Ford Mustang Instrument Panel Troubleshooting
Author Topic: Ford Mustang Instrument Panel Troubleshooting  (Read 68848 times)
CPU
  • Guest
CPU
« on: August 30, 2010, 09:07:19 pm »
Get Your Mustang's Gauges Back On Track By Understanding How They Work
From the May, 2010 issue of Mustang Monthly
By Jim Smart
Photography by Jim Smart
[align=center]
[/align]
If you've driven classic Mustangs for any time at all, you know that their instrument panels go haywire from time to time. Thankfully, Mustang instruments are easy to diagnose and fix once you learn how they work. Aside from the speedometer, which is mechanical and cable-driven, Mustang instruments are all electrical in function. And that's what we're going to talk about here.
Mustang instrument function tends to be about resistance to the flow of electricity across a circuit to achieve a given function. This resistance, also called ohms, creates heat. It also controls how fast something operates or how brightly. Ohms are an important element to understand when you're checking resistance values in a circuit.
Temperature, Oil, and Fuel
Temperature, oil pressure, and fuel quantity gauges operate on five-volts of regulated current thanks to a small voltage regulator on the back of the instrument panel, also known as a voltage limiter or voltage reducer. Inside, the voltage regulator has a bimetallic arm and heating element (resistor). It is this balance of heating element and bimetallic arm with contact points that regulates current flow to your instruments in half-second pulses of electricity. Voltage regulators fail when contact points burn and pit or the resistor burns out and doesn't get warm anymore. "Bimetallic" means two metals - two dissimilar metals that expand and contract at different rates to open and close contact points inside the voltage regulator. It is a micro-fine, constant pulsing process of contact points that keeps voltage close to five volts. Because vintage Mustangs were born in the age of AM radio, this pulsing causes radio interference. A radio noise suppression choke wired in series with the constant voltage supply lead reduces the noise.
[align=center]
Mustang temperature, oil pressure, and fuel gauges are all the same inside. Only the faces and senders differ
[/align]
These five-volts of regulated current from the voltage limiter flow through your instruments, which have their own unique function inside. Temperature, oil pressure, and fuel quantity gauges are all identical instruments behind the face, although they have different sending units and faces. All sending units, which are variable resistors (also called rheostats or potentiometers), do the same basic thing. They vary current flow to negative ground to provide readings on the instruments. When current flow is high to ground, instruments read high. And when current flow to ground is low, instruments read low. Each gauge's sending unit works like the volume control on your stereo or dimmer switch. Raise the volume or brighten the light and you are reducing resistance to current flow (low ohmage). Lower volume or dim lights and you are increasing resistance to current flow (high ohmage).
Each instrument (except ammeter) works similar to the voltage regulator - heat and its effect on dissimilar metals cause an immediate expansion along with needle movement. Each gauge has a bimetallic band tied to the needle. And each has a heating element (resistor) designed to act on the bimetallic spring and needle. When current flow across the heating element increases along with corresponding temperature, the bimetallic spring expands, moving the needle higher on the gauge face. When current flow is low, the heating element cools, causing the bimetallic spring to contract, moving the needle back to the left. When you turn the ignition off, current flow stops altogether, causing instrument heating elements to cool and returning needles to rest. These bimetallic springs are very sensitive so they respond quickly to temperature change.
[align=center]
This is a typical voltage regulator, which can be found on the back of Mustang instrument panels. Twelve volts enter and approximately five volts exit to provide regulated instrument voltage. When instruments stop working, most of the time it's a faulty voltage regulator. Word to the wise is to use a genuine Motorcraft voltage regulator because some aftermarket replacements have proven troublesome. Trouble-free, solid-state voltage regulators are also available
[/align]
Each sending unit varies resistance to current flow to negative ground. The coolant temperature sender in your engine's water jacket has an electrical conducting spring, temperature sensing element, and heat conducting disc inside. Like other sending units, it operates on variable resistance. When you start a cold engine, current flow across the temperature gauge is nil and the needle remains on "L." As the coolant warms, resistance across the sender decreases, allowing more current flow to ground from the gauge. As resistance decreases with heat, current flow across the instrument increases to move the needle higher.
