sequential tail lights and the law
Author Topic: sequential tail lights and the law  (Read 8604 times)
Offline 1965 R
« on: January 28, 2010, 01:03:49 pm »
I bought a 65 fastback from the US and am working towards getting the car ready for the pits. I love my tail lights but have been told that they are probably not allowed in WA.
Is that correct and what would this be like for a fix if so.
http://www.lamustang.com/ShowItem/108205%201964%20-%201966%20Mustang%20LED%20Tail%20Light%20Panels.aspx
What do most people do to pass the pits with this problem???
1965 R
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #1 on: January 28, 2010, 02:36:51 pm »
What brand lights are they?
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline jaythefordman
« Reply #2 on: January 28, 2010, 02:50:49 pm »
Can't see a problem with them, and not sure if the law will have a problem.
In my opinion, just leave them in and leave it up to the guys at the pits.
My 66 was passed with tailights in std US spec, no changes at all.  Just had to change headlights and front indicator lenses changed to clear
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #3 on: January 28, 2010, 03:07:35 pm »
Sequential were standard on Cougars....
Custom Mustangs
Signature Sponsor
Offline 1965 R
« Reply #4 on: January 28, 2010, 04:09:06 pm »
Manufacturer: Scott Drake Enterprises
1964 - 1966 Ford Mustang LED Tail Lights
These LED Tail Lamps Feature Both Large And Small LEDs For A Unique Look. Each Bank Of LEDs Are Independent To Make A Distinction Between Tail Light And Brake / Turn Signal Lights.
So its possibly just the yellow lenses that will be the problem then.
Offline Roegs
« Reply #5 on: January 28, 2010, 04:10:26 pm »
It will be a matter of rule/law interpretation by the person on the day inspecting.
I looked up the writings in the Australian Vehicle Standards Rules in relation to having red rear indicators (which states they can be yellow or red for vehicles built prior to July 1973) in case a traffic officer was not quite well versed in the rulings.
The part of the vehicle standards that you may have trouble with is Part 8, Div 11, Rule 104, section (1)(d):
"flash at the same time and rate as any other direction indicator lights on the same side of the vehicle"
So I guess it could be argued by a real anal inspector that sequential don't flash the same as the front indicators (since there's only one light at the front, instead of the 3 panels at the back).
Earlier in that section it talks about the minimum flash rate being 60, with a maximum of 120.  Would the new flasher module with the sequential change, ie slow, the flash rate of the front indicators?  I don't know much about the actual components of these indicators.
In my opinion this will be another one of those things where you get one answer from someone, and the complete opposite from someone else. :[
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #6 on: January 28, 2010, 04:25:24 pm »
Sorry, I don't know anything about the Scott Drake ones, if they were ours (Mustang Project) i could have sorted it for you.
Did you buy them, or were you told they were Scott Drake?
Custom Mustangs
Signature Sponsor
Offline Frank70
« Reply #7 on: January 28, 2010, 05:20:48 pm »
Technically they can be flashing at the same time and rate as the fronts - only that it is a different panel everytime.
You should get away with it - I think in Vic you would not surte about WA.
Do my old trick and book the last appointment Friday arvo.  :+
Frank.
Offline non member
  • Account Closed
« Reply #8 on: January 28, 2010, 05:33:54 pm »
But when conveted (when new) back in the 60's they were taken out & standard flashers put in their place. They were illegal then, maybe still now. Most got reinstalled after the pit inspection of the day.
However once registered, I do not believe that it would cause any grief from the law unless the driver was doing something totally stupid.
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #9 on: January 28, 2010, 06:49:25 pm »
If they were Mustang Project LED's, I could just set him up with a reprogrammed flasher unit, for the Road Worthy, which is why I am trying to make sure he is sure they are Scott Drake.
Custom Mustangs
Signature Sponsor
Offline nassi
« Reply #10 on: January 28, 2010, 08:51:54 pm »
Sequential tail lights have been passed in WA. :(
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline SLY66
« Reply #11 on: January 28, 2010, 09:23:33 pm »
i got the 66 regoe,d last year with those lights and no probs, the only thing i was asked by vic roads was to put lap belts in the front, dont think i have even put them on yet!
SLY-66
Offline 1965 R
« Reply #12 on: January 30, 2010, 02:45:52 am »
Thanks every one for your input!!!
BLKPNY tell me more about your set up on offer project LED
Offline mistermustang
« Reply #13 on: January 30, 2010, 10:11:56 am »
1965 R
not true.  i have a 68 GT500 with sequentials (stock) licensed in WA.  all i can suggest is not going to east perth pits as they're a bunch of idiots who don't know $hit about mustangs yet have the power to say 'no'.  suggest Welshpool.
BrianE :o
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #14 on: January 30, 2010, 11:03:03 am »
Mustang Project were the first to bring Sequential LED's to the Mustang market.
If you took a pic of the circuit board, I coult tell you if they were ours or not.
If they are ours, a Non Seqential LED flasher from us will convert them to normal operation, while it's getting checked.
Custom Mustangs
Signature Sponsor
Offline 1965 R
« Reply #15 on: February 02, 2010, 03:02:04 am »
So Welshpool it will be late on a Friday. I will only fix what I definitely need to then and see what they say with the rest as like you all say the wont even know all the rules them selves so it will be guess work for them as to whats ok or not.
Offline nassi
« Reply #16 on: February 02, 2010, 08:51:47 am »
Dont make it too late on Friday if the que is long they will turn you away and finnish what they have. They dont do OT.
Goodluck.
cheers
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
