9" diff yoke
Author Topic: 9" diff yoke  (Read 3023 times)
Offline edd666
  • Name: Eddie
9" diff yoke
« on: September 07, 2010, 07:32:05 pm »
Hi im after a 9" 1310 series diff yoke that takes the smaller type universal if anyone has one for sale Cheers Eddie.
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
9" diff yoke
« Reply #1 on: September 07, 2010, 08:19:10 pm »
There are a few different length yokes, what one do you need?
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline edd666
  • Name: Eddie
9" diff yoke
« Reply #2 on: September 07, 2010, 08:41:19 pm »
My old one is about 100mm Im going from 8" to 9" and will be  using the same tailshaft but the 9" is a bigger unit is there a shorter one
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
9" diff yoke
« Reply #3 on: September 07, 2010, 08:47:37 pm »
I think the shortest was about 4", but I have a few here that are longer.
Your old uni will be smaller than the 1310, have you got a new hybrid uni yet?
Custom Mustangs
Signature Sponsor
Offline edd666
  • Name: Eddie
9" diff yoke
« Reply #4 on: September 07, 2010, 09:08:23 pm »
No i dont as the uni measurements of the 1310 uni was width 3.219" and bearing cap dia 1.0625 looked to measure up the same as my 8 " uni was under the impression they were the same but differ from the 1330 and the 1350
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
9" diff yoke
« Reply #5 on: September 07, 2010, 09:14:15 pm »
My 8" uni was skinnier than the 1310 uni. The 1310 is about 82mm wide, my 8" uni was about 3-4 mm less. The strap won't hold it well enough.
Custom Mustangs
Signature Sponsor
Offline edd666
  • Name: Eddie
9" diff yoke
« Reply #6 on: September 07, 2010, 09:21:32 pm »
Whats the best solution do you know if there is a uni with 2 different cap sizes
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
9" diff yoke
« Reply #7 on: September 07, 2010, 09:37:45 pm »
You may be able to get a hybrid uni, you'd have to take the measurements to the Bearing shop.
I'd just get the tailshaft done, they can shorten it, change the rear yoke or whatever, or build you a proper one, with real size uni's front & back, and with real tube, not the cannaloni like the originals.
Custom Mustangs
Signature Sponsor
Offline edd666
  • Name: Eddie
9" diff yoke
« Reply #8 on: September 07, 2010, 09:50:07 pm »
I think i will still need that shorter yoke anyway and then i can sort the tailshaft to suit you dont have the short one you said
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
9" diff yoke
« Reply #9 on: September 07, 2010, 10:13:08 pm »
I'll have to look. What yolk is on your 9"?
Custom Mustangs
Signature Sponsor
Offline edd666
  • Name: Eddie
9" diff yoke
« Reply #10 on: September 08, 2010, 06:38:34 am »
Cheers for that i dont have one at the moment