[align=center]
Each instrument has two posts-one with five volts of power (positive) and one to sender (negative ground)
Here's what the inside of a temperature, oil pressure, and fuel gauge looks like. Two elements contribute to gauge function-a bimetallic strip and heating element (resistor). As current flows through the resistor (heating element), it gets warm. As it warms, it acts on the bimetallic strip attached to the needle (by expanding), causing the needle to move to the right. The geared elements are the instrument's calibration points.
As you face the back of the gauge, there are two calibration points. Lower left is adjusted with the ignition off to find true "zero"-"E" on a fuel gauge or "L" on a coolant temperature or oil pressure gauge. Upper right is adjusted with the ignition on with five volts of power to the gauge. This is where you adjust the needle for actual conditions. For example, "F" for a full tank or normal range with engine operating temperature at approximately 180-200 degrees F. Same is true for oil pressure.
Here are two voltage regulators. On the right is '65-'68 Mustang. On the left is '69-up as used on printed circuit instrument panels.
Here, a coolant temperature sender is checked for proper operation by submerging in hot water. At 180 degrees, there should be approximately 40 ohms of resistance, which would put the needle in the normal range.
Oil pressure senders should read 24-36 ohms of resistance at 8 psi or less and 8.0 to 17.5 ohms at 90 psi (gauged maxed out). Here, at 39.8 ohms of resistance, we're just starting to make pressure. This test is performed using air pressure. You can also conduct this test on the engine with the engine running.
[/align]
Oil pressure senders work the same way, only with spring-loaded variable resistors instead of a bimetallic contact. Oil pressure acts on the piston and resistor. When there's low oil pressure, there's high resistance to ground and current flow to ground is low, which makes the instrument read low. When pressure is higher, there's less resistance across the sender and oil pressure reads higher.
Fuel quantity works the same way, only with a float in the tank with a variable resistor. When fuel is low, resistance across the sender to ground is high and the gauge reads low. Fill up the tank and the float rises, reducing resistance across the sender and increasing current flow to ground, which makes the gauge register "Full."
[align=center]
Vintage Mustang oil pressure senders look like this. On the left is the larger sending unit for gauge use. The smaller unit on the right is for warning lights. The larger sender is a variable resistor, which varies gauge reading depending on oil pressure. The smaller unit is a simple on/off switch, which closes (oil light comes on) at 3 to 7.5 psi oil pressure.
[/align]
Idiot Lights
Warning lights, also affectionately known as "idiot" lights, are simple in scope and easy to troubleshoot. A coolant or oil pressure warning light works off a grounding "on/off" sender, which is either open or closed. When it is closed, the warning light illuminates. When open, the light is off. A coolant temperature light (TEMP) closes at a specific temperature, typically around 210 degrees F. Like a coolant temperature sender for a gauge, there's a bimetallic switch inside. However, instead of a variable resistor, it's a simple on/off function with contact points. An oil pressure light illuminates at 10 psi when contacts close to illuminate the OIL light. When you start the engine, oil pressure is low and the switch is closed. The oil pressure builds right away, contacts open, and the light goes out.
[align=center]
Coolant temperature sender resistance test shows 277.7 ohms cold, which is a lot of resistance. The gauge reading would be "C," for Cold, because there's virtually no power flowing across the gauge. Recommended resistance is 125 ohms cold for '65-'69 and 175 ohms for '70-'73. In actual practice, it doesn't make much difference.
[/align]
GEN/ALT lights work an entirely different way. When the ignition is on with the engine off, power flows through the ALT light and a parallel 15-ohm resistor (shunt) through the voltage limiter contacts to the alternator field. The voltage limiter is inside the voltage regulator. Battery voltage through the light is enough to allow the alternator to make electricity once the engine is started. The ALT light is shunted via the 15-ohm resistor just mentioned. When the engine is started, enough voltage is made to close the field relay contacts in the regulator, causing the ALT light to go out.
