belt/pulley systems
Author Topic: belt/pulley systems  (Read 13259 times)
Offline MILD67
  • Name: Rob
belt/pulley systems
« on: May 24, 2010, 07:21:27 pm »
just wondering what pros and cons there are for the v-belt, gilmer drive, and serpentine systems, i have the gilmer drive system atm but cant get it to run right. first it was jumping off, now its chewing belts, should i just go back to the old v belt or go to the serpentine system?
Offline stormin
belt/pulley systems
« Reply #1 on: May 24, 2010, 07:42:11 pm »
My new stroker has the serpentine belt drive. Looks great ran true on the dyno and does P/S,Alt, W/P and A/C and was really greatly priced.
I have a new Gilmer Belt drive set for sale if anyone wants one $150
Stormin
Offline Auslayne
belt/pulley systems
« Reply #2 on: May 24, 2010, 09:43:23 pm »
What engine is it for, Stormin? If it's 289/302 I'll take it.
Offline stormin
belt/pulley systems
« Reply #3 on: May 24, 2010, 09:59:39 pm »
Yes it is .I have no use for it .
Stormin
Offline Auslayne
belt/pulley systems
« Reply #4 on: May 24, 2010, 10:08:46 pm »
Hey Mild67,
I've had a few and never had many issues, but there are a few things to be wary of-
1/ the axis of all pulleys must be parallel, biggest culprit being the alt- don't trust the factory brackets, either. I use March billet brackets/mounts and usually have to space things here and there. Sometimes the water pump pulley needs washers between the pulley and flange. I'm guessing the belt was jumping because it was climbing over the alt pulley sides. These set ups must be spot on-orientation wise. (can be hard to eye-ball while the engine is in the car)
2/ I'd say if you're shredding belts the tension is too much. Like I mentioned above, if everything is lined up right, then just screw the tensioner bar/adjust the alt out with just enough weight on it. How much is just enough? Feel/flex the belt on the bottom span and you should move it about 12mm. Run the engine and note the pitch or noise. Too loose will create a kind of vibration, nip it up (turn it off first) in small steps until it sounds just like a blower whine. Normally, the 'loudness' fades the tighter it gets.
Lastly, remember these belts have tremendous 'bite' and you're only driving an alt and water pump, so let the teeth do the work not the belt strain. These setups don't work on the same principals as V or serpantine belts.
Can you post some pics taken fron each side?
Hope this helps-
Layne
Offline Auslayne
belt/pulley systems
« Reply #5 on: May 24, 2010, 10:10:15 pm »
Stormin,
Done deal, mate. U2U me your details and I'll follow up tomorrow.
Cheers-
Offline MILD67
  • Name: Rob
belt/pulley systems
« Reply #6 on: May 25, 2010, 01:00:23 am »
iv got it all in pieces at the moment and waiting on a march bracket and new water pump before i reassemble and give it another go, also i brought a cheap 130amp chrome alt and the alloy is very soft and maybe flexing a little.
Offline stormin
belt/pulley systems
« Reply #7 on: May 25, 2010, 04:48:13 pm »
Layne
Need your address etc. u2u sent
Stormin
Offline hybrid
belt/pulley systems
« Reply #8 on: May 25, 2010, 04:54:00 pm »
What's the serpentine system?
I need to look at pulleys for mine - I'll be using P/S and Aircon.
- Stupid questions are better than stupid mistakes.
- Before you criticize a man, walk a mile in his shoes. That way, if he gets angry, he's a mile away, barefoot, and you've got his shoes.
CPU
  • Guest
CPU
belt/pulley systems
« Reply #9 on: May 25, 2010, 05:06:46 pm »
Quote from: hybrid link=topic=10685.msg110305#msg110305
A reverse rotation water pump is required with this particular package
Offline stormin
belt/pulley systems
« Reply #10 on: May 25, 2010, 05:07:45 pm »
U2U sent
Stormin
Offline moe
  • Name: "Moe"
belt/pulley systems
« Reply #11 on: May 25, 2010, 05:10:37 pm »
http://en.wikipedia.org/wiki/Serpentine_belt
A serpentine belt (also known as a multi-vee or multi-rib belt) is a single, continuous belt used to drive multiple peripheral devices in an automotive engine, such as an alternator, power steering pump, water pump, A/C compressor, air pump, etc. The belt may also be guided by an idler pulley and/or a belt tensioner  (which may be spring loaded, hydraulic, or manual). The serpentine belt was invented by Jim Vance while working for the Gates Rubber Company and first used by Ford Motor Company for the 1979 Mustang.
Offline hybrid
belt/pulley systems
« Reply #12 on: May 25, 2010, 05:26:22 pm »
Yep.. did some searching on it.
Stormin sent the details on his, but can't justify that kind of money for a set of pulleys.
Standard ones will have to do :+
Offline moe
  • Name: "Moe"
belt/pulley systems
« Reply #13 on: May 25, 2010, 05:30:20 pm »
would it be possible to modify a set of an E series 5.0L??
Offline stormin
belt/pulley systems
« Reply #14 on: May 25, 2010, 06:35:00 pm »
Hybrid
You misread what I sent you.
New U2U sent.
stormin
Offline hybrid
belt/pulley systems
« Reply #15 on: May 25, 2010, 06:44:19 pm »
Indeed I did!
That's not so bad. I'll have to price up my aircon unit without compressor to see how much that saves me.
Offline stormin
belt/pulley systems
« Reply #16 on: May 25, 2010, 07:58:21 pm »
Polished alternator,BILLET polished P/S pump Polished A/C compressor Idler  and all other braketry and S/S or chrome bolts  and belt.   Very similar to CPU's picture   a couple of posts back
Stormin
Offline HEVEN67
belt/pulley systems
« Reply #17 on: June 13, 2010, 04:54:28 pm »
Offline KIMS 66
    • www.caseylimousines.com.au
belt/pulley systems
« Reply #18 on: September 02, 2010, 09:08:15 pm »
What price am I looking at for a serpantine unit and where can I get 1?
CPU
  • Guest
CPU
belt/pulley systems
« Reply #19 on: September 02, 2010, 09:26:14 pm »
One supplier in the states is Billet Specialties. CLICK ME  I believe Rocket Ind's is one of the agents for them here. CLICK ME
Offline kiwi69
belt/pulley systems
« Reply #20 on: September 02, 2010, 09:35:41 pm »
Concept one and March pulley systems do the serpentine pulley systems.
CPU
  • Guest
CPU
belt/pulley systems
« Reply #21 on: September 02, 2010, 09:53:10 pm »
For Concept 1 CLICK ME
For March Performance CLICK ME
Offline VIBE 65
    • www.vibephotography.com.au
belt/pulley systems
« Reply #22 on: September 08, 2010, 07:55:47 am »
hey stormin what are the details of your sepentine system can you u2u me too.
Thanks!
Offline stormin
belt/pulley systems
« Reply #23 on: September 08, 2010, 08:39:32 pm »
U2U sent
Stormin
Offline stormin
belt/pulley systems
« Reply #24 on: September 09, 2010, 08:12:48 am »
U2U sent
Stormin
