Need Help Stolen Mustang
Author Topic: Need Help Stolen Mustang  (Read 15112 times)
Offline peterp
  • Administrator
« on: October 05, 2010, 07:29:45 pm »
Stolen Mustang 2+2 Fastback
September 26th 2010
Fully restored 1966 Mustang 2+2 Fastback Shelby GT350 Clone
Red with white stripes
Registed Number BMV-76P
Chassis Number 6T09A133442
Engine Number A133442
If you have seen this vehicle contact webeditor@nsw.mustang.org.au & the infomation will be passed onto the police.
peterp
Offline MustangNut
« Reply #1 on: October 05, 2010, 07:35:43 pm »
Basterds! where was it stolen from Peter?
Offline peterp
  • Administrator
« Reply #2 on: October 05, 2010, 09:13:12 pm »
I have requested more information on the incident and should be able to post more information in the morning.
I just hope it turns up for the owner.
peterp
Offline pala
« Reply #3 on: October 05, 2010, 09:56:42 pm »
I see this and it really sh*ts me when this happens
Offline peterp
  • Administrator
« Reply #4 on: October 05, 2010, 09:58:38 pm »
Apparently our webmaster received the information from the Police in the hope that we would give it some publicity.
The car was stolen somewhere in NSW.
At this point that is all we know.
peterp
Offline ponyride
« Reply #5 on: October 05, 2010, 10:46:51 pm »
It would be handy if we could find out what sort of anti theft measures stolen cars have, so we can all learn what works and doesn't, and what the thieves are able to get around.
Rick
Offline peterp
  • Administrator
« Reply #6 on: October 06, 2010, 07:05:21 am »
It seems that most theft devices are useless against the professional thieves.
One old habit that I used years ago was when I parked the car I put the front wheels on full lock then used a steering lock to make it difficult to tow from the rear.
But that said it still doesn't stop these new flat top towing trucks from dragging it onto their tray.
I would think that a GPS location system would be a minimum requirement for peace of mind.
Maybe other members might have some tips on this problem.
peterp
Offline derwin66
« Reply #7 on: October 06, 2010, 11:07:21 am »
The car was stolen outside of a hot rod show at leumeah on the 26.9.10 at about lunchtime
65 T code coupe.
Blown 302. Heidts suspension, tricked C4
Gear vendors overdrive, RRS rack and pinion
Street or track roller perches adjustable struts.
60 F100.
Warm 289, AOD
Offline GT350H
« Reply #8 on: October 08, 2010, 09:01:02 pm »
That makes me sick in the stomach
AKA Emberglo-66
Offline donoauto
« Reply #9 on: October 09, 2010, 06:59:09 am »
Quote from: ponyride link=topic=12465.msg131043#msg131043
Every car can be stolen! We just have to try & slow them down as much as possible. Only thing that works is not to let it out of your sight & make sure insurance is high enough to buy you another of the same quality.
Regards ,
    Mark.
Auto-electrician & car A/C guy.
Offline Moz
« Reply #10 on: February 27, 2012, 10:13:17 pm »
How about this
This is what I installed on the Joker
« Last Edit: August 05, 2012, 04:49:11 pm by peterp »
Offline Meaty0
« Reply #11 on: February 27, 2012, 11:14:34 pm »
Stolen two years ago.  Hmm.  I wonder if they got it back?
If it's worth owning, it's had a song written about it.
Offline ejmustang
« Reply #12 on: February 28, 2012, 12:26:17 pm »
I was wondering that too!! be nice if we knew if these stolen cars are ever found in whatever condition .:hammer:
Offline Mustangpaul
  • Look before you leap
« Reply #13 on: February 28, 2012, 02:36:06 pm »
The Vins' are on battery aprons and if those are replaced, what other numbers will you trace? Engine numbers were not recorded in USA to my knowledge. The thieves are no doubt replacing the battery aprons with the aprons from a project and away they go. Bring on the good old fashioned Microdot technology.
Offline gt350 coupe clone
« Reply #14 on: February 28, 2012, 05:15:48 pm »
it is sad to say but prob a parts car or has been re birthed
I dont believe that it will turn up
as I said guys I work in this field anything can be stolen even if it is on a flat bed
I will be looking at a GPS tracker for my car
Can't wait to get it finished and enjoy it ! They need to have overhaulin here in Aus!!
Offline Top.cat7
  • 1965 GT 289 "K" Code
« Reply #15 on: June 05, 2012, 05:25:58 pm »
I can recall reading that in the UK there was a GPS/engine immobilizer that could be fitted to any vehicle for about $A700.00 (10 years ago). I recall thinking that if you were 'filling up' and 'Joyriders' came along, you could make a 'phone call to one central point and give them an 'authenticating' code and they would immobilize the engine, which caused a 'splutter' and a thirty second 'delay' so that the driver could pull over, and then the engine would 'die'. Also, the location would be available via the inbuilt GPS tracker for the Police to round them up, if they had hidden the vehicle in a shed or container.
I cannot believe that it is not mandatory for all new vehicles to be fitted with them.
I don't know if they are available in Australia or if there is a central 24/7 'command',  with the appropriate Satellite, to contact if you did purchase one.
Perhaps someone else knows.
Offline Top.cat7
« Reply #16 on: June 17, 2012, 09:30:24 pm »