With generator charging systems, the GEN light is connected between the armature terminal on the voltage regulator and the coil terminal on the ignition switch. This makes the GEN light an integral part of the circuit where it is in parallel with the voltage regulator contact points. If the ignition is turned on with the engine off, the voltage regulator contacts will be open and the GEN light will illuminate. When the engine is started, the regulator contacts close. Power then bypasses the GEN light and the light goes out.
[align=center]
Checking a coolant temperature sender on the vehicle shows 385.3 ohms or high resistance. Again there's no instrument response-or needle on "C."
[/align]
ALT and GEN warning lights are simple to understand and troubleshoot based on the previous description. These warning lights illuminate only when the battery isn't being charged. When they become inoperative, it's typically a burned out bulb or a break in the wiring. Keep the black/yellow wire (37) squarely in mind and you can't miss.
Ammeter
Ammeter, as its name implies, monitors or measures amperage flow in and out of the battery via the alternator. It does not measure battery voltage like a voltmeter. As the alternator charges the battery, an ammeter reflects this charging process as the needle swings right. As the battery discharges, the ammeter also shows this process as its needle swings left. It all happens via a magnetic field caused by the flow of current across the ammeter. Two basic types of ammeters have been employed in classic Mustangs. In '65, Mustangs had an induction-style ammeter with no connections, only an induction loop (also called a magnetic loop) on the back of the ammeter that picks up current flow (magnetic field) through the main power lead.
[align=center]
Here's an oil pressure sender for a warning light. With no pressure, there's virtually no resistance at 4.8 ohms, which means we'd get an "OIL" light. The oil pressure light should illuminate at 3 to 7.5 psi.
[/align]
For '66 and beyond, Ford thought it had a better idea in its shunt-style ammeter where two leads - red and yellow in color - bring current through the ammeter. The red lead goes to the battery and yellow to the alternator. The problem with these post-'65 ammeters is that they weren't durable enough for the demand. Most burned up and failed early in their service life, which is why your ammeter needle probably never moves. We looked at many '66-'73 Mustang ammeters in the used parts inventory at Mustangs Etc. and were amazed at how many of them had burned up and failed. Most do not work.
[align=center]
Coolant temperature senders vary from generation to generation. On the left is '71-'73. On the right is '65-'70, which is smaller with a single, larger pin.
Here are two basic types of Mustang ammeters-induction-style on the left with an induction loop ('65 only) and shunt-style on the right with two posts for '66-up. Although the induction-style isn't as sensitive, it is safer and more reliable
Here's the '65 induction-style ammeter installed with the main power lead (37, black/yellow) passing through. This is how an induction-style ammeter "senses" current flow. There are no connections, only the main power lead passing through the induction loop.
This is a '66-up shunt-style ammeter where alternator/battery power flows right through the instrument. When these ammeters work, they're quite sensitive to charge and discharge.....
....Problem is, very few of them have continued to function through the years because they didn't stand up to electrical load very well. This one has burned up and no longer functions. Fragile wiring became so hot it failed.
Here, we're checking a shunt-style ammeter for continuity. Because there's a break in the wiring, the multimeter shows no continuity.
[/align]
So what's the fix for burned out ammeters? There really isn't one short of having yours converted to a voltmeter by Auto Instruments. Auto Instruments can convert your ammeter to a voltmeter so the needle is centered when everything is normal (around 12-14 volts). We've learned from Ray Sanchez at Mustangs Etc. that classic Mustang shunt-style ammeters are problematic and can be an unsafe fire risk because they're live all the time and not protected with a fuse or fusible link. This is why it's a good idea to have Auto Instruments do a voltmeter conversion, which makes things reliable and safe.
[align=center]
For '66 and later Mustangs, the connection between alternator and battery passes through the ammeter. Red goes to the battery (655). Yellow (654) goes to the alternator. If you opt for a high-amp alternator, it will damage your ammeter. In that case, bypass the ammeter.
