Engine code
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
Engine code
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Engine code (Read 1722 times)
Chris66pny
Stallion
I'm new here
Car: 66 Mustang
Chris66pny
Engine code
on:
February 02, 2021, 08:59:36 pm »
Hi all,
I have a clients car that has the following code cast in the motor D2AE CA 1701. Just wondering is anyone could shed some light in the origins of this engine? Been told it's a mustang block but it's definitely not in a mustang.
Thanks in advance.
Logged
sms777
Worked
sms777
Re: Engine code
Reply #1 on:
February 02, 2021, 11:38:00 pm »
Quick google search tells me it's a 351 Cleveland of 1971-74 4 bolt mains high output Cobra Jet or Boss engine.
Logged
Chris66pny
Stallion
I'm new here
Car: 66 Mustang
Chris66pny
Re: Engine code
Reply #2 on:
February 03, 2021, 10:38:09 am »
That's what I found also. But........here's the full story.
The engine is in a 1981 Fairlane LTD, the engine has the above casting mark but is also stamped with a vin number matching the chassis which has the Geelong factory reference (stamped on the left front hand side of motor next to water pump). Trying to figure out if the engine was a replacement or came from factory like this? Why would they use a motor from 72 motor in an 81 car?
Logged
GLENN 70
GT 500
GLENN 70
Re: Engine code
Reply #3 on:
February 03, 2021, 11:27:20 am »
Is it a black engine ? , electronic dizzy? , dizzy shaft size ? And what heads ? . A lot of 79-82 Aussie 351c had 4 bolt mains as ford was getting rid of all the old stock 351c engines .
Logged
Chris66pny
Stallion
I'm new here
Car: 66 Mustang
Chris66pny
Re: Engine code
Reply #4 on:
February 03, 2021, 11:36:54 am »
Its a black engine, unsure about the rest, will be pulling the engine in the coming week to go over everything and have it rebuilt, ill get more info then. Id heard they used old blocks but unsure on the truth to this, looking more and more likely!
Logged
sms777
Worked
sms777
Re: Engine code
Reply #5 on:
February 07, 2021, 12:09:14 am »
Sounds like it's the original '72 American engine got replaced at one stage which originally had the engine number stamped at the back of the block just below the left cylinder head. To satisfy our rego requirements they could have simply just bang the VIN on the block near the waterpump which is the correct location for an Aussie Cleveland. It is acceptable in most states.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Engine code
