09:05 pm »
Quote from: 2+266 link=topic=12559.msg131910#msg131910
we pulled down an engine a little while ago and put stuff away....i have a timing cover in a box at work which came off that  windsor....if i go past later i will check numbers and see if it is what you are looking for.....