[/align]
Tachometer
Your Mustang's tachometer gives an rpm readout based on frequency of ignition point closures. As engine rpm increases, the greater the frequency of these closures per minute along with a higher tachometer reading. The tachometer will have two leads - one red and one black. Red is a male plug that gets its power from the ignition switch, known as "switched" power. The black lead with a female plug goes to the positive side of the ignition coil. When tachometers fail, it's either a bad connection or a problem in the tachometer itself. Tachometers rarely fail. They're as reliable as oil, fuel, and coolant temperature gauges.
When a tachometer fails, the engine typically won't start either because the ignition coil gets its power via the tachometer. In fact, if you disconnect the factory tachometer, your engine will not start. Mustang factory tachometers get their signal via ignition points cycling (closing). With electronic ignition, the basic principle is the same - the cycling of coil collapses and spark plug firings.
[align=center]
Tachometer troubleshooting is simple. Check all connections; make sure you have power from the ignition switch (red), and make sure there's power from the tach (black) to the ignition coil (positive side).....
....Remember, if there's no power from the ignition switch or from the tach, the engine will not start. No start is your first clue.
[/align]
Tachometer service and calibration isn't something you should tackle yourself. When your tachometer becomes inoperative and all troubleshooting efforts are exhausted, we suggest sending it to Auto Instruments for service and calibration.
Questions and Answers
Problem: My gauges won't register with the ignition turned on. What's wrong?
Probable Solution: Replace the instrument voltage regulator.
Question: Can my instruments be calibrated?
Answer: Yes, you can calibrate them yourself or send them out for calibration. Ideally, you will calibrate them yourself on the vehicle.
Question: How do I know if the problem is the sender or gauge?
Answer: Go to the sender, disconnect the plug, and ground it directly to the body or engine block. If the gauge moves to maximum, replace the sender. If the gauge is unresponsive, suspect the gauge, wiring, or voltage regulator.
Tapping on the Gas Gauge
It is surely an old cliché, but knowing true fuel quantity has never been an exact science. Just because the gauge is on "E" doesn't always mean the tank is empty. Or, it can be empty but the fuel gauge shows a quarter tank. Here's how you can get it spot on.
[align=center]
A typical fuel tank sending unit shows 73.6 ohms and a dim bulb with an empty tank....
....This means high resistance to the flow of electricity and a low fuel reading because power through the gauge is low, thus reading "E."
With the float at maximum with a full tank, we have 9.7 ohms and a bright bulb, indicating minimal resistance and a much higher flow of electricity to ground so the fuel gauge reads "F."
The fuel tank sending unit can be calibrated along with the fuel gauge. This is where we fine-tune the fuel gauge and sending unit to get a spot-on gas gauge.
[/align]
When it comes to fuel quantity, there are three forms of calibration designed to get you close to what's in the tank. First, don't begin with handicaps such as a bashed in fuel tank, damaged sender, or trash in the fuel tank. Begin your calibration process with good parts and a clean tank. We're going to show you how variable resistance translates to needle position on a fuel gauge using a multimeter (ohmmeter) and a simple 12-volt light bulb.
[align=center]
Beginning in '67, Ford got away from instrument panel sockets and connectors in the main wiring loom. Instead, '67-'68 Mustangs had instrument harnesses incorporated into the cluster itself with one or two main harness multiplex plugs. Instrument basics remain the same as '65-'66.
Although General Motors had been utilizing printed circuit technology for ages, Ford didn't get on board until '69 when Mustang instrument clusters went from wiring harnesses to printed circuits with a main multiplex plug to feed the whole works. Instrument basics remain the same for '69-'70 with an integral voltage regulator.
Printed circuit technology only got better for '71-'73, with the same printed circuit for all instrument panel types with an integral voltage regulator.
[/align]
Offline napes
« Reply #1 on: September 02, 2010, 09:00:30 pm »
Thanks for posting CPU - really good article :)
CPU
  • Guest
CPU
« Reply #2 on: September 03, 2010, 12:52:20 am »
My pleasure. :hi:
There are a few good articles that pop up in that magazine.  As more come to light we will post them.
Offline Phoenix
« Reply #3 on: September 03, 2010, 08:55:44 am »
Thats a :gpost: CPU with :cpics:. I'll go and have a :drink: in appreciation.
:thumb: Phoenix.
Phoenix, from the desert, not the ashes.
Too old to rock and roll, too young to die.
Offline beancounter
« Reply #4 on: October 01, 2010, 10:03:21 pm »
no mention of the clock?
which is the only thing not working on my dash.
apart from only having one half of the panel lit up
any suggestions?
Offline A67PNY
« Reply #5 on: October 01, 2010, 10:18:57 pm »
Hey beancounter if your clock needs repair
try these people....
http://www.ottoinstruments.com.au/repairs.htm
CPU
  • Guest
CPU
« Reply #6 on: December 31, 2010, 01:53:39 pm »
Quote from: beancounter link=topic=12082.msg130661#msg130661
any suggestions?
Better late than never :giggle:
We found an article or two and posted it here http://mustang.org.au/forum/viewthread.php?tid=13248
Offline my 390
Re: Ford Mustang Instrument Panel Troubleshooting
« Reply #7 on: December 28, 2013, 04:04:53 pm »
Thanks CPU
I just fitted dakota gauges and the engine won't start.  A search on here found this and presto.  Disconnectingnthe old tacho means the engine wont run.  Temporarily put the old tach back and it runs again. The above article put me right.  Now to find a work around. New topic coming
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
« Reply #8 on: July 22, 2015, 07:19:00 pm »
Can someone explain the ammeter in my 65; Deluxe (Pony) dash?
From what I understand it's supposed to hit D when discharging and C when charging; in mine the needle always sits dead centre between D and C with ignition on or off.
Just trying to figure out if it works or is broken.
s
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« Reply #9 on: July 22, 2015, 10:20:47 pm »
There are a couple of good articles on this subject to Google up if you want more detail, but the short version is these things were poorly designed/implemented by Ford and never had a chance of working properly from day one.
The ammeters are designed to shunt a small portion of the current that flows between the alternator/regulator and the battery.  The problem is for the needle to show any significant deflection it requires more current flowing through the ammeter than the resistance of the wiring and the gauge itself will allow under normal loads.  I forget the exact value but it worked out you'd need somewhere around 100 amps flowing to/from the battery to get significant needle movement.
It is generally acknowledged that it is much easier and just as useful to implement a voltmeter rather than an ammeter and that is what Ford could/should have done...
If someone was really keen on getting an ammeter to work, they'd need to buy a modern gauge with much lower internal resistance and run thicker, lower resistance wire from the gauge back to the splice points in the wiring harness.
Edit: Here's an excellent post on the subject from allfordmustangs.com that offers re-wiring suggestions if you want to try to get your factory ammeter needle moving:
http://www.allfordmustangs.com/forums/classic-tech/233652-1966-mustang-ammeter-wiring.html
« Last Edit: July 22, 2015, 10:32:21 pm by BAC »
Brian
Offline StephenSLR
    • www.lycanthia.com
« Reply #10 on: July 22, 2015, 10:31:18 pm »
I've had a bit of a search and yeah from 66 onwards they have two wires that attach to the rear of the gauge and the element inside the gauge was so poor it'd often burn out and could be a fire risk; some recommend turning the gauge into voltmeters.
The 65 ammeters have an induction loop within and it picks up current running through a wire that passes through a flat loop at the rear of the gauge.
Just wondering; when they are working; what movement do you see; if at all and when?
s
« Last Edit: July 22, 2015, 10:33:12 pm by StephenSLR »
Offline BAC
  • Name: Brian
« Reply #11 on: July 22, 2015, 10:49:03 pm »
If you could grab hold of a stand alone inductive ammeter you could test how much current is running though the loop cable and compare it to the Ford spec (assuming you can look it up somewhere...)
Brian
